[mapserver-commits] r8768 - trunk/docs/development/rfc
svn at osgeo.org
svn at osgeo.org
Tue Mar 10 11:42:26 EDT 2009
Author: dmorissette
Date: 2009-03-10 11:42:26 -0400 (Tue, 10 Mar 2009)
New Revision: 8768
trunk/docs/development/rfc/ms-rfc-55.txt
Added list of affected parameters
Modified: trunk/docs/development/rfc/ms-rfc-55.txt
--- trunk/docs/development/rfc/ms-rfc-55.txt 2009-03-10 15:31:51 UTC (rev 8767)
+++ trunk/docs/development/rfc/ms-rfc-55.txt 2009-03-10 15:42:26 UTC (rev 8768)
@@ -7,7 +7,7 @@
:Date: 2009/03/09
:Authors: Daniel Morissette
:Contact: dmorissette at mapgears.com
-:Last Edited: 2009/03/09
+:Last Edited: 2009/03/10
:Status: Draft
:Version: MapServer 6.0
:Id: $Id: $
@@ -45,7 +45,33 @@
More specifically, this is done by multiplying the layer->scalefactor value
by the resolution/defresolution ratio in msPrepareImage().
+The following rendering parameters will be affected:
+* size (symbols and labels)
+* width (lines)
+The following rendering parameters which were not impacted by scaling in
+the past will also be fixed to follow the scaling from now on:
+* offsets (line, point, polygon)
+* pattern (line)
+* gap (line)
+* outlinewidth (labels)
+* shadowsize, background-shadow-size (labels)
+* buffer around labels (collision)
+* minfeaturesize, mindistance (labels)
+The case of outlinewidth for line styles is a bit different: it ignores
+the scalefactor so that we get a fixed outline width no matter what we use
+for size units, but we want it to follow the resolution/defresolution factor.
+For this case the line drawing code will need to have a reference to the
+mapObj passed to msDrawLineSymbol() so that it can access the resolution
+and defresolution parameters and do the right thing.
+In the case of pixmap symbols, they will be scaled only if a size is set.
+If no size is set then no scaling happens.
Usage example
@@ -79,6 +105,8 @@
mapfile which matches the resolution for which all mapfile classes
and styles are defined.
+The rendering parameters listed above that did not follow scaling in the
+past will be fixed to follow the scaling.
Files Impacted
More information about the mapserver-commits
