[mapserver-commits] r8689 - trunk/docs/tutorial
Mon Mar 9 09:49:56 EDT 2009
Author: jmckenna
Date: 2009-03-09 09:49:56 -0400 (Mon, 09 Mar 2009)
New Revision: 8689
Added:
   trunk/docs/tutorial/example1-2.txt
   trunk/docs/tutorial/index.txt
add more tutorial pages
Added: trunk/docs/tutorial/example1-2.txt
--- trunk/docs/tutorial/example1-2.txt	                        (rev 0)
+++ trunk/docs/tutorial/example1-2.txt	2009-03-09 13:49:56 UTC (rev 8689)
@@ -0,0 +1,50 @@
+.. _example1-2:
+Section 2: CGI variables and the User Interface
+So far we have only looked at the mapfile when creating maps. In creating web mapping
+applications, it is usually our intention to make maps that can be changed by the user
+(of the application) interactively. That is, a user should be able to change the content
+of (or the information in) the map. To accomplish this interactivity, we use the
+MapServer HTML templates.
+A MapServer HTML template is essentially an HTML file with a few MapServer specific tags.
+These tags are the MapServer CGI variables and are enclosed in square brackets "[]".
+When the MapServer CGI program processes an application, it first parses the query string
+and the mapfile, and produces the necessary output. Some of this output will need to be
+written to the HTML template file which you would have to also specify in the mapfile
+using the web template keyword (or in a separate HTML initialization file). The CGI
+program will replace all the variables in the HTML template with the proper value
+before sending it back to the web browser. If you are to directly view an HTML template
+on a web browser, there won't be any maps rendered and you will instead get blank
+images and other junk.
+MapServer provides several variables for web mapping: the "img" variable which you've
+seen in Example 1.9 is but one example. There area few core CGI variables originally
+designed as part of the mapping interface but practically all the mapfile parameters
+can be defined as variables. The definitive reference to the CGI variables can be
+found at :ref:`here <cgi>`.
+We can also define our own variables, which MapServer will pass along to our application.
+For example, we can create a variable called "root" to represent the root directory of
+this tutorial, the value for "root" will then be "/tutorial". When the MapServer CGI
+program processes our HTML template, it will replace every instance of he "[root]" tag
+with "/tutorial". You will see this in action for each of the following examples.
+So, let's build an interactive interface for our application...
+- Users of a web mapping application should be able to pan and zoom on the map:
+  `Example 2.1 - Pan and Zoom Controls <http://biometry.gis.umn.edu/cgi-bin/mapserv.exe?map=/ms4w/apps/tutorial/htdocs/example2.map&layer=states&zoom=0&mode=browse&root=/tutorial&program=/cgi-bin/mapserv.exe&map_web=template+example2-1.html>`_
+- They also should be able to turn on and off layers on a map:
+  `Example 2.2 - Layer Control <http://biometry.gis.umn.edu/cgi-bin/mapserv.exe?map=/ms4w/apps/tutorial/htdocs/example2.map&layer=states&zoom=0&mode=browse&root=/tutorial&program=/cgi-bin/mapserv.exe&map_web=template+example2-2.html>`_
+- A map should always include a scalebar.
+  `Example 2.3 - Adding a Scalebar <http://biometry.gis.umn.edu/cgi-bin/mapserv.exe?map=/ms4w/apps/tutorial/htdocs/example2.map&layer=states&zoom=0&mode=browse&root=/tutorial&program=/cgi-bin/mapserv.exe&map_web=template+example2-3.html>`_
+- If users are to navigate through the map, a reference map should be provided:
+  `Example 2.4 - Adding a Reference Map <http://biometry.gis.umn.edu/cgi-bin/mapserv.exe?map=/ms4w/apps/tutorial/htdocs/example2.map&layer=states&zoom=0&mode=browse&root=/tutorial&program=/cgi-bin/mapserv.exe&map_web=template+example2-4.html>`_
+- The map should include a legend.
+  `Example 2.5- Adding a Legend <http://biometry.gis.umn.edu/cgi-bin/mapserv.exe?map=/ms4w/apps/tutorial/htdocs/example2.map&layer=states&zoom=0&mode=browse&root=/tutorial&program=/cgi-bin/mapserv.exe&map_web=template+example2-5.html>`_
\ No newline at end of file
Modified: trunk/docs/tutorial/index.txt
--- trunk/docs/tutorial/index.txt	2009-03-09 13:20:39 UTC (rev 8688)
+++ trunk/docs/tutorial/index.txt	2009-03-09 13:49:56 UTC (rev 8689)
@@ -28,4 +28,6 @@
    :maxdepth: 1
    background
-   example1-1
+   example1-1
+   example1-2
+   example1-3
