[mapserver-commits] r8561 - trunk/mapserver
Mon Feb 16 23:04:33 EST 2009
Author: assefa
Date: 2009-02-16 23:04:32 -0500 (Mon, 16 Feb 2009)
New Revision: 8561
   trunk/mapserver/mapogcsld.c
Initial SLD 1.1.0 support for line, point, polygon, text #473
Modified: trunk/mapserver/mapogcsld.c
--- trunk/mapserver/mapogcsld.c	2009-02-17 04:01:04 UTC (rev 8560)
+++ trunk/mapserver/mapogcsld.c	2009-02-17 04:04:32 UTC (rev 8561)
@@ -411,6 +411,7 @@
     CPLStripXMLNamespace(psRoot, "ogc", 1);
     CPLStripXMLNamespace(psRoot, "sld", 1);
     CPLStripXMLNamespace(psRoot, "gml", 1);
+    CPLStripXMLNamespace(psRoot, "se", 1);
@@ -957,7 +958,7 @@
                               int bNewClass)
     int nClassId = 0;
-    CPLXMLNode *psStroke;
+    CPLXMLNode *psStroke=NULL, *psOffset=NULL;
     int iStyle = 0;
     if (psRoot && psLayer)
@@ -981,6 +982,14 @@
             msSLDParseStroke(psStroke, psLayer->class[nClassId]->styles[iStyle],
                              psLayer->map, 0);
+            /*parse PerpendicularOffset SLD 1.1.10*/
+            psOffset = CPLGetXMLNode(psRoot, "PerpendicularOffset");
+            if (psOffset && psOffset->psChild && psOffset->psChild->pszValue)
+              psLayer->class[nClassId]->styles[iStyle]->offsetx = atoi(psOffset->psChild->pszValue);
+              psLayer->class[nClassId]->styles[iStyle]->offsety = psLayer->class[nClassId]->styles[iStyle]->offsetx;
@@ -1011,9 +1020,13 @@
         /* parse css parameters */
         psCssParam =  CPLGetXMLNode(psStroke, "CssParameter");
+        /*sld 1.1 used SvgParameter*/
+        if (psCssParam == NULL)
+          psCssParam =  CPLGetXMLNode(psStroke, "SvgParameter");
         while (psCssParam && psCssParam->pszValue &&
-               strcasecmp(psCssParam->pszValue, "CssParameter") == 0)
+               (strcasecmp(psCssParam->pszValue, "CssParameter") == 0 ||
+                strcasecmp(psCssParam->pszValue, "SvgParameter") == 0))
             psStrkName = (char*)CPLGetXMLValue(psCssParam, "name", NULL);
@@ -1202,9 +1215,30 @@
     CPLXMLNode *psFill, *psStroke;
     int nClassId=0, iStyle=0;
+    CPLXMLNode *psDisplacement=NULL, *psDisplacementX=NULL, *psDisplacementY=NULL;
+    int nOffsetX=-1, nOffsetY=-1;
+        /*parse displacement for SLD 1.1.0*/
+        psDisplacement = CPLGetXMLNode(psRoot, "Displacement");
+        if (psDisplacement)
+            psDisplacementX = CPLGetXMLNode(psDisplacement, "DisplacementX");
+            psDisplacementY = CPLGetXMLNode(psDisplacement, "DisplacementY");
+            /* psCssParam->psChild->psNext->pszValue) */
+            if (psDisplacementX &&
+                psDisplacementX->psChild &&
+                psDisplacementX->psChild->pszValue &&
+                psDisplacementY &&
+                psDisplacementY->psChild &&
+                psDisplacementY->psChild->pszValue)
+                nOffsetX = atoi(psDisplacementX->psChild->pszValue);
+                nOffsetY = atoi(psDisplacementY->psChild->pszValue);
         psFill =  CPLGetXMLNode(psRoot, "Fill");
         if (psFill)
@@ -1224,6 +1258,12 @@
             msSLDParsePolygonFill(psFill, psLayer->class[nClassId]->styles[iStyle],
                                   psLayer->map);
+            if (nOffsetX > 0 && nOffsetY > 0)
+                psLayer->class[nClassId]->styles[iStyle]->offsetx = nOffsetX;
+                psLayer->class[nClassId]->styles[iStyle]->offsety = nOffsetY;
         /* stroke wich corresponds to the outilne in mapserver */
         /* is drawn after the fill */
@@ -1259,6 +1299,12 @@
                              psLayer->map, 1);
@@ -1285,8 +1331,13 @@
         psStyle->color.blue = 128;
         psCssParam =  CPLGetXMLNode(psFill, "CssParameter");
+          psCssParam =  CPLGetXMLNode(psFill, "SvgParameter");
             psFillName = (char*)CPLGetXMLValue(psCssParam, "name", NULL);
             if (psFillName)
@@ -1351,6 +1402,8 @@
     CPLXMLNode  *psCssParam, *psGraphic, *psExternalGraphic, *psMark, *psSize;
     CPLXMLNode *psWellKnownName, *psStroke, *psFill;
+    CPLXMLNode *psOpacity=NULL, *psRotation=NULL;
     char *psColor=NULL, *psColorName = NULL;
     int nLength = 0;
     char *pszSymbolName = NULL;
@@ -1376,8 +1429,34 @@
             if (psSize && psSize->psChild && psSize->psChild->pszValue)
               psStyle->size = atof(psSize->psChild->pszValue);
             else
-              psStyle->size = 6; /* defualt value */
+              psStyle->size = 6; /* default value */
