[mapserver-commits] r8660 - sandbox/graphics
svn at osgeo.org
svn at osgeo.org
Sun Mar 8 11:31:31 EDT 2009
Author: tbonfort
Date: 2009-03-08 11:31:31 -0400 (Sun, 08 Mar 2009)
New Revision: 8660
sandbox/graphics/Makefile.in
sandbox/graphics/configure
sandbox/graphics/configure.in
add configuration option for cairo support
Modified: sandbox/graphics/Makefile.in
--- sandbox/graphics/Makefile.in 2009-03-08 15:31:00 UTC (rev 8659)
+++ sandbox/graphics/Makefile.in 2009-03-08 15:31:31 UTC (rev 8660)
@@ -225,8 +225,9 @@
ICONV_INC=@ICONV_INC@
CAIRO=@CAIRO_ENABLED@
-CAIRO_LIB=`pkg-config --libs cairo cairo-ft cairo-svg cairo-pdf cairo-png`
-CAIRO_INC=`pkg-config --cflags cairo cairo-ft cairo-svg cairo-pdf cairo-png`
+CAIRO_LIB=@CAIRO_LIB@
+CAIRO_INC=@CAIRO_INC@
# Pick a compiler, etc. Flex and bison are only required if you need to modify the mapserver lexer (maplexer.l) or expression parser (mapparser.y).
@@ -249,7 +250,7 @@
XTRALIBS= @XTRALIBS@
RUNPATHS= @RPATHS@
-DEFINES = -DUSE_CAIRO $(IGNORE_MISSING_DATA) $(USE_POINT_Z_M) $(STRINGS) @ALL_ENABLED@ $(FRIBIDI)
+DEFINES = $(IGNORE_MISSING_DATA) $(USE_POINT_Z_M) $(STRINGS) @ALL_ENABLED@ $(FRIBIDI)
INCLUDES = $(REGEX_INC) $(PNG_INC) $(GD_INC) $(AGG_INC) $(OGL_INC) $(FTGL_INC) $(PDF_INC) $(PROJ_INC) $(TIFF_INC) $(JPEG_INC) $(EGIS_INC) \
$(SDE_INC) $(GDAL_INC) $(POSTGIS_INC) $(MYGIS_INC) \
Modified: sandbox/graphics/configure
--- sandbox/graphics/configure 2009-03-08 15:31:00 UTC (rev 8659)
+++ sandbox/graphics/configure 2009-03-08 15:31:31 UTC (rev 8660)
@@ -759,6 +759,9 @@
FRIBIDI_ENABLED
FRIBIDI_INC
FRIBIDI_LIB
+CAIRO_ENABLED
+CAIRO_INC
+CAIRO_LIB
FASTCGI_ENABLED
FASTCGI_INC
FASTCGI_LIB
@@ -1374,16 +1377,18 @@
Optional Features:
--disable-FEATURE do not include FEATURE (same as --enable-FEATURE=no)
--enable-FEATURE[=ARG] include FEATURE [ARG=yes]
- --enable-ignore-missing-data Ignore missing data file errors at runtime
- --disable-ignore-missing-data Report all missing data files (enabled by
- default).
+ --enable-ignore-missing-data
+ Ignore missing data file errors at runtime
+ --disable-ignore-missing-data
+ Report all missing data files (enabled by default).
--enable-point-z-m Use point Z and M parameters (disabled by default).
--disable-point-z-m Disable support for point Z and M parameters.
--disable-fast-nint Use safe MS_NINT with reliable rounding
--enable-debug Include "-g" in CFLAGS for debugging.
--disable-debug Do not include "-g" in CFLAGS (the default).
--enable-gcov Enable source code coverage testing using gcov
- --enable-perlv-ld-detect (applies to --with-php only)
+ --enable-perlv-ld-detect
+ (applies to --with-php only)
Use perl -V output to figure the command to use to
link php_mapscript.so. Try this only if the default
internal macro didn't work.
