[mapserver-commits] r8950 - trunk/mapserver/mapscript/python
svn at osgeo.org
svn at osgeo.org
Thu Apr 23 13:24:52 EDT 2009
Author: hobu
Date: 2009-04-23 13:24:52 -0400 (Thu, 23 Apr 2009)
New Revision: 8950
trunk/mapserver/mapscript/python/setup.py
fall back to mapscriptvars in the case of windows
Modified: trunk/mapserver/mapscript/python/setup.py
--- trunk/mapserver/mapscript/python/setup.py 2009-04-23 15:21:00 UTC (rev 8949)
+++ trunk/mapserver/mapscript/python/setup.py 2009-04-23 17:24:52 UTC (rev 8950)
@@ -50,7 +50,44 @@
#extra_compile_args = ['-g', '-arch', 'i386', '-isysroot','/']
-def get_config(option, config='../../mapserver-config'):
+def read_mapscriptvars():
+ # Should be created by the mapserver build process.
+ mapscriptvars = "../../mapscriptvars"
+ try:
+ fp = open(mapscriptvars, "r")
+ except IOError, e:
+ raise IOError, '%s. %s' % (e, "Has MapServer been made?")
+ output = {}
+ install_dir = fp.readline().strip()
+ defines = fp.readline().strip()
+ includes = fp.readline().strip()
+ libraries = fp.readline().strip()
+ extra_libs = fp.readline().strip()
+ version = fp.readline().strip()
+ if version:
+ version = version.split()[2]
+ version = version.replace('#','')
+ output['version'] = version
+ output['libs'] = libraries
+ output['extra_libs'] = extra_libs
+ output['defines'] = defines
+ output['includes'] = includes
+ fp.close()
+ return output
+def get_config(option, config='mapserver-config'):
+ v = read_mapscriptvars()
+ if sys.platform == 'win32':
+ return v[option]
command = config + " --%s" % option
p = popen2.popen3(command)
r = p[0].readline().strip()
@@ -61,7 +98,7 @@
class ms_ext(build_ext):
- MAPSERVER_CONFIG = '../../mapserver-config'
+ MAPSERVER_CONFIG = 'mapserver-config'
user_options = build_ext.user_options[:]
user_options.extend([
('mapserver-config=', None,
@@ -147,7 +184,8 @@
extra_link_args = extra_link_args)
-mapserver_version = get_config('version')
+mapserver_version = get_config('version', config='../../mapserver-config')
author = "Steve Lime"
author_email = "steve.lime at dnr.state.mn.us"
maintainer = "Howard Butler"
More information about the mapserver-commits
