[mapserver-commits] r9114 - trunk/mapserver
Sun Jun 21 14:20:48 EDT 2009
Author: tbonfort
Date: 2009-06-21 14:20:48 -0400 (Sun, 21 Jun 2009)
New Revision: 9114
   trunk/mapserver/mapcairo.c
   trunk/mapserver/mapdraw.c
   trunk/mapserver/maplabel.c
   trunk/mapserver/mapogl.cpp
   trunk/mapserver/mapoutput.c
   trunk/mapserver/maprendering.c
   trunk/mapserver/mapserver.h
   trunk/mapserver/mapsymbol.h
   trunk/mapserver/maputil.c
refactor renderer plugins to follow the layer vtable approach a bit more closely
Modified: trunk/mapserver/mapcairo.c
--- trunk/mapserver/mapcairo.c	2009-06-19 14:00:59 UTC (rev 9113)
+++ trunk/mapserver/mapcairo.c	2009-06-21 18:20:48 UTC (rev 9114)
@@ -26,10 +26,10 @@
  * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
  * DEALINGS IN THE SOFTWARE.
+#include "mapserver.h"
 #ifdef USE_CAIRO
-#include "mapserver.h"
 #include <cairo.h>
 #if defined(_WIN32) && !defined(__CYGWIN__)
 #include <cairo-pdf.h>
@@ -51,6 +51,8 @@
 /* trivial cache container */
 struct facecache;
 typedef struct facecache faceCacheObj;
@@ -749,4 +751,81 @@
 	s->renderer_cache=NULL;
+#endif /*USE_CAIRO*/
+int msPopulateRendererVTableCairoRaster( rendererVTableObj *renderer ) {
+#ifdef USE_CAIRO
+    renderer->supports_imagecache=0;
+    renderer->supports_pixel_buffer=1;
+    renderer->supports_transparent_layers = 1;
+    renderer->startNewLayer = startNewLayerCairo;
+    renderer->closeNewLayer = closeNewLayerCairo;
+    renderer->renderLine=&renderLineCairo;
+    renderer->createImage=&createImageCairo;
+    renderer->saveImage=&saveImageCairo;
+    renderer->getRasterBuffer=&getRasterBufferCairo;
+    renderer->transformShape=&msTransformShapeAGG;
+    renderer->renderPolygon=&renderPolygonCairo;
+    renderer->renderGlyphsLine=&renderGlyphsLineCairo;
+    renderer->renderGlyphs=&renderGlyphsCairo;
+    renderer->freeImage=&freeImageCairo;
+    renderer->renderEllipseSymbol = &renderEllipseSymbolCairo;
+    renderer->renderVectorSymbol = &renderVectorSymbolCairo;
+    renderer->renderTruetypeSymbol = &renderTruetypeSymbolCairo;
+    renderer->renderPixmapSymbol = &renderPixmapSymbolCairo;
+    renderer->mergeRasterBuffer = &mergeRasterBufferCairo;
+    renderer->getTruetypeTextBBox = &getTruetypeTextBBoxCairo;
+    renderer->renderTile = &renderTileCairo;
+    renderer->renderPolygonTiled = &renderPolygonTiledCairo;
+    renderer->freeTile = &freeTileCairo;
+    renderer->freeSymbol = &freeSymbolCairo;
+    return MS_SUCCESS;
+#else
+    msSetError(MS_MISCERR, "Cairo Driver requested but is not built in",
+            "msPopulateRendererVTableCairoRaster()");
+    return MS_FAILURE;
 #endif
+inline int populateRendererVTableCairoVector( rendererVTableObj *renderer ) {
+#ifdef USE_CAIRO
+    renderer->supports_pixel_buffer=0;
+#else
+#endif
+int msPopulateRendererVTableCairoSVG( rendererVTableObj *renderer ) {
+    return populateRendererVTableCairoVector(renderer);
+int msPopulateRendererVTableCairoPDF( rendererVTableObj *renderer ) {
Modified: trunk/mapserver/mapdraw.c
--- trunk/mapserver/mapdraw.c	2009-06-19 14:00:59 UTC (rev 9113)
+++ trunk/mapserver/mapdraw.c	2009-06-21 18:20:48 UTC (rev 9114)
@@ -148,8 +148,8 @@
         return(NULL);
     else if (MS_RENDERER_PLUGIN(map->outputformat)) {
-		renderObj *r = map->outputformat->r;
-		image = r->createImage(map->width, map->height, map->outputformat,&map->imagecolor);
+		rendererVTableObj *renderer = map->outputformat->vtable;
+		image = renderer->createImage(map->width, map->height, map->outputformat,&map->imagecolor);
         if (image == NULL)
             return(NULL);
 		image->format = map->outputformat;
@@ -745,7 +745,7 @@
   else if (MS_RENDERER_PLUGIN(image_draw->format)) {
 		if (layer->opacity > 0 && layer->opacity < 100) {
-			if (!image_draw->format->r->supports_transparent_layers) {
+			if (!image_draw->format->vtable->supports_transparent_layers) {
 				msApplyOutputFormat(&transFormat, image->format, MS_TRUE,
 						MS_NOOVERRIDE,MS_NOOVERRIDE);
 				image_draw = msImageCreate(image->width, image->height,