@@ -1394,7 +1399,8 @@
Optional Packages:
--with-PACKAGE[=ARG] use PACKAGE [ARG=yes]
--without-PACKAGE do not use PACKAGE (same as --with-PACKAGE=no)
- --with-pkg-config[=PATH] Include pkg-config support (PATH is path to pkg-config)
+ --with-pkg-config[=PATH]
+ Include pkg-config support (PATH is path to pkg-config)
--with-freetype=DIR GD: Specify where FreeType 2.x is installed (DIR is
path to freetype-config program or install dir).
--with-zlib=DIR GD,SVG: Specify where zlib is installed (DIR is path
@@ -1406,21 +1412,22 @@
libXpm install prefix).
--with-libiconv=DIR Specify where libiconv is installed (DIR is path
to libiconv install dir (prefix)).
- --with-gd[=[static,]DIR] Specify which version of GD to use (DIR is GD's
+ --with-gd[=[static,]DIR]
+ Specify which version of GD to use (DIR is GD's
install dir).
--without-pdf Disable PDF support.
--with-pdf[=DIR] Include PDF support (DIR is PDFlib's install dir).
- --with-ftgl[=DIR] Include OpenGl support (DIR is OpenGL's install dir).
- --with-opengl[=DIR] Include OpenGl support (DIR is OpenGL's install dir).
+ --with-ftgl[=DIR] Include OpenGl support (DIR is OpenGL's install dir).
+ --with-opengl[=DIR] Include OpenGl support (DIR is OpenGL's install dir).
--with-agg[=DIR] Include AGG support (DIR is AGG's install dir).
- --with-experimental-png Include experimental palette support for rgba png.
+ --with-experimental-png Include experimental palette support for rgba png.
--without-eppl Disable EPPL7 support.
--with-eppl Include EPPL7 support.
--with-proj[=DIR] Include PROJ.4 support (DIR is PROJ.4's install dir).
--with-threads[=linkopt]Include thread safe support
--with-sde[=DIR] Include ESRI SDE support (DIR is SDE's install dir).
- --with-sde-version[=VERSION NUMBER] Set ESRI SDE version number (Default
- is 91).
+ --with-sde-version[=VERSION NUMBER]
+ Set ESRI SDE version number (Default is 91).
--with-geos[=PATH] Include GEOS support (PATH is path to geos-config)
--with-ogr[=PATH] Include OGR support (PATH is path to gdal-config).
--with-gdal[=PATH] Include GDAL support (PATH is path to gdal-config)
@@ -1428,7 +1435,8 @@
--with-tiff[=DIR] Include TIFF support (DIR is LibTIFF's install dir).
--with-postgis[=ARG] Include PostGIS Support (ARG=yes/path to pg_config)
--with-mygis[=ARG] Include MyGIS Support (ARG=yes/path to mysql_config)
- --with-oraclespatial[=ARG] Include OracleSpatial Support (ARG=yes/path to
+ --with-oraclespatial[=ARG]
+ Include OracleSpatial Support (ARG=yes/path to
Oracle home)
--with-ming[=DIR] Include MING/Flash Support (DIR=path to Ming
directory)
@@ -1443,8 +1451,10 @@
OGR required).
--with-curl-config=PATH Specify path to curl-config.
--with-xml2-config=PATH Specify path to xml2-config.
- --with-fribidi-config[=ARG] Include FriBidi Support (ARG=yes/path to
+ --with-fribidi-config[=ARG]
+ Include FriBidi Support (ARG=yes/path to
fribidi-config or fribidi.pc)
+ --with-cairo[=ARG] Include Cairo Support (ARG=yes/path to cairo.pc)
--with-fastcgi=path Enable FastCGI, point to installed tree.
--with-httpd Specify path to 'httpd' executable.
--with-warnings[=flags] Enable strict warnings (or user defined warnings)
@@ -12412,6 +12422,71 @@
ALL_LIB="$FRIBIDI_LIB $ALL_LIB"
+{ echo "$as_me:$LINENO: checking if Cairo support requested" >&5
+echo $ECHO_N "checking if Cairo support requested... $ECHO_C" >&6; }
+# Check whether --with-cairo was given.
