[mapserver-commits] r8688 - trunk/docs/tutorial
Mon Mar 9 09:20:39 EDT 2009
Author: pnaciona
Date: 2009-03-09 09:20:39 -0400 (Mon, 09 Mar 2009)
New Revision: 8688
   trunk/docs/tutorial/example1-3.txt
update tutorial example 1.3
Modified: trunk/docs/tutorial/example1-3.txt
--- trunk/docs/tutorial/example1-3.txt	2009-03-09 13:09:00 UTC (rev 8687)
+++ trunk/docs/tutorial/example1-3.txt	2009-03-09 13:20:39 UTC (rev 8688)
@@ -9,7 +9,7 @@
 By using non-spatial attribute information in the data, we can create a map
 like this:
-.. image: http://biometry.gis.umn.edu/cgi-bin/mapserv.exe?map=/ms4w/apps/tutorial/htdocs/example1-3.map&layer=states_poly&layer=states_line&mode=map
+.. image:: http://biometry.gis.umn.edu/cgi-bin/mapserv.exe?map=/ms4w/apps/tutorial/htdocs/example1-3.map&layer=states_poly&layer=states_line&mode=map
 This is what the mapfile looks like: `Example1-3.map<http://biometry.gis.umn.edu/tutorial/example1-3.map>`_.
@@ -22,30 +22,29 @@
        (land) CLASS---|---CLASS (water)      |-CLASS
-            STYLE-|       |-STYLE              |-STYLE</pre>
+            STYLE-|       |-STYLE              |-STYLE
 Our mapfile still only has two layers but the polygon layer has been broken down
 into two classes. Let's have a look at the additional parameters:
 **CLASSITEM**
-This keyword is used to specify what attribute to use in separating the class
-objects. In this example that attribute is "CLASS". If you open the database
-file associated with this layer's shapefile, you'll see that there's a column
-(attribute) called "CLASS".
+         This keyword is used to specify what attribute to use in separating
+         the class objects. In this example that attribute is "CLASS". If you
+         open the database file associated with this layer's shapefile, you'll
+         see that there's a column (attribute) called "CLASS".
-How do we know which attribute to use?  Well, database records in
-            shapefiles are stored in DBF files.  You can open it in a
-            spreadsheet program such as Openoffice.org's Calc, or in a desktop
-            GIS software such as QGIS, Thuban, or ArcView.  If your data came
-            with a metadata (and it should!), you can skim through through that
-            metadata file for attribute information.  You can also use "ogrinfo"
-            to display basic attribute info in your shapefiles--look back at
-            example 1.1 (the last few lines after "Layer SRS WKT:" show the
-            attribute names and types).
+         How do we know which attribute to use?  Well, database records in
+         shapefiles are stored in DBF files.  You can open it in a spreadsheet
+         program such as Openoffice.org's Calc, or in a desktop GIS software
+         such as QGIS, Thuban, or ArcView.  If your data came with a metadata
+         (and it should!), you can skim through through that metadata file for
+         attribute information.  You can also use "ogrinfo" to display basic
+         attribute info in your shapefiles--look back at example 1.1 (the last
+         few lines after "Layer SRS WKT:" show the attribute names and types).
 **EXPRESSION**
-For each class, we specify what attribute value to use. This is the
-            simplest form of EXPRESSION. EXPRESSIONs can be even more complex
-            than this, allowing one to evaluate regular or logical expressions.
-            Please look at the mapfile reference page to see what you can do
-            with EXPRESSION.
+          For each class, we specify what attribute value to use. This is the
+          simplest form of EXPRESSION. EXPRESSIONs can be even more complex than
+          this, allowing one to evaluate regular or logical expressions. Please
+          look at the mapfile reference page to see what you can do
+          with EXPRESSION.
\ No newline at end of file