@@ -756,7 +756,7 @@
 					return (MS_FAILURE);
 			} else {
-				image_draw->format->r->startNewLayer(image_draw,layer->opacity);
+				image_draw->format->vtable->startNewLayer(image_draw,layer->opacity);
@@ -826,16 +826,17 @@
     msApplyOutputFormat( &transFormat, NULL, MS_NOOVERRIDE, MS_NOOVERRIDE, MS_NOOVERRIDE );
   else if( MS_RENDERER_PLUGIN(image_draw->format) && layer->opacity > 0 && layer->opacity < 100 ) {
+	  rendererVTableObj *renderer = image_draw->format->vtable;
+      if (!renderer->supports_transparent_layers) {
           rasterBufferObj rb;
-          image_draw->format->r->getRasterBuffer(image_draw,&rb);
-		  image_draw->format->r->mergeRasterBuffer(image,&rb,layer->opacity*0.01,0,0);
-		  image_draw->format->r->freeImage( image_draw );
+          renderer->getRasterBuffer(image_draw,&rb);
+		  renderer->mergeRasterBuffer(image,&rb,layer->opacity*0.01,0,0);
+		  renderer->freeImage( image_draw );
 		  /* deref and possibly free temporary transparent output format.  */
 	  } else {
-		  image_draw->format->r->closeNewLayer(image_draw,layer->opacity*0.01);
+		  renderer->closeNewLayer(image_draw,layer->opacity*0.01);
 #ifdef USE_AGG
Modified: trunk/mapserver/maplabel.c
--- trunk/mapserver/maplabel.c	2009-06-19 14:00:59 UTC (rev 9113)
+++ trunk/mapserver/maplabel.c	2009-06-21 18:20:48 UTC (rev 9114)
@@ -666,7 +666,7 @@
 int msGetTruetypeTextBBox(imageObj *img, char *font, double size, char *string, rectObj *rect, double **advances) {
 #ifdef USE_GD_FT
 	if(img!=NULL && MS_RENDERER_PLUGIN(img->format)) {
-		img->format->r->getTruetypeTextBBox(img,font,size,string,rect,advances);
+		img->format->vtable->getTruetypeTextBBox(img,font,size,string,rect,advances);
 		//printf("%s: %f %f %f %f\n",string,rect->minx,rect->miny,rect->maxx,rect->maxy);
 		return MS_SUCCESS;
 	} else
Modified: trunk/mapserver/mapogl.cpp
--- trunk/mapserver/mapogl.cpp	2009-06-19 14:00:59 UTC (rev 9113)
+++ trunk/mapserver/mapogl.cpp	2009-06-21 18:20:48 UTC (rev 9114)
@@ -5,10 +5,10 @@
  *      Author: toby
 #ifdef USE_OGL
 #include <assert.h>
 #include "mapoglrenderer.h"
 #include "mapoglcontext.h"
@@ -215,5 +215,40 @@
+#endif /* USE_OGL */
-#endif /* USE_OGL */
+int msPopulateRendererVTableOGL(rendererVTableObj *renderer) {
+#ifdef USE_OGL
+    	renderer->startNewLayer = msStartNewLayerOgl;
+    	renderer->closeNewLayer = msCloseNewLayerOgl;
+        renderer->renderLine=&msDrawLineOgl;
+        renderer->createImage=&msImageCreateOgl;
+        renderer->saveImage=&msSaveImageOgl;
+        renderer->renderPolygon=&msDrawPolygonOgl;
+        renderer->renderGlyphs=&msRenderGlyphsOgl;
+        renderer->renderEllipseSymbol = &msRenderEllipseOgl;
+        renderer->renderVectorSymbol = &msRenderVectorSymbolOgl;
+        renderer->renderPixmapSymbol = &msRenderPixmapOgl;
+        renderer->mergeRasterBuffer = &msMergeImagesOgl;
+        renderer->getTruetypeTextBBox = &msGetTruetypeTextBBoxOgl;
+        renderer->createPixmapSymbolTile = &msCreateTilePixmapOgl;
+        renderer->createVectorSymbolTile = &msCreateTileVectorOgl;
+        renderer->createEllipseSymbolTile = &msCreateTileEllipseOgl;
+        renderer->createTruetypeSymbolTile = &msCreateTileTruetypeOgl;
+        renderer->renderTile = &msRenderTileOgl;
+        renderer->renderPolygonTiled = &msDrawPolygonTiledOgl;
+        renderer->renderLineTiled = &msDrawLineTiledOgl;
+        renderer->freeTile = &msFreeTileOgl;
+        renderer->freeSymbol = &msFreeSymbolOgl;
+        renderer->freeImage=&msFreeImageOgl;
+    #else
+        msSetError(MS_MISCERR,"OGL driver requested but it is not compiled in this release",
+                "msPopulateRendererVTableOGL()");
+#endif
Modified: trunk/mapserver/mapoutput.c
--- trunk/mapserver/mapoutput.c	2009-06-19 14:00:59 UTC (rev 9113)
+++ trunk/mapserver/mapoutput.c	2009-06-21 18:20:48 UTC (rev 9114)
@@ -228,7 +228,6 @@
         format->imagemode = MS_IMAGEMODE_RGB;
         format->extension = strdup("png");
         format->renderer = MS_RENDER_WITH_CAIRO_RASTER;
