[mapserver-commits] r9039 - trunk/docs
svn at osgeo.org
svn at osgeo.org
Sat May 23 17:17:55 EDT 2009
Author: gislars
Date: 2009-05-23 17:17:55 -0400 (Sat, 23 May 2009)
New Revision: 9039
Added:
trunk/docs/make.bat
added batchfile to build docs on windows systems
Added: trunk/docs/make.bat
--- trunk/docs/make.bat (rev 0)
+++ trunk/docs/make.bat 2009-05-23 21:17:55 UTC (rev 9039)
@@ -0,0 +1,66 @@
+ at ECHO OFF
+REM Command file for Sphinx documentation
+set SPHINXBUILD=sphinx-build
+set ALLSPHINXOPTS= -d _build/doctrees/%%L -c . -A language=%%L -D language=%%L
+if NOT "%PAPER%" == "" (
+ set ALLSPHINXOPTS=-D latex_paper_size=%PAPER% %ALLSPHINXOPTS%
+if "%1" == "" goto help
+if "%1" == "help" (
+ :help
+ echo.Please use `make ^<target^>` where ^<target^> is one of
+ echo. html to make standalone HTML files
+ echo. latex to make LaTeX files, you can set PAPER=a4 or PAPER=letter
+ echo. changes to make an overview over all changed/added/deprecated items
+ echo. linkcheck to check all external links for integrity
+ goto end
+if "%1" == "clean" (
+ for /d %%i in (_build\*) do rmdir /q /s %%i
+ del /q /s _build\*
+ goto end
+if "%1" == "html" (
+ FOR /D %%L in ("??") DO (
+ %SPHINXBUILD% -b html %ALLSPHINXOPTS% %%L _build/html/%%L
+ echo.
+ echo.Build finished. The HTML pages are in _build/html.
+ goto end
+if "%1" == "latex" (
+ %SPHINXBUILD% -b latex %ALLSPHINXOPTS% %%L _build/latex/%%L
+ echo.
+ echo.Build finished; the LaTeX files are in _build/latex.
+ goto end
+if "%1" == "changes" (
+ %SPHINXBUILD% -b changes %ALLSPHINXOPTS% %%L _build/changes/%%L
+ echo.
+ echo.The overview file is in _build/changes.
+ goto end
+if "%1" == "linkcheck" (
+ %SPHINXBUILD% -b linkcheck %ALLSPHINXOPTS% %%L _build/linkcheck/%%L
+ echo.
+ echo.Link check complete; look for any errors in the above output ^
+or in _build/linkcheck/output.txt.
+ goto end
+:end
More information about the mapserver-commits