+if test "${with_cairo+set}" = set; then
+ withval=$with_cairo;
+fi
+if test "$with_cairo" = "no" -o "$with_cairo" = "" ; then
+ { echo "$as_me:$LINENO: result: no" >&5
+echo "${ECHO_T}no" >&6; }
+ CAIRO_CONFIG="no"
+elif test "$with_cairo" = "yes" ; then
+ { echo "$as_me:$LINENO: result: yes" >&5
+echo "${ECHO_T}yes" >&6; }
+ if test "$PKG_CONFIG" != "no" ; then
+ { echo "$as_me:$LINENO: checking for cairo pkg-config path" >&5
+echo $ECHO_N "checking for cairo pkg-config path... $ECHO_C" >&6; }
+ `$PKG_CONFIG --silence-errors -- cairo cairo-ft cairo-svg cairo-pdf cairo-png >> /dev/null`
+ if test $? -eq 0 ; then
+ CAIRO_CONFIG="cairo cairo-ft cairo-svg cairo-pdf cairo-png"
+ else
+ { { echo "$as_me:$LINENO: error: cairo support requested, but not found.Try installing the cairo development headers" >&5
+echo "$as_me: error: cairo support requested, but not found.Try installing the cairo development headers" >&2;}
+ { (exit 1); exit 1; }; }
+ fi
+ else
+ { { echo "$as_me:$LINENO: error: pkg-config required for cairo support, try using --with-pkg-config=PATH" >&5
+echo "$as_me: error: pkg-config required for cairo support, try using --with-pkg-config=PATH" >&2;}
+ fi
+else
+ CAIRO_CONFIG=$with_cairo_config
+fi
+if test "$CAIRO_CONFIG" = "no" ; then
+ CAIRO_ENABLED=
+ CAIRO_INC=
+ CAIRO_LIB=
+else
+ { echo "$as_me:$LINENO: result: yes, pkg-config defaults, or user supplied path to cairo.pc" >&5
+echo "${ECHO_T}yes, pkg-config defaults, or user supplied path to cairo.pc" >&6; }
+ CAIRO_ENABLED="-DUSE_CAIRO"
+ CAIRO_LIB=`$PKG_CONFIG --libs $CAIRO_CONFIG`
+ CAIRO_INC=`$PKG_CONFIG --cflags $CAIRO_CONFIG`
+fi
+CAIRO_ENABLED=$CAIRO_ENABLED
+CAIRO_INC=$CAIRO_INC
+CAIRO_LIB=$CAIRO_LIB
+ALL_ENABLED="$CAIRO_ENABLED $ALL_ENABLED"
+ALL_INC="$CAIRO_INC $ALL_INC"
+ALL_LIB="$CAIRO_LIB $ALL_LIB"
{ echo "$as_me:$LINENO: checking FastCGI support" >&5
echo $ECHO_N "checking FastCGI support... $ECHO_C" >&6; }
@@ -14325,6 +14400,9 @@
FRIBIDI_ENABLED!$FRIBIDI_ENABLED$ac_delim
FRIBIDI_INC!$FRIBIDI_INC$ac_delim
FRIBIDI_LIB!$FRIBIDI_LIB$ac_delim
+CAIRO_ENABLED!$CAIRO_ENABLED$ac_delim
+CAIRO_INC!$CAIRO_INC$ac_delim
+CAIRO_LIB!$CAIRO_LIB$ac_delim
FASTCGI_ENABLED!$FASTCGI_ENABLED$ac_delim
FASTCGI_INC!$FASTCGI_INC$ac_delim
FASTCGI_LIB!$FASTCGI_LIB$ac_delim
@@ -14359,7 +14437,7 @@
LTLIBOBJS!$LTLIBOBJS$ac_delim
_ACEOF
- if test `sed -n "s/.*$ac_delim\$/X/p" conf$$subs.sed | grep -c X` = 81; then
+ if test `sed -n "s/.*$ac_delim\$/X/p" conf$$subs.sed | grep -c X` = 84; then
break
elif $ac_last_try; then
{ { echo "$as_me:$LINENO: error: could not make $CONFIG_STATUS" >&5