-        format->r = msCreateRenderer(MS_RENDER_WITH_CAIRO_RASTER);
     if( strcasecmp(driver,"CAIRO/JPEG") == 0 )
@@ -237,7 +236,6 @@
         format->extension = strdup("jpg");
     if( strcasecmp(driver,"CAIRO/PDF") == 0 )
@@ -245,8 +243,7 @@
 		format->mimetype = strdup("application/x-pdf");
 		format->extension = strdup("pdf");
-		format->renderer = MS_RENDER_WITH_CAIRO_VECTOR;
-		format->r = msCreateRenderer(MS_RENDER_WITH_CAIRO_VECTOR);
+		format->renderer = MS_RENDER_WITH_CAIRO_PDF;
     if( strcasecmp(driver,"CAIRO/SVG") == 0 )
@@ -254,8 +251,7 @@
 		format->mimetype = strdup("image/svg+xml");
 		format->extension = strdup("svg");
+		format->renderer = MS_RENDER_WITH_CAIRO_SVG;
@@ -269,7 +265,6 @@
         format->renderer = MS_RENDER_WITH_OGL;
-        format->r = msCreateRenderer(MS_RENDER_WITH_OGL);
 #endif
@@ -339,7 +334,10 @@
     if( format != NULL )
       format->inmapfile = MS_FALSE;
+    if( format!= NULL && MS_RENDERER_PLUGIN(format) ) {
+        msInitializeRendererVTable(format);
     return format;
@@ -437,7 +435,8 @@
     msFree( format->driver );
     msFree( format->extension );
     msFreeCharArray( format->formatoptions, format->numformatoptions );
-    msFree( format->r);
+    /* msFreeRendererVTable( format->vtable ); */
+    msFree( format->vtable );
     msFree( format );
@@ -468,7 +467,7 @@
     format->name = strdup(name);
     format->driver = strdup(driver);
     format->refcount = 0;
-    format->r = NULL;
+    format->vtable = NULL;
     format->imagemode = MS_IMAGEMODE_PC256;
@@ -752,7 +751,6 @@
     dst->imagemode = src->imagemode;
     dst->renderer = src->renderer;
-    dst->r = src->r;
     dst->transparent = src->transparent;
     dst->bands = src->bands;
@@ -766,6 +764,8 @@
     dst->inmapfile = src->inmapfile;
+    msInitializeRendererVTable(dst);
     return dst;
@@ -1002,93 +1002,30 @@
     return result;
-renderObj* msCreateRenderer(int type) {
-    renderObj *r = malloc(sizeof(renderObj));
-    switch(type) {
-#ifdef USE_CAIRO
-    case MS_RENDER_WITH_CAIRO_RASTER:
-        r->supports_imagecache=0;
-        r->supports_pixel_buffer=1;
-        r->supports_transparent_layers = 1;
-        r->startNewLayer = startNewLayerCairo;
-        r->closeNewLayer = closeNewLayerCairo;
-        r->renderLine=&renderLineCairo;
-        r->createImage=&createImageCairo;
-        r->saveImage=&saveImageCairo;
-        r->getRasterBuffer=&getRasterBufferCairo;
-        r->transformShape=&msTransformShapeAGG;
-        r->renderPolygon=&renderPolygonCairo;
-        r->renderGlyphsLine=&renderGlyphsLineCairo;
-        r->renderGlyphs=&renderGlyphsCairo;
-        r->freeImage=&freeImageCairo;
-        r->renderEllipseSymbol = &renderEllipseSymbolCairo;
-        r->renderVectorSymbol = &renderVectorSymbolCairo;
-        r->renderTruetypeSymbol = &renderTruetypeSymbolCairo;
-        r->renderPixmapSymbol = &renderPixmapSymbolCairo;
-        r->mergeRasterBuffer = &mergeRasterBufferCairo;
-        r->getTruetypeTextBBox = &getTruetypeTextBBoxCairo;
-        r->renderTile = &renderTileCairo;
-        r->renderPolygonTiled = &renderPolygonTiledCairo;
-        r->freeTile = &freeTileCairo;
-        r->freeSymbol = &freeSymbolCairo;
-        return r;
-    case MS_RENDER_WITH_CAIRO_VECTOR:
-        r->supports_pixel_buffer=0;
-        return r;
-#endif
-#ifdef USE_OGL
-    case MS_RENDER_WITH_OGL:
-    	r->startNewLayer = msStartNewLayerOgl;
-    	r->closeNewLayer = msCloseNewLayerOgl;
-        r->renderLine=&msDrawLineOgl;
-        r->createImage=&msImageCreateOgl;
-        r->saveImage=&msSaveImageOgl;
-        r->renderPolygon=&msDrawPolygonOgl;
-        r->renderGlyphs=&msRenderGlyphsOgl;
-        r->renderEllipseSymbol = &msRenderEllipseOgl;
-        r->renderVectorSymbol = &msRenderVectorSymbolOgl;
-        r->renderPixmapSymbol = &msRenderPixmapOgl;
-        r->mergeRasterBuffer = &msMergeImagesOgl;
-        r->getTruetypeTextBBox = &msGetTruetypeTextBBoxOgl;
-        r->createPixmapSymbolTile = &msCreateTilePixmapOgl;
