[mapserver-commits] r7956 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Sat Oct 4 11:37:16 EDT 2008
Author: tbonfort
Date: 2008-10-04 11:37:16 -0400 (Sat, 04 Oct 2008)
New Revision: 7956
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapagg.cpp
fix a bug with shapes with duplicate end points. was causing nans in the angle follow placement code (#2695)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2008-10-04 11:02:58 UTC (rev 7955)
+++ trunk/mapserver/HISTORY.TXT 2008-10-04 15:37:16 UTC (rev 7956)
@@ -11,6 +11,9 @@
Current Version (5.3-dev, SVN trunk):
+- fix a bug with shapes with duplicate end points. was causing nans
+ in the angle follow placement code (#2695)
- refactor msGetLabelSizeEx (now merged with msGetLabelSize) (#2390)
- native label size computation for AGG when using angle follow (#2357)
Modified: trunk/mapserver/mapagg.cpp
--- trunk/mapserver/mapagg.cpp 2008-10-04 11:02:58 UTC (rev 7955)
+++ trunk/mapserver/mapagg.cpp 2008-10-04 15:37:16 UTC (rev 7956)
@@ -2113,7 +2113,7 @@
for (i = 0; i < labelpath->path.numpoints; i++) {
double x, y;
double theta;
if (msGetNextGlyph(&string_ptr, s) == -1)
break; /* Premature end of string??? */
@@ -2463,10 +2463,15 @@
if(dx*dx+dy*dy>1)
k++;
- /*always keep last point*/
+ /*try to keep last point*/
point[k].x = MS_MAP2IMAGE_X_IC_DBL(point[j].x, extent.minx, inv_cs);
point[k].y = MS_MAP2IMAGE_Y_IC_DBL(point[j].y, extent.maxy, inv_cs);
- shape->line[i].numpoints=k+1;
+ /*discard last point if equal to the one before it*/
+ if(point[k].x!=point[k-1].x || point[k].y!=point[k-1].y) {
+ shape->line[i].numpoints=k+1;
+ } else {
+ shape->line[i].numpoints=k;
else if(shape->type == MS_SHAPE_POLYGON) {
More information about the mapserver-commits
