[mapserver-commits] r7962 - trunk/msautotest/pymod
Mon Oct 6 15:52:10 EDT 2008
Author: nsavard
Date: 2008-10-06 15:52:10 -0400 (Mon, 06 Oct 2008)
New Revision: 7962
Added:
   trunk/msautotest/pymod/README_MSAUTOTEST_VIEWER
Initial revision.
Added: trunk/msautotest/pymod/README_MSAUTOTEST_VIEWER
--- trunk/msautotest/pymod/README_MSAUTOTEST_VIEWER	                        (rev 0)
+++ trunk/msautotest/pymod/README_MSAUTOTEST_VIEWER	2008-10-06 19:52:10 UTC (rev 7962)
@@ -0,0 +1,17 @@
+msautotest viewer
+The msautotest viewer is a small Web application that is provided to ease
+the test results verification.  All test results that appear in the Web
+page are also in the result directory of each test directory (gdal, misc
+and wxs), so there are all failed tests.
+To use the msautotest viewer,  you need to give Web access to the msautotest
+directory.  For that edit the http_msautotest.conf and copy it to your
+Apache httpd conf directory.
+Edit the configuration to suit your needs.  The gdal_translate tool in
+particular, is needed to convert Geotiff image to PNG image in order to be
+able to see it in the browser.
+You also need to set the path to the python executable in the
+msautotest_viewer.py python script file.
\ No newline at end of file