-        r->createVectorSymbolTile = &msCreateTileVectorOgl;
-        r->createEllipseSymbolTile = &msCreateTileEllipseOgl;
-        r->createTruetypeSymbolTile = &msCreateTileTruetypeOgl;
-        r->renderTile = &msRenderTileOgl;
-        r->renderPolygonTiled = &msDrawPolygonTiledOgl;
-        r->renderLineTiled = &msDrawLineTiledOgl;
-        r->freeTile = &msFreeTileOgl;
-        r->freeSymbol = &msFreeSymbolOgl;
-        r->freeImage=&msFreeImageOgl;
-        return r;
-#endif
-    default:
-        return NULL;
+int msInitializeRendererVTable(outputFormatObj *format) {
+    assert(format);
+    if(format->vtable) {
+        /* TODO?: clean up caches before switch
+        msFreeRendererVTable(format->vtable); */
+        msFree(format->vtable);
+    format->vtable = (rendererVTableObj*)malloc(sizeof(rendererVTableObj));
+    switch(format->renderer) {
+        case MS_RENDER_WITH_CAIRO_RASTER:
+            return msPopulateRendererVTableCairoRaster(format->vtable);
+        case MS_RENDER_WITH_CAIRO_PDF:
+            return msPopulateRendererVTableCairoPDF(format->vtable);
+        case MS_RENDER_WITH_CAIRO_SVG:
+            return msPopulateRendererVTableCairoSVG(format->vtable);
+        case MS_RENDER_WITH_OGL:
+            return msPopulateRendererVTableOGL(format->vtable);
+        default:
+            msSetError(MS_MISCERR, "unsupported RendererVtable renderer %d",
+                    "msInitializeRendererVTable()",format->renderer);
+    /* this code should never be executed */
Modified: trunk/mapserver/maprendering.c
--- trunk/mapserver/maprendering.c	2009-06-19 14:00:59 UTC (rev 9113)
+++ trunk/mapserver/maprendering.c	2009-06-21 18:20:48 UTC (rev 9114)
@@ -169,7 +169,7 @@
         while(cachep->next && cachep->next->next) cachep = cachep->next;
         /*free the last tile's data*/
-        img->format->r->freeTile(cachep->next->data);
+        img->format->vtable->freeTile(cachep->next->data);
         /*reuse the last tile object*/
             /* make the cache point to the start of the list*/
@@ -201,7 +201,7 @@
 tileCacheObj *getTile(imageObj *img, symbolObj *symbol,  symbolStyleObj *s, int width, int height) {
 	tileCacheObj *tile;
-	renderObj *r = img->format->r;
+	rendererVTableObj *renderer = img->format->vtable;
     if(width==-1 || height == -1) {
         width=height=MS_MAX(symbol->sizex,symbol->sizey);
@@ -214,19 +214,19 @@
         p_y = height/2.0;
         format.driver = img->format->driver;
         format.imagemode = MS_IMAGEMODE_RGBA;
-        tileimg = r->createImage(width,height,&format,NULL);
+        tileimg = renderer->createImage(width,height,&format,NULL);
         switch(symbol->type) {
             case (MS_SYMBOL_TRUETYPE):
-                r->renderTruetypeSymbol(tileimg, p_x, p_y, symbol, s);
+                renderer->renderTruetypeSymbol(tileimg, p_x, p_y, symbol, s);
                 break;
             case (MS_SYMBOL_PIXMAP):
-                r->renderPixmapSymbol(tileimg, p_x, p_y, symbol, s);
+                renderer->renderPixmapSymbol(tileimg, p_x, p_y, symbol, s);
                 break;
             case (MS_SYMBOL_ELLIPSE):
-                r->renderEllipseSymbol(tileimg, p_x, p_y,symbol, s);
+                renderer->renderEllipseSymbol(tileimg, p_x, p_y,symbol, s);
                 break;
             case (MS_SYMBOL_VECTOR):
-                r->renderVectorSymbol(tileimg, p_x, p_y, symbol, s);
+                renderer->renderVectorSymbol(tileimg, p_x, p_y, symbol, s);
                 break;
             default:
                 break;
@@ -238,7 +238,7 @@
 void msImagePolylineMarkers(imageObj *image, shapeObj *p, symbolObj *symbol,
         symbolStyleObj *style, double spacing, int auto_angle) {
-    renderObj *r = image->format->r;
+    rendererVTableObj *renderer = image->format->vtable;
     int i,j;
     pointObj point;
     double original_rotation = style->rotation;
@@ -247,7 +247,7 @@
         symbol_width = MS_MAX(1,symbol->sizex*style->scale);
     else {
         rectObj rect;
-        r->getTruetypeTextBBox(image,symbol->full_font_path,style->scale,
