[mapserver-commits] r8138 - trunk/docs/development/rfc
svn at osgeo.org
svn at osgeo.org
Sun Nov 30 13:53:41 EST 2008
Author: hobu
Date: 2008-11-30 13:53:41 -0500 (Sun, 30 Nov 2008)
New Revision: 8138
trunk/docs/development/rfc/ms-rfc-40.txt
ReST formatting, etc
Modified: trunk/docs/development/rfc/ms-rfc-40.txt
--- trunk/docs/development/rfc/ms-rfc-40.txt 2008-11-30 18:41:14 UTC (rev 8137)
+++ trunk/docs/development/rfc/ms-rfc-40.txt 2008-11-30 18:53:41 UTC (rev 8138)
@@ -14,18 +14,29 @@
Overview
-MapServer 5.0 supports "hard" text wrapping, where the wrap character is unconditionally treated as a newline. This rfc proposes the addition of:
- - conditional wrapping, i.e. newlines are only added when the current line length has met a user adjustable criteria
+MapServer 5.0 supports "hard" text wrapping, where the wrap character is
+unconditionally treated as a newline. This RFC proposes the addition of:
+ - conditional wrapping, i.e. newlines are only added when the current
+ line length has met a user adjustable criteria
- line alignment, i.e. text aligned per user request, namely right, center and left
-These two additions are independant from one another, i.e. can be activated together or not.
+These two additions are independent from one another, i.e. can be activated
+together or not.
Line Wrapping
-A new keyword, MAXLENGTH is added to the label object, and interacts with the label WRAP parameter as follows:
- - the wrap character specifies what character can be replaced by a newline (no change w.r.t. the current meaning). Probably the most usefull wrap character will become ' ' (i.e. the space character)
- - the MAXLENGTH value specifies the maximum number of characters that can compose a line before a newline is inserted. A value of 0 specifies the current "hard" wrapping. A positive value triggers wrapping at the WRAP character for lines longer than MAXLENGTH. A Negative value triggers wrapping that is allowed to break words, i.e. not necessarily at the WRAP character.
+A new keyword, MAXLENGTH is added to the label object, and interacts with the
+label WRAP parameter as follows:
+ - the wrap character specifies what character can be replaced by a newline
+ (no change w.r.t. the current meaning). Probably the most useful wrap
+ character will become ' ' (i.e. the space character)
+ - the MAXLENGTH value specifies the maximum number of characters that can
+ compose a line before a newline is inserted. A value of 0 specifies the
+ current "hard" wrapping. A positive value triggers wrapping at the WRAP
+ character for lines longer than MAXLENGTH. A negative value triggers
+ wrapping that is allowed to break words, i.e. not necessarily at
+ the WRAP character.
The WRAP / MAXLENGTH combinations are summarized here:
@@ -41,41 +52,48 @@
Line Centering
-A new keyword ALIGN is added to the label object. It supports 3 values: left, center and right,
-and controls how text lines should be aligned w.r.t. the label bounding box. Precise placement of text can only
-be done at the renderer level, by exactly defining the starting pixel of the current line. While this approach
-could be taken, it would considerably burden the renderer code.
+A new keyword ALIGN is added to the label object. It supports 3 values: left,
+center and right, and controls how text lines should be aligned w.r.t. the
+label bounding box. Precise placement of text can only be done at the renderer
+level, by exactly defining the starting pixel of the current line. While this
+approach could be taken, it would considerably burden the renderer code.
-I propose to use a more generic though less precise way of doing, by padding the text lines with space characters
-to approximate indentation. The initial implementation could only rely on the number of characters in each
-text line:
+I propose to use a more generic though less precise way of doing, by
+padding the text lines with space characters to approximate indentation.
+The initial implementation could only rely on the number of characters in
+each text line:
- loop through text lines to find the line with the most characters l_max
- pad all the other lines with (l_max - l_cur)/2 space characters
-A more advanced implementation will be to use the exact line lengths as returned by the renderers with the
-msGetLabelSize function:
+A more advanced implementation will be to use the exact line lengths as
+returned by the renderers with the msGetLabelSize function:
- - compute the size in pixels of the " " string (two spaces, accounts for kerning): l_2space
+ - compute the size in pixels of the " " string (two spaces,
+ accounts for kerning): l_2space
- loop through text lines to longest line of length pix_l_max
- - pad all the other lines with (pix_l_max - pix_l_cur)/2 * 1/(2*l_2space) space characters
+ - pad all the other lines with
+ (pix_l_max - pix_l_cur)/2 * 1/(2*l_2space) space characters
-'''Limitations''': aligning text to the right will produce ugly results using this method, unless using a
-monospace font.
+'''Limitations''': aligning text to the right will produce ugly results using
+this method, unless using a monospace font.
Modifications to the source code
-* MAXLENGTH and ALIGN will be added to the LABEL object in map.h, in the mapfile parser/writer (mapfile.c) and in MapScript
+* MAXLENGTH and ALIGN will be added to the LABEL object in map.h, in the
+ mapfile parser/writer (mapfile.c) and in MapScript
-* msTransformLabelText() in maplabel.c will be updated to support the modifications proposed. No other modifications
- should be required as the text itself is modified to fit the user's request (i.e. it is padded with spaces, and/or
- newlines are added to it)
+* msTransformLabelText() in maplabel.c will be updated to support the
+ modifications proposed. No other modifications should be required as the
+ text itself is modified to fit the user's request (i.e. it is padded with
+ spaces, and/or newlines are added to it)
MapScript Implications
-The labelObj will have new maxlength property of type integer, and align property (ms_align_*).
+The labelObj will have new maxlength property of type integer
+and align property (ms_align_*).
Files affected
@@ -105,5 +123,12 @@
Questions/Comments from the review period
-* SteveW: allow preciser computation of line offsets when padding with spaces: done. The precise size of each line is calculated in pixels, and the closest number of space characters required for alignment is computed accordingly
-* DanielM: allow multiple characters to be used when wrapping lines: not addressed. Space characters can be *replaced* by a newline, while the hyphen character should generally be kept. Any idea how we can specify that some wrapping characters are to be kept while others are just markers for potential linebreaks?
+* SteveW: allow preciser computation of line offsets when
+ padding with spaces: done. The precise size of each line is
+ calculated in pixels, and the closest number of space characters
+ required for alignment is computed accordingly
+* DanielM: allow multiple characters to be used when wrapping lines:
+ not addressed. Space characters can be *replaced* by a newline, while the
+ hyphen character should generally be kept. Any idea how we can specify that
+ some wrapping characters are to be kept while others are just markers
+ for potential linebreaks?
More information about the mapserver-commits