@@ -14725,6 +14803,8 @@
echo "${ECHO_T} AGG support: ${AGG_ENABLED}" >&6; }
{ echo "$as_me:$LINENO: result: AGG Freetype support: ${AGG_FT_LIB}${AGG_FT_OBJ}" >&5
echo "${ECHO_T} AGG Freetype support: ${AGG_FT_LIB}${AGG_FT_OBJ}" >&6; }
+{ echo "$as_me:$LINENO: result: Cairo (SVG,PDF) support: ${CAIRO_ENABLED}" >&5
+echo "${ECHO_T} Cairo (SVG,PDF) support: ${CAIRO_ENABLED}" >&6; }
{ echo "$as_me:$LINENO: result: Ming(flash) support: ${MING_ENABLED}" >&5
echo "${ECHO_T} Ming(flash) support: ${MING_ENABLED}" >&6; }
{ echo "$as_me:$LINENO: result: PDFLib support: ${PDF_ENABLED}" >&5
Modified: sandbox/graphics/configure.in
--- sandbox/graphics/configure.in 2009-03-08 15:31:00 UTC (rev 8659)
+++ sandbox/graphics/configure.in 2009-03-08 15:31:31 UTC (rev 8660)
@@ -87,7 +87,8 @@
AC_MSG_CHECKING(if pkg-config path is provided)
AC_ARG_WITH(pkg-config,
-[ --with-pkg-config[[=PATH]] Include pkg-config support (PATH is path to pkg-config)],,)
+[ --with-pkg-config[[=PATH]]
+ Include pkg-config support (PATH is path to pkg-config)],,)
if test -n "$with_pkg_config" -a "$with_pkg_config" != "no" ; then
@@ -523,7 +524,8 @@
AC_CHECKING(for GD 2.0.16 or higher)
AC_ARG_WITH(gd,
-[ --with-gd[[=[static,]DIR]] Specify which version of GD to use (DIR is GD's
+[ --with-gd[[=[static,]DIR]]
install dir).],,)
if test "$with_gd" = "no" ; then
@@ -821,7 +823,7 @@
AC_MSG_CHECKING(if FTGL support requested)
AC_ARG_WITH(ftgl,
-[ --with-ftgl[[=DIR]] Include OpenGl support (DIR is OpenGL's install dir).],,)
+[ --with-ftgl[[=DIR]] Include OpenGl support (DIR is OpenGL's install dir).],,)
if test "$with_ftgl" = "yes" ; then
with_ftgl="/usr"
@@ -876,7 +878,7 @@
AC_MSG_CHECKING(if OGL support requested)
AC_ARG_WITH(ogl,
-[ --with-opengl[[=DIR]] Include OpenGl support (DIR is OpenGL's install dir).],,)
+[ --with-opengl[[=DIR]] Include OpenGl support (DIR is OpenGL's install dir).],,)
if test "$with_opengl" = "yes" ; then
@@ -1031,7 +1033,7 @@
AC_MSG_CHECKING(if RGBA palette png support requested)
AC_ARG_WITH(experimental-png,
-[ --with-experimental-png Include experimental palette support for rgba png.],,)
+[ --with-experimental-png Include experimental palette support for rgba png.],,)
if test -z "$with_experimental_png" -o "$with_experimental_png" = "no" ; then
AC_MSG_RESULT([no])
@@ -1217,8 +1219,8 @@
[ --with-sde[[=DIR]] Include ESRI SDE support (DIR is SDE's install dir).],,)
AC_ARG_WITH(sde-version,
-[ --with-sde-version[[=VERSION NUMBER]] Set ESRI SDE version number (Default
- is 91).],SDE_VERSION=$with_sde_version,SDE_VERSION=91)
+[ --with-sde-version[[=VERSION NUMBER]]