+        renderer->getTruetypeTextBBox(image,symbol->full_font_path,style->scale,
                 symbol->character,&rect,NULL);
         symbol_width=rect.maxx-rect.minx;
@@ -280,16 +280,16 @@
                 point.y = p->line[i].point[j - 1].y + current_length * ry;
                 switch (symbol->type) {
                     case MS_SYMBOL_PIXMAP:
-                        r->renderPixmapSymbol(image, point.x, point.y, symbol, style);
+                        renderer->renderPixmapSymbol(image, point.x, point.y, symbol, style);
                         break;
                     case MS_SYMBOL_ELLIPSE:
-                        r->renderEllipseSymbol(image, point.x, point.y, symbol, style);
+                        renderer->renderEllipseSymbol(image, point.x, point.y, symbol, style);
                         break;
                     case MS_SYMBOL_VECTOR:
-                        r->renderVectorSymbol(image, point.x, point.y, symbol, style);
+                        renderer->renderVectorSymbol(image, point.x, point.y, symbol, style);
                         break;
                     case MS_SYMBOL_TRUETYPE:
-                        r->renderTruetypeSymbol(image, point.x, point.y, symbol, style);
+                        renderer->renderTruetypeSymbol(image, point.x, point.y, symbol, style);
                         break;
                 current_length += symbol_width + spacing;
@@ -341,16 +341,16 @@
                     point.y = p->line[i].point[j - 1].y + offset * ry;
                             break;
                             break;
                             break;
                             break;
                     break;
@@ -401,7 +401,7 @@
     if (image)
 		if (MS_RENDERER_PLUGIN(image->format)) {
 			symbolObj *symbol;
 			shapeObj *offsetLine = p;
             int i;
@@ -415,7 +415,7 @@
 			symbol = symbolset->symbol[style->symbol];
             /* store a reference to the renderer to be used for freeing */
-            symbol->renderer = r;
+            symbol->renderer = renderer;
 			width = style->width * scalefactor;
             width = MS_MIN(width,style->maxwidth);
@@ -447,7 +447,7 @@
                 s.color.alpha = MS_NINT(style->opacity * 2.55);
-                r->renderLine(image,offsetLine,&s);
+                renderer->renderLine(image,offsetLine,&s);
 			else {
                 symbolStyleObj s;
@@ -536,11 +536,11 @@
     if (image)
         	shapeObj *offsetPolygon = NULL;
         	symbolObj *symbol = symbolset->symbol[style->symbol];
             if (style->offsetx != 0 || style->offsety != 0) {
 				if(style->offsety==-99)
@@ -554,7 +554,7 @@
              * also draws an optional outline */
             if(style->symbol == 0 || symbol->type == MS_SYMBOL_SIMPLE) {
                 style->color.alpha = MS_NINT(style->opacity*2.55);
-                r->renderPolygon(image,offsetPolygon,&style->color);
+                renderer->renderPolygon(image,offsetPolygon,&style->color);
                 if(MS_VALID_COLOR(style->outlinecolor)) {
                     strokeStyleObj s;
                     MS_COPYCOLOR(&s.color,&style->outlinecolor);
@@ -562,7 +562,7 @@
                     s.width = (style->width == 0)?scalefactor:style->width*scalefactor;
                     s.color.alpha = style->color.alpha;
-                    r->renderLine(image,offsetPolygon,&s);
+                    renderer->renderLine(image,offsetPolygon,&s);
                 goto cleanup; /*finished plain polygon*/
@@ -571,7 +571,7 @@
                 colorObj red;
                 MS_INIT_COLOR(red,255,0,0);
                 red.alpha=255;
-                r->renderPolygon(image,offsetPolygon,&red);
+                renderer->renderPolygon(image,offsetPolygon,&red);
 #if 0
@@ -670,12 +670,12 @@
    if (image)
        if(MS_RENDERER_PLUGIN(image->format)) {
             symbolStyleObj s;
        	    double p_x,p_y;
             computeSymbolStyle(&s,style,symbol,scalefactor);
