[mapserver-commits] r8659 - trunk/docs/development
svn at osgeo.org
svn at osgeo.org
Sun Mar 8 11:31:00 EDT 2009
Author: dmorissette
Date: 2009-03-08 11:31:00 -0400 (Sun, 08 Mar 2009)
New Revision: 8659
trunk/docs/development/documentation.txt
Added/updated Linux install/usage instructions
Modified: trunk/docs/development/documentation.txt
--- trunk/docs/development/documentation.txt 2009-03-08 14:56:25 UTC (rev 8658)
+++ trunk/docs/development/documentation.txt 2009-03-08 15:31:00 UTC (rev 8659)
@@ -64,13 +64,14 @@
:Revision: $Revision$
:Date: $Date$
-Installing Sphinx for rst-html Generation
+Installing and Using Sphinx for rst-html Generation
+**On Windows:**
#. install `Python 2.X`_
#. download `setuptools`_
-#. For Windows users: make sure that the 'C:\Python2X\Scripts'
- directory is your path
+#. make sure that the 'C:\Python2X\Scripts' directory is your path
#. execute the following at commandline:
@@ -88,10 +89,28 @@
...you should see a message: "build succeeded, ..."
- Alternatively, if you are on \*nix, you can issue
+**On Linux:**
+#. make sure you have the Python dev and setuptools packages installed.
+ On Ubuntu:
+ sudo apt-get install python-dev
+ sudo apt-get install python-setuptools
+#. install sphinx using easy_install:
+ sudo easy_install sphynx
+#. to process the docs, from the MapServer /docs directory, run:
make html
or
@@ -100,8 +119,9 @@
make latex
- to build the documentation using `make`.
+ the HTML output will be written to the build/html sub-directory.
Reference Labels
More information about the mapserver-commits
