[mapserver-commits] r8073 - trunk/docs
Sun Nov 23 21:40:12 EST 2008
Author: hobu
Date: 2008-11-23 21:40:12 -0500 (Sun, 23 Nov 2008)
New Revision: 8073
Added:
   trunk/docs/Makefile
   trunk/docs/_static/
   trunk/docs/_templates/
   trunk/docs/conf.py
add sphinx build stuff
Added: trunk/docs/Makefile
--- trunk/docs/Makefile	                        (rev 0)
+++ trunk/docs/Makefile	2008-11-24 02:40:12 UTC (rev 8073)
@@ -0,0 +1,75 @@
+# Makefile for Sphinx documentation
+# You can set these variables from the command line.
+SPHINXOPTS    =
+SPHINXBUILD   = sphinx-build
+PAPER         =
+# Internal variables.
+PAPEROPT_a4     = -D latex_paper_size=a4
+PAPEROPT_letter = -D latex_paper_size=letter
+ALLSPHINXOPTS   = -d build/doctrees $(PAPEROPT_$(PAPER)) $(SPHINXOPTS) .
+.PHONY: help clean html web pickle htmlhelp latex changes linkcheck
+help:
+	@echo "Please use \`make <target>' where <target> is one of"
+	@echo "  html      to make standalone HTML files"
+	@echo "  pickle    to make pickle files"
+	@echo "  json      to make JSON files"
+	@echo "  htmlhelp  to make HTML files and a HTML help project"
+	@echo "  latex     to make LaTeX files, you can set PAPER=a4 or PAPER=letter"
+	@echo "  changes   to make an overview over all changed/added/deprecated items"
+	@echo "  linkcheck to check all external links for integrity"
+clean:
+	-rm -rf build/*
+html:
+	mkdir -p build/html build/doctrees
+	$(SPHINXBUILD) -b html $(ALLSPHINXOPTS) build/html
+	@echo
+	@echo "Build finished. The HTML pages are in build/html."
+pickle:
+	mkdir -p build/pickle build/doctrees
+	$(SPHINXBUILD) -b pickle $(ALLSPHINXOPTS) build/pickle
+	@echo
+	@echo "Build finished; now you can process the pickle files."
+web: pickle
+json:
+	mkdir -p build/json build/doctrees
+	$(SPHINXBUILD) -b json $(ALLSPHINXOPTS) build/json
+	@echo
+	@echo "Build finished; now you can process the JSON files."
+htmlhelp:
+	mkdir -p build/htmlhelp build/doctrees
+	$(SPHINXBUILD) -b htmlhelp $(ALLSPHINXOPTS) build/htmlhelp
+	@echo
+	@echo "Build finished; now you can run HTML Help Workshop with the" \
+	      ".hhp project file in build/htmlhelp."
+latex:
+	mkdir -p build/latex build/doctrees
+	$(SPHINXBUILD) -b latex $(ALLSPHINXOPTS) build/latex
+	@echo
+	@echo "Build finished; the LaTeX files are in build/latex."
+	@echo "Run \`make all-pdf' or \`make all-ps' in that directory to" \
+	      "run these through (pdf)latex."
+changes:
+	mkdir -p build/changes build/doctrees
+	$(SPHINXBUILD) -b changes $(ALLSPHINXOPTS) build/changes
+	@echo
+	@echo "The overview file is in build/changes."
+linkcheck:
+	mkdir -p build/linkcheck build/doctrees
+	$(SPHINXBUILD) -b linkcheck $(ALLSPHINXOPTS) build/linkcheck
+	@echo
+	@echo "Link check complete; look for any errors in the above output " \
+	      "or in build/linkcheck/output.txt."
Added: trunk/docs/conf.py
--- trunk/docs/conf.py	                        (rev 0)
+++ trunk/docs/conf.py	2008-11-24 02:40:12 UTC (rev 8073)
@@ -0,0 +1,187 @@
+# -*- coding: utf-8 -*-
+# MapServer documentation build configuration file, created by
+# sphinx-quickstart on Fri Nov 21 09:49:43 2008.
+# This file is execfile()d with the current directory set to its containing dir.
+# The contents of this file are pickled, so don't put values in the namespace
+# that aren't pickleable (module imports are okay, they're removed automatically).
+# All configuration values have a default; values that are commented out
+# serve to show the default.
+import sys, os
+# If your extensions are in another directory, add it here. If the directory
+# is relative to the documentation root, use os.path.abspath to make it
+# absolute, like shown here.
+#sys.path.append(os.path.abspath('.'))
+# General configuration
+# Add any Sphinx extension module names here, as strings. They can be extensions
+# coming with Sphinx (named 'sphinx.ext.*') or your custom ones.