             if (!MS_VALID_COLOR(s.color) && !MS_VALID_COLOR(s.outlinecolor) && symbol->type != MS_SYMBOL_PIXMAP)
@@ -697,10 +697,10 @@
             p_x = p->x + style->offsetx * scalefactor;
             p_y = p->y + style->offsety * scalefactor;
-			if(r->supports_imagecache) {
+			if(renderer->supports_imagecache) {
 				tileCacheObj *tile = getTile(image, symbol, &s, -1, -1);
 				if(tile!=NULL)
-				    r->renderTile(image, (imageObj*)tile->data, p_x, p_y);
+				    renderer->renderTile(image, (imageObj*)tile->data, p_x, p_y);
 				return;
@@ -710,20 +710,20 @@
 						symbol->font));
                 if(!symbol->full_font_path)
 					return;
-                r->renderTruetypeSymbol(image, p_x, p_y, symbol, &s);
+                renderer->renderTruetypeSymbol(image, p_x, p_y, symbol, &s);
 				break;
 			case (MS_SYMBOL_PIXMAP): {
-				r->renderPixmapSymbol(image,p_x,p_y,symbol,&s);
+				renderer->renderPixmapSymbol(image,p_x,p_y,symbol,&s);
 				break;
 			case (MS_SYMBOL_ELLIPSE): {
-				r->renderEllipseSymbol(image, p_x, p_y,symbol, &s);
+				renderer->renderEllipseSymbol(image, p_x, p_y,symbol, &s);
 				break;
 			case (MS_SYMBOL_VECTOR): {
-				r->renderVectorSymbol(image, p_x, p_y, symbol, &s);
+				renderer->renderVectorSymbol(image, p_x, p_y, symbol, &s);
 				break;
 			default:
@@ -806,7 +806,7 @@
         labelStyleObj s;
  	if (image) {
             double x, y;
 			if (!string || !strlen(string))
 				return (0); // not errors, just don't want to do anything
@@ -816,7 +816,7 @@
 			x = labelPnt.x;
 			y = labelPnt.y;
 			if (label->type == MS_TRUETYPE) {
-				r->renderGlyphs(image,x,y,&s,string);			}
+				renderer->renderGlyphs(image,x,y,&s,string);			}
 	else if( MS_RENDERER_GD(image->format) )
       nReturnVal = msDrawTextGD(image->img.gd, labelPnt, string, label, fontset, scalefactor);
@@ -846,7 +846,7 @@
     int nReturnVal = -1;
     if(image) {
             labelStyleObj s;
@@ -854,7 +854,7 @@
             computeLabelStyle(&s,label,fontset,scalefactor);
-                r->renderGlyphsLine(image,labelpath,&s,string);
+                renderer->renderGlyphsLine(image,labelpath,&s,string);
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h	2009-06-19 14:00:59 UTC (rev 9113)
+++ trunk/mapserver/mapserver.h	2009-06-21 18:20:48 UTC (rev 9114)
@@ -89,9 +89,9 @@
 #endif
 /*forward declaration of rendering object*/
-struct renderer;
+struct rendererVTable;
 struct tilecache;
-typedef struct renderer renderObj;
+typedef struct rendererVTable rendererVTableObj;
 typedef struct tilecache tileCacheObj;
@@ -304,7 +304,7 @@
 #define MS_DRIVER_PDF(format) (strncasecmp((format)->driver,"pdf",3)==0)
 #define MS_DRIVER_IMAGEMAP(format)  (strncasecmp((format)->driver,"imagemap",8)==0)
 #define MS_DRIVER_SVG(format) (strncasecmp((format)->driver,"svg",3)==0)
-#define MS_DRIVER_AGG(format) (strncasecmp((format)->driver,"agg/",3)==0)
+#define MS_DRIVER_AGG(format) (strncasecmp((format)->driver,"agg/",4)==0)
 #define MS_DRIVER_CAIRO(format) (strncasecmp((format)->driver,"cairo/",6)==0)
 #define MS_DRIVER_OGL(format) (strncasecmp((format)->driver,"ogl/",4)==0)
 #define MS_DRIVER_TEMPLATE(format) (strncasecmp((format)->driver,"template",8)==0)
@@ -318,8 +318,9 @@
 #define MS_RENDER_WITH_AGG      7
 #define MS_RENDER_WITH_TEMPLATE 8 /* query results only */
 #define MS_RENDER_WITH_CAIRO_RASTER   9
-#define MS_RENDER_WITH_CAIRO_VECTOR 10
-#define MS_RENDER_WITH_OGL      11
+#define MS_RENDER_WITH_CAIRO_PDF 10
+#define MS_RENDER_WITH_CAIRO_SVG 11
+#define MS_RENDER_WITH_OGL      12
 #define MS_RENDERER_GD(format)  ((format)->renderer == MS_RENDER_WITH_GD)
 #define MS_RENDERER_SWF(format) ((format)->renderer == MS_RENDER_WITH_SWF)
@@ -557,7 +558,7 @@
     char **formatoptions;
     int  refcount;
     int inmapfile; /* boolean value for writing */
-    renderObj *r;
+    rendererVTableObj *vtable;
 } outputFormatObj;
 /* The following is used for "don't care" values in transparent, interlace and
@@ -2471,101 +2472,13 @@
 void msFreeRasterBuffer(rasterBufferObj *b);
 #endif /* SWIG */
