[mapserver-commits] r9561 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Wed Nov 25 09:50:56 EST 2009
Author: sdlime
Date: 2009-11-25 09:50:54 -0500 (Wed, 25 Nov 2009)
New Revision: 9561
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapquery.c
Fixed a problem with shape-based queries against projected layers when using a tolerance (#3211)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2009-11-23 20:26:44 UTC (rev 9560)
+++ trunk/mapserver/HISTORY.TXT 2009-11-25 14:50:54 UTC (rev 9561)
@@ -14,6 +14,8 @@
Current Version (SVN trunk):
+- Fixed a problem with shape-based queries against projected layers when using a tolerance (#3211)
- Fixed long expression evaluation (#2123)
- Added simplfy and topologyPreservingSimplify to MapScript (#2753)
Modified: trunk/mapserver/mapquery.c
--- trunk/mapserver/mapquery.c 2009-11-23 20:26:44 UTC (rev 9560)
+++ trunk/mapserver/mapquery.c 2009-11-25 14:50:54 UTC (rev 9561)
@@ -847,7 +847,7 @@
tolerance = layer_tolerance * msAdjustExtent(&(map->extent), map->width, map->height);
else
tolerance = layer_tolerance * (msInchesPerUnit(lp->toleranceunits,0)/msInchesPerUnit(map->units,0));
/* open this layer */
status = msLayerOpen(lp);
if(status != MS_SUCCESS) return(MS_FAILURE);
@@ -884,6 +884,11 @@
/* identify target shapes */
searchrect = selectshape.bounds;
+ searchrect.minx -= tolerance; /* expand the search box to account for layer tolerances (e.g. buffered searches) */
+ searchrect.maxx += tolerance;
+ searchrect.miny -= tolerance;
+ searchrect.maxy += tolerance;
#ifdef USE_PROJ
if(lp->project && msProjectionsDiffer(&(lp->projection), &(map->projection)))
msProjectRect(&(map->projection), &(lp->projection), &searchrect); /* project the searchrect to source coords */
@@ -891,11 +896,6 @@
lp->project = MS_FALSE;
#endif
- searchrect.minx -= tolerance; /* expand the search box to account for layer tolerances (e.g. buffered searches) */
- searchrect.maxx += tolerance;
- searchrect.miny -= tolerance;
- searchrect.maxy += tolerance;
status = msLayerWhichShapes(lp, searchrect);
if(status == MS_DONE) { /* no overlap */
msLayerClose(lp);
@@ -1334,6 +1334,12 @@
searchrect = qshape->bounds;
#ifdef USE_PROJ
@@ -1341,11 +1347,6 @@
#endif
msLayerClose(lp);
More information about the mapserver-commits
