[mapserver-commits] r8951 - trunk/mapserver/mapscript/python
svn at osgeo.org
svn at osgeo.org
Thu Apr 23 14:04:34 EDT 2009
Author: hobu
Date: 2009-04-23 14:04:33 -0400 (Thu, 23 Apr 2009)
New Revision: 8951
trunk/mapserver/mapscript/python/setup.py
seem to be working in windows now
Modified: trunk/mapserver/mapscript/python/setup.py
--- trunk/mapserver/mapscript/python/setup.py 2009-04-23 17:24:52 UTC (rev 8950)
+++ trunk/mapserver/mapscript/python/setup.py 2009-04-23 18:04:33 UTC (rev 8951)
@@ -79,6 +79,8 @@
output['defines'] = defines
output['includes'] = includes
fp.close()
+ # print output['libs']
+ # sys.exit(1)
return output
def get_config(option, config='mapserver-config'):
@@ -145,7 +147,7 @@
dir, lib = os.path.split(x)
libraries.append( lib[:-4] )
if len(dir) > 0:
- lib_dirs.append( dir )
+ self.library_dirs.append( dir )
elif x[-2:] == '.a':
extra_link_args.append(x)
elif x[:10] == '-framework':
@@ -157,23 +159,19 @@
# don't forget to add mapserver lib
self.libraries = unique(libraries) + ['mapserver',]
- if self.libraries is None:
- if self.get_compiler() == 'msvc':
- libraries.remove('mapserver')
- libraries.append('mapserver_i')
- libraries.append('gd')
- self.libraries = libraries
+ if self.get_compiler() == 'msvc':
+ for lib in self.libraries:
+ if lib == 'mapserver':
+ print lib
+ self.libraries.remove(lib)
+ self.libraries.append('mapserver_i')
+ self.libraries.append('gd')
+ self.libraries = unique(self.libraries)
build_ext.finalize_options(self)
- return True
- try:
- self.dir = os.path.abspath('..')
- self.library_dirs.append(self.dir)
- self.include_dirs.append(self.dir)
- except:
- print 'Could not run mapserver-config!!!!'
+ self.dir = os.path.abspath('../..')
+ self.library_dirs.append(self.dir)
+ self.include_dirs.append(self.dir)
@@ -200,7 +198,7 @@
readme = file('README','rb').read()
if not os.path.exists('mapscript_wrap.c') :
- os.system('swig -python -shadow -modern %s -o mapscript_wrap.c ../mapscript.i' % " ".get_config('defines'))
+ os.system('swig -python -shadow -modern %s -o mapscript_wrap.c ../mapscript.i' % get_config('defines'))
classifiers = [
'Development Status :: 4 - Beta',
More information about the mapserver-commits