+            /*SLD 1.1.0 extract opacity, rotation, displacement*/
+            psOpacity = CPLGetXMLNode(psGraphic, "Opacity");
+            if (psOpacity && psOpacity->psChild && psOpacity->psChild->pszValue)
+              psStyle->opacity = (int)(atof(psOpacity->psChild->pszValue) * 100);
+            psRotation = CPLGetXMLNode(psGraphic, "Rotation");
+            if (psRotation && psRotation->psChild && psRotation->psChild->pszValue)
+              psStyle->angle = atof(psRotation->psChild->pszValue);
+            psDisplacement = CPLGetXMLNode(psGraphic, "Displacement");
+                    psStyle->offsetx = atoi(psDisplacementX->psChild->pszValue);
+                    psStyle->offsety = atoi(psDisplacementY->psChild->pszValue);
             /* extract symbol */
             psMark =  CPLGetXMLNode(psGraphic, "Mark");
             if (psMark)
@@ -1423,8 +1502,13 @@
                     if (psFill)
                             psColorName =
@@ -1454,8 +1538,13 @@
                     if (psStroke)
                             psColorName =
@@ -2098,7 +2187,7 @@
                             /* the last parameter is used to set the GAP size in the symbol.
                                It is harcoded to be 2 * the size set for the symbol. This is
                                used when using graphic strokes with line symblizers (symbols
-                               along the line). Set to be negative for ration purpose. */
+                               along the line). Set to be negative for rotation purpose. */
                             psStyle->symbol = msSLDGetGraphicSymbol(map, pszTmpSymbolName, pszURL,
        (int)(-(2 * psStyle->size)));
@@ -2513,7 +2602,7 @@
     if (psRoot && psClass && psLayer)
-        /*set the angle by defulat to auto. the angle can be
+        /*set the angle by default to auto. the angle can be
           modified Label Placement #2806*/
         psClass->label.autoangle = MS_TRUE;
@@ -2588,8 +2677,13 @@
                 if (psFont)
                     psCssParam =  CPLGetXMLNode(psFont, "CssParameter");
+                      psCssParam =  CPLGetXMLNode(psFont, "SvgParameter");
                         pszName = (char*)CPLGetXMLValue(psCssParam, "name", NULL);
                         if (pszName)
@@ -2692,8 +2786,13 @@
                     if (psHaloFill)
                         psCssParam =  CPLGetXMLNode(psHaloFill, "CssParameter");
+                          psCssParam =  CPLGetXMLNode(psHaloFill, "SvgParameter");
                             if (pszName)
@@ -2730,9 +2829,14 @@
                 if (psFill)
                         if (pszName)
@@ -2768,7 +2872,7 @@
 /*                         ParseTextPointPlacement                      */
-/*      point plavament node ifor the text symbolizer.                  */
+/*      point placement node for the text symbolizer.                  */
 void ParseTextPointPlacement(CPLXMLNode *psRoot, classObj *psClass)
@@ -2867,15 +2971,23 @@
 void ParseTextLinePlacement(CPLXMLNode *psRoot, classObj *psClass)
-    CPLXMLNode *psOffset = NULL;
+  CPLXMLNode *psOffset = NULL, *psAligned=NULL;
     if (psRoot && psClass)
         /*if there is a line placement, we will assume that the
-              best setting for mapserver would be for the text to follow
-              the line #2806*/
+          best setting for mapserver would be for the text to follow
+          the line #2806*/
         psClass->label.autofollow = MS_TRUE;
+        /*sld 1.1.0 has a parameter IsAligned. default value is true*/
+        psAligned = CPLGetXMLNode(psRoot, "IsAligned");
+        if (psAligned && psAligned->psChild && psAligned->psChild->pszValue &&
+            strcasecmp(psAligned->psChild->pszValue, "false") == 0)
+            psClass->label.autoangle = MS_FALSE;
+            psClass->label.autofollow = MS_FALSE;
@@ -2883,10 +2995,15 @@
             psClass->label.offsety = atoi(psOffset->psChild->pszValue);
             /*if there is a PerpendicularOffset, we will assume that the
-              best setting for mapserver would be for use angle 0 and the
+              best setting for mapserver would be to use angle=0 and the
               the offset #2806*/
-            psClass->label.autoangle = MS_FALSE;
-            psClass->label.autofollow = MS_FALSE;
+            /* since sld 1.1.0 introduces the IsAligned parameter, only
+               set the angles if the parameter is not set*/
+            if (!psAligned)
