[mapserver-commits] r9040 - trunk/docs/en/development
svn at osgeo.org
svn at osgeo.org
Mon May 25 09:10:49 EDT 2009
Author: jmckenna
Date: 2009-05-25 09:10:48 -0400 (Mon, 25 May 2009)
New Revision: 9040
trunk/docs/en/development/documentation.txt
modify windows instructions
Modified: trunk/docs/en/development/documentation.txt
--- trunk/docs/en/development/documentation.txt 2009-05-23 21:17:55 UTC (rev 9039)
+++ trunk/docs/en/development/documentation.txt 2009-05-25 13:10:48 UTC (rev 9040)
@@ -79,18 +79,20 @@
easy_install Sphinx
...you should see message: "Finished processing dependencies for Sphinx"
-#. inside the MapServer /docs directory, create /build/doctrees and /build/html
- directories
#. inside the /docs directory, execute:
- sphinx-build -b html -d build\doctrees . build\html
- ...you should see a message: "build succeeded, ..."
+ make html
+ or
+ make latex
+ the HTML output will be written to the _build/html sub-directory.
**On Linux:**
#. make sure you have the Python dev and setuptools packages installed.
More information about the mapserver-commits
