[mapserver-commits] r8769 - trunk/docs/tutorial
svn at osgeo.org
svn at osgeo.org
Tue Mar 10 11:44:39 EDT 2009
Author: jmckenna
Date: 2009-03-10 11:44:39 -0400 (Tue, 10 Mar 2009)
New Revision: 8769
trunk/docs/tutorial/background.txt
trunk/docs/tutorial/example1-1.txt
trunk/docs/tutorial/example1-2.txt
trunk/docs/tutorial/example1-3.txt
trunk/docs/tutorial/example1-4.txt
trunk/docs/tutorial/example1-5.txt
trunk/docs/tutorial/example1-6.txt
trunk/docs/tutorial/example1-7.txt
trunk/docs/tutorial/example1-8.txt
trunk/docs/tutorial/index.txt
trunk/docs/tutorial/section1.txt
trunk/docs/tutorial/section2.txt
add ref to tutorial, and add tutorial navigation
Modified: trunk/docs/tutorial/background.txt
--- trunk/docs/tutorial/background.txt 2009-03-10 15:42:26 UTC (rev 8768)
+++ trunk/docs/tutorial/background.txt 2009-03-10 15:44:39 UTC (rev 8769)
@@ -106,4 +106,10 @@
Other documentation exist to give you better understanding of the many customizations
MapServer offer. Please visit the MapServer documentation page at
http://www.mapserver.org. There you will find several HOWTO documents, from getting
-started to using MapScript, a scripting interface for MapServer.
\ No newline at end of file
+started to using MapScript, a scripting interface for MapServer.
+:ref:`Back to Tutorial home <tutorial>` | :ref:`Proceed to Section 1 <section1>`
Modified: trunk/docs/tutorial/example1-1.txt
--- trunk/docs/tutorial/example1-1.txt 2009-03-10 15:42:26 UTC (rev 8768)
+++ trunk/docs/tutorial/example1-1.txt 2009-03-10 15:44:39 UTC (rev 8769)
@@ -194,4 +194,10 @@
MapServer doesn't draw polygon outlines by default, so if you want to
see polygon boundaries, you will want to define an OUTLINECOLOR.
-This ends the first example in this tutorial. You are encouraged to change the values of the keywords in the mapfile. It will help you understand what these keywords do.
+This ends the first example in this tutorial. You are encouraged to change the values of the keywords in the mapfile. It will help you understand what these keywords do.
+:ref:`Back to Section 1 index <section1>` | :ref:`Proceed to Example 1.2 <example1-2>`
Modified: trunk/docs/tutorial/example1-2.txt
--- trunk/docs/tutorial/example1-2.txt 2009-03-10 15:42:26 UTC (rev 8768)
+++ trunk/docs/tutorial/example1-2.txt 2009-03-10 15:44:39 UTC (rev 8769)
@@ -76,4 +76,10 @@
we add these other layers, we have to separate the states boundary line layer
from the states polygon layer and put it on top of the other other layers.
There is order in how we define/add layers and you'll see it clearly as we
-proceed in this section.
+proceed in this section.
+:ref:`Back to Example 1.1 <example1-1>` | :ref:`Proceed to Example 1.3 <example1-3>`
Modified: trunk/docs/tutorial/example1-3.txt
--- trunk/docs/tutorial/example1-3.txt 2009-03-10 15:42:26 UTC (rev 8768)
+++ trunk/docs/tutorial/example1-3.txt 2009-03-10 15:44:39 UTC (rev 8769)
@@ -54,3 +54,9 @@
this, allowing one to evaluate regular or logical expressions. Please
look at the mapfile reference page to see what you can do
with EXPRESSION.
+:ref:`Back to Example 1.2 <example1-2>` | :ref:`Proceed to Example 1.4 <example1-4>`
Modified: trunk/docs/tutorial/example1-4.txt
--- trunk/docs/tutorial/example1-4.txt 2009-03-10 15:42:26 UTC (rev 8768)
+++ trunk/docs/tutorial/example1-4.txt 2009-03-10 15:44:39 UTC (rev 8769)
@@ -111,4 +111,8 @@
give this CLASS a transparent color (the label IDs don't show up).
Once again, play with the values to understand how it affects the map.
:ref:`Back to Example 1.3 <example1-3>` | :ref:`Proceed to Example 1.5 <example1-5>`
Modified: trunk/docs/tutorial/example1-5.txt
--- trunk/docs/tutorial/example1-5.txt 2009-03-10 15:42:26 UTC (rev 8768)
+++ trunk/docs/tutorial/example1-5.txt 2009-03-10 15:44:39 UTC (rev 8769)
@@ -137,4 +137,10 @@
TYPE RASTER
OFFSITE 70 74 66
-Also, try changing the IMAGETYPE from PNG24 to PNG.
+Also, try changing the IMAGETYPE from PNG24 to PNG.
