[mapserver-commits] r7963 - trunk/msautotest/pymod
Mon Oct 6 15:52:47 EDT 2008
Author: nsavard
Date: 2008-10-06 15:52:47 -0400 (Mon, 06 Oct 2008)
New Revision: 7963
Added:
   trunk/msautotest/pymod/config.cfg
Initial revision.
Added: trunk/msautotest/pymod/config.cfg
--- trunk/msautotest/pymod/config.cfg	                        (rev 0)
+++ trunk/msautotest/pymod/config.cfg	2008-10-06 19:52:47 UTC (rev 7963)
@@ -0,0 +1,30 @@
+[Logging]
+#Log debug script information.  Possible values are:  True or False
+PythonLogging:  True
+#PythonLoggingFile: c:/tmp/python.log
+PythonLoggingFile: /tmp/python.log
+#When the external image image viewer is opened, specifiy where to log
+#the output and error message from the command line
+#ShellOutputFile:  c:/tmp/msautotest_output.log
+#ShellErrorFile:  c:/tmp/msautotest_error.log
+ShellOutputFile:  /tmp/msautotest_output.log
+ShellErrorFile:  /tmp/msautotest_error.log
+[Applications]
+#Where to write the png images after their conversion from gtiff
+#TmpDir: c:/tmp/
+TmpDir: /tmp/
+#Web URL to access temporary images
+#Edit httpd_msautotest.conf to give access to this directory
+#Default "/tmp"
+TmpWeb: /tmp/
+#External image converter command and options
+#ImageConverterCmd: C:/ms4w/tools/gdal-ogr/gdal_translate %(ImageConverterOptions)s
+ImageConverterCmd: /home/nsavard/fgs-ms5.2.0/bin/gdal_translate %(ImageConverterOptions)s
+ImageConverterOptions: -of
+[Report]
+ResultsPerPage:  5
\ No newline at end of file