-/*      Prototypes for functions in mapogl.cpp                          */
-#ifdef USE_OGL
 #ifndef SWIG
-void msDrawLineOgl(imageObj *img, shapeObj *p, colorObj *c, double width, int patternlength, double* pattern);
-imageObj* msImageCreateOgl(int width, int height, outputFormatObj *format, colorObj* bg);
-int msSaveImageOgl(imageObj *img, char *filename, outputFormatObj *format);
-void msDrawPolygonOgl(imageObj *img, shapeObj *p,colorObj *c, colorObj *oc, double outlineWidth);
-void msDrawPolygonTiledOgl(imageObj *img, shapeObj *p, colorObj *oc, double outlineWidth, void *tile);
-void msDrawLineTiledOgl(imageObj *img, shapeObj *p, void* tile);
-void msRenderGlyphsOgl(imageObj *img,double x, double y, colorObj *color, colorObj *outlinecolor,
-            double size, char *font, char *thechars, double angle,
-            colorObj *shadowcolor, double shdx, double shdy,
-            int outlinewidth);
-void msRenderEllipseOgl(imageObj *image, double x, double y,
-    		double width, double height, double angle,
-    		colorObj *color, colorObj *outlinecolor,
-    		double outlinewidth);
-void msRenderVectorSymbolOgl(imageObj *img, double x, double y, symbolObj *symbol,
-		double scale, double angle, colorObj *c, colorObj *oc, double ow);
-void msRenderPixmapOgl(imageObj *img, double x, double y,
-        		symbolObj *symbol,
-        		double scale, double angle);
-void msMergeImagesOgl(imageObj *dest, imageObj *overlay, int opacity,
-		int dstX, int dstY);
-void* msCreateTileVectorOgl(symbolObj *symbol, double scale, double angle,
-    		colorObj *color,
-    		colorObj *backgroundcolor,
-    		colorObj *outlinecolor, double outlinewidth);
-void* msCreateTileEllipseOgl(double width, double height, double angle,
-			colorObj *color,
+MS_DLL_EXPORT int msInitializeRendererVTable(outputFormatObj *outputformat);
+MS_DLL_EXPORT int msPopulateRendererVTableCairoRaster( rendererVTableObj *renderer );
+MS_DLL_EXPORT int msPopulateRendererVTableCairoSVG( rendererVTableObj *renderer );
+MS_DLL_EXPORT int msPopulateRendererVTableCairoPDF( rendererVTableObj *renderer );
+MS_DLL_EXPORT int msPopulateRendererVTableOGL( rendererVTableObj *renderer );
-void* msCreateTilePixmapOgl(symbolObj *symbol, double scale, double angle, colorObj *bc);
-void* msCreateTileTruetypeOgl(imageObj *img, char *text, char *font,
-	double size, double angle, colorObj *c, colorObj *bc, colorObj *oc,
-	double ow);
-void msRenderTileOgl(imageObj *img, void *tile, double x, double y, double angle);
-int msGetTruetypeTextBBoxOgl(imageObj *img,char *font, double size, char *string,
-    		rectObj *rect, double **advances);
-void msFreeImageOgl(imageObj *image);
-void msFreeTileOgl(void *tile);
-void msStartNewLayerOgl(imageObj *img, double opacity);
-void msCloseNewLayerOgl(imageObj *img, double opacity);
-void msFreeSymbolOgl(symbolObj *s);
-#endif /* SWIG */
-/*      prototypes for functions in mapcairo.c                        */
-#ifdef USE_CAIRO
-#ifndef SWIG
-	void renderLineCairo(imageObj *img, shapeObj *p, strokeStyleObj *s);
-    imageObj* createImageCairo(int width, int height, outputFormatObj *format, colorObj* bg);
-    void getRasterBufferCairo(imageObj *img,rasterBufferObj *rb);
-    int saveImageCairo(imageObj *img, FILE *fp, outputFormatObj *format);
-    void renderPolygonCairo(imageObj *img, shapeObj *p,colorObj *c);
-    void renderPolygonTiledCairo(imageObj *img, shapeObj *p, imageObj *tile);
-    void renderGlyphsCairo(imageObj *img,double x, double y, labelStyleObj *s, char *text);
-    void renderGlyphsLineCairo(imageObj *img,labelPathObj *labelpath,labelStyleObj *style, char *text);
-    void renderEllipseSymbolCairo(imageObj *image, double x, double y, symbolObj *symbol, symbolStyleObj *s);
-    void renderVectorSymbolCairo(imageObj *img, double x, double y, symbolObj *symbol, symbolStyleObj *s);
-    void renderPixmapSymbolCairo(imageObj *img, double x, double y,symbolObj *symbol, symbolStyleObj *s);
-    void renderTruetypeSymbolCairo(imageObj *img, double x, double y, symbolObj *symbol, symbolStyleObj *style);
