[mapserver-commits] r8139 - in trunk/docs: development/rfc input
svn at osgeo.org
svn at osgeo.org
Sun Nov 30 13:54:06 EST 2008
Author: hobu
Date: 2008-11-30 13:54:06 -0500 (Sun, 30 Nov 2008)
New Revision: 8139
trunk/docs/development/rfc/ms-rfc-4.txt
trunk/docs/input/raster_data.txt
add some linkages
Modified: trunk/docs/development/rfc/ms-rfc-4.txt
--- trunk/docs/development/rfc/ms-rfc-4.txt 2008-11-30 18:53:41 UTC (rev 8138)
+++ trunk/docs/development/rfc/ms-rfc-4.txt 2008-11-30 18:54:06 UTC (rev 8139)
@@ -22,7 +22,7 @@
* The new resampling options will be implemented in mapresample.c and will
- only be accessable for datasets processing through that mechanism (ie.
+ only be accessible for datasets processing through that mechanism (ie.
GDAL raster formats, requires coordinate system information defined).
* The resampling kernel to use will be selected with one of the following.
@@ -50,23 +50,23 @@
All new options are selected via new PROCESSING options. There is
-no change in the mapfile syntax. There should be no compatbability problems
+no change in the mapfile syntax. There should be no compatibility problems
with old mapfiles.
MapScript Implications
-There are no additions or changes to the mapscript API. The new
+There are no additions or changes to the MapScript API. The new
options are controlled via PROCESSING information on the layers which I
-believe is already manipulatable from mapscript.
+believe is already manipulatable from MapScript.
Documentation Implications
-The new processing options will need to be documented in the Raster HOWTO
-(and possibly the mapfile reference).
+The new processing options will need to be documented in the :ref:`raster`
+(and possibly the :ref:`map` reference).
Test Plan
Modified: trunk/docs/input/raster_data.txt
--- trunk/docs/input/raster_data.txt 2008-11-30 18:53:41 UTC (rev 8138)
+++ trunk/docs/input/raster_data.txt 2008-11-30 18:54:06 UTC (rev 8139)
@@ -1,3 +1,5 @@
+.. _raster:
Raster Data
More information about the mapserver-commits
