[mapserver-commits] r9115 - trunk/docs/en/mapfile
svn at osgeo.org
svn at osgeo.org
Sun Jun 21 14:47:47 EDT 2009
Author: tbonfort
Date: 2009-06-21 14:47:46 -0400 (Sun, 21 Jun 2009)
New Revision: 9115
trunk/docs/en/mapfile/style.txt
trunk/docs/en/mapfile/symbol.txt
document the move of gap, pattern, caps and joins from symbolObj to styleObj
Modified: trunk/docs/en/mapfile/style.txt
--- trunk/docs/en/mapfile/style.txt 2009-06-21 18:20:48 UTC (rev 9114)
+++ trunk/docs/en/mapfile/style.txt 2009-06-21 18:47:46 UTC (rev 9115)
@@ -70,6 +70,17 @@
The associated RFC document for this feature is :ref:`RFC19`.
+GAP [int]
+ Given in pixels. This defines a distance between symbols for
+ TrueType lines. As of MapServer 5.0 this also applies to PixMap symbols.
+ When drawing the symbol along a line segment, a negative GAP will will add
+ 180 degress to the angle. The TrueType and PixMap symbols are always oriented
+ along the line. A GAP of 0 (the default value) will cause MapServer to use
+ the symbol as a brush to draw the line.
+ .. versionadded:: 6.0 moved from :ref:`SYMBOL`
GEOMTRANSFORM [start|end|vertices|bbox|centroid]
- Used to indicate that the current feature will be transformed before the actual
@@ -84,6 +95,25 @@
vertices of the underlying geometry. When used with ANGLE AUTO, the marker is
oriented by the half angle formed by the two adjacent line segments.
+LINECAP [butt|round|square|triangle]
+ Sets the line cap type for the cartoline symbol. Default is butt. Works
+ with the CARTOLINE symbol only!
+LINEJOIN [round|miter|bevel]
+ Sets the line join type for the cartoline symbol. Default is "none" -
+ lines will not be joined . Works with the CARTOLINE symbol only!
+LINEJOINMAXSIZE [int]
+ Sets the max length of the miter line join type. The value represents a
+ coefficient which multiplies a current symbol size. Default is 3.
+ Works with the CARTOLINE symbol only!
MAXSIZE [integer]
Maximum size in pixels to draw a symbol. Default is 50.
@@ -119,6 +149,12 @@
+PATTERN [num on] [num off] [num on] ... END
+ Defines a dash style or pattern for line symbologies.
SIZE [integer|attribute]
- Height, in layer SIZEUNITS, of the symbol/pattern to be used. Only useful with
Modified: trunk/docs/en/mapfile/symbol.txt
--- trunk/docs/en/mapfile/symbol.txt 2009-06-21 18:20:48 UTC (rev 9114)
+++ trunk/docs/en/mapfile/symbol.txt 2009-06-21 18:47:46 UTC (rev 9115)
@@ -43,7 +43,13 @@
FONT [string]
Name of TrueType font to use as defined in the :ref:`FONTSET`.
GAP [int]
+ .. deprecated:: 6.0
+ This keyword has been deprecated in version 6.0. It has been replaced by the
+ same keyword in the :ref:`STYLE`.
@@ -51,6 +57,7 @@
IMAGE [string]
Image (GIF or PNG) to use as a marker or brush for type PIXMAP symbols.
@@ -59,19 +66,39 @@
Alias for this font to be used in :ref:`CLASS` objects
Defines a dash style or pattern. Implemented in MapServer 5.0,
to replace the deprecated STYLE parameter.
More information about the mapserver-commits