+extensions = []
+# Add any paths that contain templates here, relative to this directory.
+templates_path = ['_templates']
+# The suffix of source filenames.
+source_suffix = '.txt'
+# The encoding of source files.
+#source_encoding = 'utf-8'
+# The master toctree document.
+master_doc = 'index'
+# General information about the project.
+project = u'MapServer'
+copyright = u'2008, Steve Lime'
+# The version info for the project you're documenting, acts as replacement for
+# |version| and |release|, also used in various other places throughout the
+# built documents.
+# The short X.Y version.
+version = '5'
+# The full version, including alpha/beta/rc tags.
+release = '5.4.0'
+# The language for content autogenerated by Sphinx. Refer to documentation
+# for a list of supported languages.
+#language = None
+# There are two options for replacing |today|: either, you set today to some
+# non-false value, then it is used:
+#today = ''
+# Else, today_fmt is used as the format for a strftime call.
+#today_fmt = '%B %d, %Y'
+# List of documents that shouldn't be included in the build.
+#unused_docs = []
+# List of directories, relative to source directory, that shouldn't be searched
+# for source files.
+exclude_trees = []
+# The reST default role (used for this markup: `text`) to use for all documents.
+#default_role = None
+# If true, '()' will be appended to :func: etc. cross-reference text.
+#add_function_parentheses = True
+# If true, the current module name will be prepended to all description
+# unit titles (such as .. function::).
+#add_module_names = True
+# If true, sectionauthor and moduleauthor directives will be shown in the
+# output. They are ignored by default.
+#show_authors = False
+# The name of the Pygments (syntax highlighting) style to use.
+pygments_style = 'sphinx'
+# Options for HTML output
+# The style sheet to use for HTML and HTML Help pages. A file of that name
+# must exist either in Sphinx' static/ path, or in one of the custom paths
+# given in html_static_path.
+html_style = 'default.css'
+# The name for this set of Sphinx documents.  If None, it defaults to
+# "<project> v<release> documentation".
+#html_title = None
+# A shorter title for the navigation bar.  Default is the same as html_title.
+#html_short_title = None
+# The name of an image file (relative to this directory) to place at the top
+# of the sidebar.
+#html_logo = None
+# The name of an image file (within the static path) to use as favicon of the
+# docs.  This file should be a Windows icon file (.ico) being 16x16 or 32x32
+# pixels large.
+#html_favicon = None
+# Add any paths that contain custom static files (such as style sheets) here,
+# relative to this directory. They are copied after the builtin static files,
+# so a file named "default.css" will overwrite the builtin "default.css".
+html_static_path = ['_static']
+# If not '', a 'Last updated on:' timestamp is inserted at every page bottom,
+# using the given strftime format.
+#html_last_updated_fmt = '%b %d, %Y'
+# If true, SmartyPants will be used to convert quotes and dashes to
+# typographically correct entities.
+#html_use_smartypants = True
+# Custom sidebar templates, maps document names to template names.
+#html_sidebars = {}
+# Additional templates that should be rendered to pages, maps page names to
+# template names.
+#html_additional_pages = {}
+# If false, no module index is generated.
+#html_use_modindex = True
+# If false, no index is generated.
+#html_use_index = True
+# If true, the index is split into individual pages for each letter.
+#html_split_index = False
+# If true, the reST sources are included in the HTML build as _sources/<name>.
+#html_copy_source = True
+# If true, an OpenSearch description file will be output, and all pages will
+# contain a <link> tag referring to it.  The value of this option must be the
+# base URL from which the finished HTML is served.
+#html_use_opensearch = ''
+# If nonempty, this is the file name suffix for HTML files (e.g. ".xhtml").
+#html_file_suffix = ''
+# Output file base name for HTML help builder.
+htmlhelp_basename = 'MapServerdoc'
+# Options for LaTeX output
+# The paper size ('letter' or 'a4').
+#latex_paper_size = 'letter'
+# The font size ('10pt', '11pt' or '12pt').
+#latex_font_size = '10pt'
+# Grouping the document tree into LaTeX files. List of tuples
+# (source start file, target name, title, author, document class [howto/manual]).
+latex_documents = [
+  ('index', 'MapServer.tex', ur'MapServer Documentation',
+   ur'Steve Lime', 'manual'),
+# The name of an image file (relative to this directory) to place at the top of
+# the title page.
+#latex_logo = None
+# For "manual" documents, if this is true, then toplevel headings are parts,
+# not chapters.
+#latex_use_parts = False
+# Additional stuff for the LaTeX preamble.
+#latex_preamble = ''
+# Documents to append as an appendix to all manuals.
+#latex_appendices = []
+#latex_use_modindex = True