-    void mergeRasterBufferCairo(imageObj *img, rasterBufferObj *rb, double opacity, int dstX, int dstY);
-    void renderTileCairo(imageObj *img, imageObj *tile, double x, double y);
-    int getTruetypeTextBBoxCairo(imageObj *img,char *font, double size, char *string,
-    void freeImageCairo(imageObj *image);
-    void freeTileCairo(imageObj *tile);
-    void startNewLayerCairo(imageObj *img, double opacity);
-    void closeNewLayerCairo(imageObj *img, double opacity);
-    void freeSymbolCairo(symbolObj *s);
-#endif /* SWIG */
-#endif
-/*      end of prototypes for functions in mapcairo.c                 */
-#ifndef SWIG
-renderObj* msCreateRenderer(int type);
 //allocate 50k for starters
 #define MS_DEFAULT_BUFFER_ALLOC 50000
@@ -2587,8 +2500,7 @@
 MS_DLL_EXPORT  inline void msBufferFree(bufferObj *buffer);
 MS_DLL_EXPORT  inline void msBufferAppend(bufferObj *buffer, void *data, size_t length);
-struct renderer{
-	//void *renderer_data;
+struct rendererVTable {
 	int supports_transparent_layers;
     int supports_pixel_buffer;
 	int supports_imagecache;
Modified: trunk/mapserver/mapsymbol.h
--- trunk/mapserver/mapsymbol.h	2009-06-19 14:00:59 UTC (rev 9113)
+++ trunk/mapserver/mapsymbol.h	2009-06-21 18:20:48 UTC (rev 9114)
@@ -112,7 +112,7 @@
 #ifndef SWIG
   gdImagePtr img;
   void *renderer_cache; /* Renderer storage */
-  renderObj *renderer;
+  rendererVTableObj *renderer;
   rasterBufferObj *pixmap_buffer;
   char *full_font_path;
 #endif /* SWIG */
Modified: trunk/mapserver/maputil.c
--- trunk/mapserver/maputil.c	2009-06-19 14:00:59 UTC (rev 9113)
+++ trunk/mapserver/maputil.c	2009-06-21 18:20:48 UTC (rev 9114)
@@ -653,7 +653,7 @@
     if (img)
         if (MS_RENDERER_PLUGIN(img->format)) {
             FILE *stream;
             if(filename)
                 stream = fopen(msBuildPath(szPath, map->mappath, filename),"wb");
@@ -664,13 +664,13 @@
             if(!stream)
                 return MS_FAILURE;
-            if(r->supports_pixel_buffer) {
+            if(renderer->supports_pixel_buffer) {
                 rasterBufferObj data;
-                r->getRasterBuffer(img,&data);
+                renderer->getRasterBuffer(img,&data);
                 msSaveRasterBuffer(&data,stream,img->format );
             } else {
-                r->saveImage(img, stream, img->format);
+                renderer->saveImage(img, stream, img->format);
             fclose(stream);
             return MS_SUCCESS;
@@ -773,11 +773,11 @@
     *size_ptr = 0;
     if( MS_RENDERER_PLUGIN(image->format)){
             bufferObj buffer;
             msBufferInit(&buffer);
-            r->getRasterBuffer(image,&data);
+            renderer->getRasterBuffer(image,&data);
             msSaveRasterBufferToBuffer(&data,&buffer,format);
             return buffer.data;
             //don't free the bufferObj as we don't own the bytes anymore
@@ -809,18 +809,18 @@
     if (image)
                 tileCacheObj *next,*cur = image->tilecache;
                 while(cur) {
-                    r->freeTile(cur->data);
+                    renderer->freeTile(cur->data);
                     next = cur->next;
                     free(cur);
                     cur = next;
                 image->ntiles = 0;
-        	image->format->r->freeImage(image);
+        	renderer->freeImage(image);
         else if( MS_RENDERER_GD(image->format) ) {
             if( image->img.gd != NULL )
@@ -1376,7 +1376,7 @@
         if( image != NULL && map) msImageInitGD( image, &map->imagecolor );
     else if(MS_RENDERER_PLUGIN(format)) {
-    	image = format->r->createImage(width,height,format,&map->imagecolor);
+    	image = format->vtable->createImage(width,height,format,&map->imagecolor);
     	image->format = format;
 		format->refcount++;
@@ -1494,7 +1494,7 @@
                        imageObj *image)
 	if (image != NULL && MS_RENDERER_PLUGIN(image->format)) {
-		image->format->r->transformShape(shape, extent, cellsize);
+		image->format->vtable->transformShape(shape, extent, cellsize);
 		return;
