[mapserver-commits] r8562 - trunk/docs/ogc
svn at osgeo.org
svn at osgeo.org
Mon Feb 16 23:05:14 EST 2009
Author: assefa
Date: 2009-02-16 23:05:14 -0500 (Mon, 16 Feb 2009)
New Revision: 8562
trunk/docs/ogc/sld.txt
Initial SLD 1.1.0 support for line, point, polygon, text #473
Modified: trunk/docs/ogc/sld.txt
--- trunk/docs/ogc/sld.txt 2009-02-17 04:04:32 UTC (rev 8561)
+++ trunk/docs/ogc/sld.txt 2009-02-17 04:05:14 UTC (rev 8562)
@@ -95,6 +95,32 @@
</UserStyle>
</NamedLayer>
</StyledLayerDescriptor>
+Veersion 1.1.0 of the same SLD
+.. code-block:: guess
+ <StyledLayerDescriptor version="1.1.0">
+ <NamedLayer>
+ <Name>WorldGen_Outline</Name>
+ <UserStyle>
+ <Name>xxx</Name>
+ <FeatureTypeStyle>
+ <Rule>
+ <LineSymbolizer>
+ <Geometry>
+ <PropertyName>center-line</PropertyName>
+ </Geometry>
+ <Stroke>
+ <SvgParameter name="stroke">#0000ff</SvgParameter>
+ </Stroke>
+ </LineSymbolizer>
+ </Rule>
+ </FeatureTypeStyle>
+ </UserStyle>
+ </NamedLayer>
+ </StyledLayerDescriptor>
When MapServer gets a valid SLD through a request, it parses this SLD to extract
all the styles attached to the NamedLayers, and then it applies these styles to
@@ -248,8 +274,13 @@
Stroke (CssParameter): linejoin and linecap No Not supported in MapServer
Stroke (CssParameter): dasharray Yes
Stroke (CssParameter): dashoffset No
+PerperdicularOffset (only in SLD 1.1.0) Yes Offset values of the style object will be set
+InitialGap(GraphicStroke SLD 1.1.0) No
+Gap (GraphicStroke parameter SLD 1.1.0) No
+Note that SvgParameter instead of CssParameter are required for SLD 1.1.0.
The following are examples of valid requests using the LineSymbolizer:
- simple line: `sld 7a`_ / `full request 7a`_
@@ -269,13 +300,15 @@
**Table 8. PolygonSymbolizer**
-Features Supported Notes
-Geometry No
-Stroke Yes Strokes are the same as for the LineSymbolizer
-Fill Yes Was developed to support symbol fill polygons in addition to solid fill
+Features Supported Notes
+Geometry No
+Stroke Yes Strokes are the same as for the LineSymbolizer
+Fill Yes Was developed to support symbol fill polygons in addition to solid fill
+PerperdicularOffset No SLD 1.1.0 parameter
+Displacement Yes SLD 1.1.0 parameter. Sets offsetx/y in MapServer
A Fill can be a solid fill or be a Graphic Fill, which is either a well-known
Mark symbol (e.g., square, circle, triangle, star, cross, x) or an
@@ -315,9 +348,11 @@
Geometry No
Graphic: Mark symbol Yes Well-known names (square, circle, triangle, star, cross, X) are supported
Graphic: ExternalGraphic Yes Was developed to support symbol fill polygons in addition to solid fill
-Opacity No Not supported in MapServer
+Opacity Yes Support added in Mapserver 5.4
Size Yes
-Rotation No Not supported in MapServer
+Rotation Yes Support added in MapServer 5.4
+Displacement Yes SLD 1.1.0 Paramater. Support added in MapServer 5.4
+AnchorPoint No
Note: refer to the PolygonSymbolizer notes for how the Mark and ExternalGraphic symbols are applied in MapServer.
@@ -350,7 +385,7 @@
Font-style (Italic, ...) Yes
Font-weight Yes
Font-size Yes If true-type fonts are not used, default bitmap sizes are given
-LabelPlacement Yes PointPlacement is supported. LinePlacement is supported for versions >=5.2.1.
+LabelPlacement Yes PointPlacement is supported. LinePlacement is supported for versions >=5.2.1. Only PerperdicularOffset and IsAligned are suported for LinePlacement.
Halo Yes Supported (fill converted to outlinecolor, and radius is converted to outlinewidth. Note that outlinewidth is only available for AGG in >=5.2)
Fill Yes Only solid color is available
@@ -378,7 +413,11 @@
- Angle setting: by default the angle parameter is set to AUTO. For point features,
users can use the PointPlacement to alter the value. For line features, the user can
- add a LinePlacement: If an 'empty' LinePlacement is part of the SLD, the angle will be set to to FOLLOW, If a LinePlacement contains the PerpendicualarOffset parameter, the angle withh be set to 0 and the PerpendicualarOffset will be used to set the offset values in the label object.
+ add a LinePlacement: If an 'empty' LinePlacement is part of the SLD, the angle will be
+ set to FOLLOW, If a LinePlacement contains the PerpendicualarOffset parameter, the
+ angle will be set to 0 and the PerpendicualarOffset will be used to set the offset values
+ in the label object. SLD 1.1.0 introduces the IsAligned parameter for LinePlacement: if
+ this parameter is set to false, the angle will be set to 0.
The following are examples of valid requests using the TextSymbolizer:
More information about the mapserver-commits