+:ref:`Back to Example 1.4 <example1-4>` | :ref:`Proceed to Example 1.6 <example1-6>`
Modified: trunk/docs/tutorial/example1-6.txt
--- trunk/docs/tutorial/example1-6.txt 2009-03-10 15:42:26 UTC (rev 8768)
+++ trunk/docs/tutorial/example1-6.txt 2009-03-10 15:44:39 UTC (rev 8769)
@@ -109,3 +109,9 @@
`<http://spatialreference.org/>`_
You can find more by searching the web for "map projection".
+:ref:`Back to Example 1.5 <example1-5>` | :ref:`Proceed to Example 1.7 <example1-7>`
Modified: trunk/docs/tutorial/example1-7.txt
--- trunk/docs/tutorial/example1-7.txt 2009-03-10 15:42:26 UTC (rev 8768)
+++ trunk/docs/tutorial/example1-7.txt 2009-03-10 15:44:39 UTC (rev 8769)
@@ -133,4 +133,10 @@
Documentations also exist for configuring MapServer application to
support the WFS standard, both as a `server
<http://mapserver.gis.umn.edu/doc/wfs-server-howto.html>`_ and as a
- `client <http://mapserver.gis.umn.edu/doc/wfs-client-howto.html>`_.
+ `client <http://mapserver.gis.umn.edu/doc/wfs-client-howto.html>`_.
+:ref:`Back to Example 1.6 <example1-6>` | :ref:`Proceed to Example 1.8 <example1-8>`
Modified: trunk/docs/tutorial/example1-8.txt
--- trunk/docs/tutorial/example1-8.txt 2009-03-10 15:42:26 UTC (rev 8768)
+++ trunk/docs/tutorial/example1-8.txt 2009-03-10 15:44:39 UTC (rev 8769)
@@ -30,4 +30,10 @@
keyword on you mapfile. The NAME of your OUTPUT format should be used as your
IMAGETYPE value ex: IMAGETYPE png or IMAGETYPE png24).
-Please consult the OUTPUTFORMAT object reference at: `<http://ms4w.gis.umn.edu/doc/mapfile-reference.html#outputformat>`_.
+Please consult the OUTPUTFORMAT object reference at: `<http://ms4w.gis.umn.edu/doc/mapfile-reference.html#outputformat>`_.
+:ref:`Back to Example 1.7 <example1-7>` | :ref:`Proceed to Example 1.9 <example1-9>`
Modified: trunk/docs/tutorial/index.txt
--- trunk/docs/tutorial/index.txt 2009-03-10 15:42:26 UTC (rev 8768)
+++ trunk/docs/tutorial/index.txt 2009-03-10 15:44:39 UTC (rev 8769)
@@ -29,4 +29,10 @@
background
section1
- section2
+ section2
+:ref:`Begin tutorial <background>`
Modified: trunk/docs/tutorial/section1.txt
--- trunk/docs/tutorial/section1.txt 2009-03-10 15:42:26 UTC (rev 8768)
+++ trunk/docs/tutorial/section1.txt 2009-03-10 15:44:39 UTC (rev 8769)
@@ -28,4 +28,10 @@
- :ref:`Example 1.8 - A different output format <example1-8>`
- MapServer not only generates static maps, it can also create interactive maps...
- - :ref:`Example 1.9 - The difference between map and browse mode <example1-9>`
+ - :ref:`Example 1.9 - The difference between map and browse mode <example1-9>`
+:ref:`Back to Tutorial home <tutorial>` | :ref:`Proceed to Section 2 <section2>`
Modified: trunk/docs/tutorial/section2.txt
--- trunk/docs/tutorial/section2.txt 2009-03-10 15:42:26 UTC (rev 8768)
+++ trunk/docs/tutorial/section2.txt 2009-03-10 15:44:39 UTC (rev 8769)
@@ -56,4 +56,10 @@
`Example 2.4 - Adding a Reference Map <http://demo.mapserver.org/cgi-bin/mapserv.exe?map=/ms4w/apps/tutorial/htdocs/example2.map&layer=states&zoom=0&mode=browse&root=/tutorial&program=/cgi-bin/mapserv.exe&map_web=template+example2-4.html>`_
- The map should include a legend.
- `Example 2.5- Adding a Legend <http://demo.mapserver.org/cgi-bin/mapserv.exe?map=/ms4w/apps/tutorial/htdocs/example2.map&layer=states&zoom=0&mode=browse&root=/tutorial&program=/cgi-bin/mapserv.exe&map_web=template+example2-5.html>`_
+ `Example 2.5- Adding a Legend <http://demo.mapserver.org/cgi-bin/mapserv.exe?map=/ms4w/apps/tutorial/htdocs/example2.map&layer=states&zoom=0&mode=browse&root=/tutorial&program=/cgi-bin/mapserv.exe&map_web=template+example2-5.html>`_
More information about the mapserver-commits
