[mapserver-commits] r7957 - branches/branch-5-2/mapserver
svn at osgeo.org
svn at osgeo.org
Sat Oct 4 11:45:36 EDT 2008
Author: tbonfort
Date: 2008-10-04 11:45:36 -0400 (Sat, 04 Oct 2008)
New Revision: 7957
branches/branch-5-2/mapserver/HISTORY.TXT
branches/branch-5-2/mapserver/mapagg.cpp
fix a bug with shapes with duplicate end points. was causing NaNs in the angle follow placement code (#2695)
Modified: branches/branch-5-2/mapserver/HISTORY.TXT
--- branches/branch-5-2/mapserver/HISTORY.TXT 2008-10-04 15:37:16 UTC (rev 7956)
+++ branches/branch-5-2/mapserver/HISTORY.TXT 2008-10-04 15:45:36 UTC (rev 7957)
@@ -12,6 +12,8 @@
Current Version (SVN branch-5-2)
+- fix a bug with shapes with duplicate end points. was causing NaNs
+ in the angle follow placement code (#2695)
- memory leak in msInsertLayer, from Ned Horning (#2784)
Modified: branches/branch-5-2/mapserver/mapagg.cpp
--- branches/branch-5-2/mapserver/mapagg.cpp 2008-10-04 15:37:16 UTC (rev 7956)
+++ branches/branch-5-2/mapserver/mapagg.cpp 2008-10-04 15:45:36 UTC (rev 7957)
@@ -2451,10 +2451,13 @@
if(dx*dx+dy*dy>1)
k++;
- /*always keep last point*/
point[k].x = MS_MAP2IMAGE_X_IC_DBL(point[j].x, extent.minx, inv_cs);
point[k].y = MS_MAP2IMAGE_Y_IC_DBL(point[j].y, extent.maxy, inv_cs);
- shape->line[i].numpoints=k+1;
+ if(point[k].x!=point[k-1].x || point[k].y!=point[k-1].y) {
+ shape->line[i].numpoints=k+1;
+ } else {
+ shape->line[i].numpoints=k;
else if(shape->type == MS_SHAPE_POLYGON) {
More information about the mapserver-commits