+ Set ESRI SDE version number (Default is 91).],SDE_VERSION=$with_sde_version,SDE_VERSION=91)
if test -z "$SDE_VERSION" -o `expr "$SDE_VERSION" \>\= 92` = 1; then
SDE_VERSION=""
@@ -1652,7 +1654,8 @@
AC_MSG_CHECKING(if OracleSpatial support requested)
AC_ARG_WITH(oraclespatial,
-[ --with-oraclespatial[[=ARG]] Include OracleSpatial Support (ARG=yes/path to
+[ --with-oraclespatial[[=ARG]]
Oracle home)],,)
if test "$with_oraclespatial" = "no" -o "$with_oraclespatial" = ""; then
@@ -2050,7 +2053,8 @@
AC_MSG_CHECKING(if FriBidi support requested)
AC_ARG_WITH(fribidi-config,
-[ --with-fribidi-config[[=ARG]] Include FriBidi Support (ARG=yes/path to
+[ --with-fribidi-config[[=ARG]]
fribidi-config or fribidi.pc)],,)
if test "$with_fribidi_config" = "no" -o "$with_fribidi_config" = "" ; then
@@ -2107,6 +2111,57 @@
+dnl ---------------------------------------------------------------------------
+dnl Look for Cairo if requested.
+AC_MSG_CHECKING(if Cairo support requested)
+AC_ARG_WITH(cairo,
+[ --with-cairo[[=ARG]] Include Cairo Support (ARG=yes/path to cairo.pc)],,)
+ AC_MSG_RESULT(no)
+ CAIRO_CONFIG="no"
+ AC_MSG_RESULT(yes)
+ AC_MSG_CHECKING(for cairo pkg-config path)
+ else
+ AC_MSG_ERROR([cairo support requested, but not found.Try installing the cairo development headers])
+ fi
+ else
+ AC_MSG_ERROR([pkg-config required for cairo support, try using --with-pkg-config=PATH])
+ fi
+else
+fi
+ CAIRO_ENABLED=
+ CAIRO_INC=
+ CAIRO_LIB=
+else
+ AC_MSG_RESULT([yes, pkg-config defaults, or user supplied path to cairo.pc])
+fi
+AC_SUBST(CAIRO_ENABLED,$CAIRO_ENABLED)
+AC_SUBST(CAIRO_INC,$CAIRO_INC)
+AC_SUBST(CAIRO_LIB,$CAIRO_LIB)
dnl Support for FastCGI enabled builds.
@@ -2220,9 +2275,10 @@
AC_ARG_ENABLE(ignore-missing-data,
-[ --enable-ignore-missing-data Ignore missing data file errors at runtime
- default).],,)
+[ --enable-ignore-missing-data
+ Report all missing data files (enabled by default).],,)
if test "$enable_ignore_missing_data" = "yes" ; then
IGNORE_MISSING_DATA="-DIGNORE_MISSING_DATA"
@@ -2362,7 +2418,8 @@
module.],,)
AC_ARG_ENABLE(internal-ld-detect,
-[ --enable-perlv-ld-detect (applies to --with-php only)
+[ --enable-perlv-ld-detect
internal macro didn't work.],,)
@@ -2675,6 +2732,7 @@
AC_MSG_RESULT([ iconv support: ${ICONV_ENABLED}])
AC_MSG_RESULT([ AGG support: ${AGG_ENABLED}])
AC_MSG_RESULT([ AGG Freetype support: ${AGG_FT_LIB}${AGG_FT_OBJ}])
+AC_MSG_RESULT([ Cairo (SVG,PDF) support: ${CAIRO_ENABLED}])
AC_MSG_RESULT([ Ming(flash) support: ${MING_ENABLED}])
AC_MSG_RESULT([ PDFLib support: ${PDF_ENABLED}])
AC_MSG_RESULT()
More information about the mapserver-commits
