[mapserver-commits] r9562 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Fri Nov 27 15:01:03 EST 2009
Author: dmorissette
Date: 2009-11-27 15:01:02 -0500 (Fri, 27 Nov 2009)
New Revision: 9562
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapserver.h
Update for 5.6.0-rc1
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2009-11-25 14:50:54 UTC (rev 9561)
+++ trunk/mapserver/HISTORY.TXT 2009-11-27 20:01:02 UTC (rev 9562)
@@ -11,10 +11,11 @@
For a complete change history, please see the Subversion log comments.
-Current Version (SVN trunk):
+Version 5.6.0-rc1 (2009-11-27):
-- Fixed a problem with shape-based queries against projected layers when using a tolerance (#3211)
+- Fixed a problem with shape-based queries against projected layers when
+ using a tolerance (#3211)
- Fixed long expression evaluation (#2123)
@@ -24,7 +25,8 @@
- layer->project flag not being reset properly for drawquerylayer (#673 #2079)
-- OGC SLD: support multi-polygons geometries for filters embedded in an SLD (#3097)
+- OGC SLD: support multi-polygons geometries for filters embedded in
+ an SLD (#3097)
- [WMC] embedded SLD in context does not work with namespace prefix (#3115)
@@ -34,7 +36,8 @@
- Parse PropertyName parameter for wfs requests (#675)
-- Fixed when saving a map, layer->transform isn't written properly in all cases. (#3198)
+- Fixed when saving a map, layer->transform isn't written properly in
+ all cases. (#3198)
- Fixed buffer overflow in oracle spatial driver with large sql data (#2694)
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h 2009-11-25 14:50:54 UTC (rev 9561)
+++ trunk/mapserver/mapserver.h 2009-11-27 20:01:02 UTC (rev 9562)
@@ -33,7 +33,7 @@
** MapServer version - to be updated for every release
-#define MS_VERSION "5.6.0-beta5"
+#define MS_VERSION "5.6.0-rc1"
#define MS_VERSION_MAJOR 5
#define MS_VERSION_MINOR 6
More information about the mapserver-commits
