[mapserver-commits] r9385 - trunk/mapserver
Tue Oct 6 13:54:12 EDT 2009
Author: aboudreault
Date: 2009-10-06 13:54:12 -0400 (Tue, 06 Oct 2009)
New Revision: 9385
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapagg.cpp
   trunk/mapserver/mapgd.c
   trunk/mapserver/mapimagemap.c
   trunk/mapserver/maplabel.c
   trunk/mapserver/mappdf.c
   trunk/mapserver/mapprimitive.c
   trunk/mapserver/maprendering.c
   trunk/mapserver/mapsvg.c
   trunk/mapserver/mapswf.c
   trunk/mapserver/mapsymbol.c
Reversed MAXWIDTH/MINWIDTH change: due to the current API, can't be fixed for 5.6 (#3153)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2009-10-06 17:38:52 UTC (rev 9384)
+++ trunk/mapserver/HISTORY.TXT	2009-10-06 17:54:12 UTC (rev 9385)
@@ -13,9 +13,6 @@
 Current Version (SVN trunk):
-- Fixed some style properties are not scaled with resolution (#3153)
 - Fixed anchor point of vertically stacked bar graphs
 - Fixed TEXT property cannot be removed in the CLASS object. PHP/Mapscript (#3063)
Modified: trunk/mapserver/mapagg.cpp
--- trunk/mapserver/mapagg.cpp	2009-10-06 17:38:52 UTC (rev 9384)
+++ trunk/mapserver/mapagg.cpp	2009-10-06 17:54:12 UTC (rev 9385)
@@ -1044,8 +1044,8 @@
     size = MS_MIN(size, style->maxsize);
     width = style->width*scalefactor;
-    width = MS_MAX(width, (style->minwidth*scalefactor));
-    width = MS_MIN(width, (style->maxwidth*scalefactor));
+    width = MS_MAX(width, style->minwidth);
+    width = MS_MIN(width, style->maxwidth);
     angle = (style->angle) ? style->angle : 0.0;
     angle_radians = angle*MS_DEG_TO_RAD;
@@ -1210,8 +1210,8 @@
     else
         d = 1;
     width = MS_NINT(style->width*scalefactor);
@@ -1575,8 +1575,8 @@
     width = (style->width*scalefactor);
     ox = style->offsetx * scalefactor;
     oy = style->offsety * scalefactor;
@@ -1764,8 +1764,8 @@
     angle_radians = style->angle*MS_DEG_TO_RAD;
Modified: trunk/mapserver/mapgd.c
--- trunk/mapserver/mapgd.c	2009-10-06 17:38:52 UTC (rev 9384)
+++ trunk/mapserver/mapgd.c	2009-10-06 17:54:12 UTC (rev 9385)
@@ -604,8 +604,8 @@
   gdImageSetThickness(hatch, width);
   /* normalize the angle (180 to 0, 0 is east, 90 is north 180 is west) */
@@ -1076,8 +1076,8 @@
   if(style->symbol >= symbolset->numsymbols || style->symbol < 0) return; /* no such symbol, 0 is OK */
   if(fc < 0) return; /* nothing to do */
@@ -1288,8 +1288,8 @@
@@ -1508,8 +1508,8 @@
@@ -1752,8 +1752,8 @@
@@ -2029,8 +2029,8 @@
Modified: trunk/mapserver/mapimagemap.c
--- trunk/mapserver/mapimagemap.c	2009-10-06 17:38:52 UTC (rev 9384)
+++ trunk/mapserver/mapimagemap.c	2009-10-06 17:54:12 UTC (rev 9385)
@@ -989,8 +989,8 @@
   else
       size = MS_NINT(style->size*scalefactor);
-  size = MS_MAX(size, (style->minsize*scalefactor));
-  size = MS_MIN(size, (style->maxsize*scalefactor));
+  size = MS_MAX(size, style->minsize);
+  size = MS_MIN(size, style->maxsize);
   if(style->symbol > symbolset->numsymbols || style->symbol < 0) return; /* no such symbol, 0 is OK */
 /* if(fc<0 && oc<0) return; // nothing to do */
@@ -1197,8 +1197,8 @@
   else
   if (suppressEmpty && p->numvalues==0) return;/* suppress area with empty title */
@@ -1410,8 +1410,8 @@
   else
 /* DEBUG_IF printf ("a"); */
 /* if(fc==-1 && oc!=-1) { // use msDrawLineSymbolIM() instead (POLYLINE) */
Modified: trunk/mapserver/maplabel.c
--- trunk/mapserver/maplabel.c	2009-10-06 17:38:52 UTC (rev 9384)
+++ trunk/mapserver/maplabel.c	2009-10-06 17:54:12 UTC (rev 9385)
@@ -779,8 +779,8 @@
     char *font=NULL;
     size = label->size*scalefactor;
-    size = MS_MAX(size, (label->minsize*scalefactor));
-    size = MS_MIN(size, (label->maxsize*scalefactor));
+    size = MS_MAX(size, label->minsize);
+    size = MS_MIN(size, label->maxsize);
     font = msLookupHashTable(&(fontset->fonts), label->font);
     if(!font) {
Modified: trunk/mapserver/mappdf.c
--- trunk/mapserver/mappdf.c	2009-10-06 17:38:52 UTC (rev 9384)
+++ trunk/mapserver/mappdf.c	2009-10-06 17:54:12 UTC (rev 9385)
@@ -806,8 +806,8 @@
     else
Modified: trunk/mapserver/mapprimitive.c
--- trunk/mapserver/mapprimitive.c	2009-10-06 17:38:52 UTC (rev 9384)
+++ trunk/mapserver/mapprimitive.c	2009-10-06 17:54:12 UTC (rev 9385)
@@ -1622,8 +1622,8 @@
   if(!font) {
Modified: trunk/mapserver/maprendering.c
--- trunk/mapserver/maprendering.c	2009-10-06 17:38:52 UTC (rev 9384)
+++ trunk/mapserver/maprendering.c	2009-10-06 17:54:12 UTC (rev 9385)
@@ -102,8 +102,8 @@
     if(MS_VALID_COLOR(s->outlinecolor)) {
         s->outlinewidth =  src->width * scalefactor;
-        s->outlinewidth = MS_MAX(s->outlinewidth, (src->minwidth*scalefactor));
-        s->outlinewidth = MS_MIN(s->outlinewidth, (src->maxwidth*scalefactor));
+        s->outlinewidth = MS_MAX(s->outlinewidth, src->minwidth);
+        s->outlinewidth = MS_MIN(s->outlinewidth, src->maxwidth);
     } else {
         s->outlinewidth = 0;
@@ -417,9 +417,9 @@
             /* store a reference to the renderer to be used for freeing */
             symbol->renderer = renderer;
-            width = style->width * scalefactor;
+			width = style->width * scalefactor;
+            width = MS_MIN(width,style->maxwidth);
+            width = MS_MAX(width,style->minwidth);
             if(style->offsety==-99) {
 				offsetLine = msOffsetPolyline(p,style->offsetx * width,-99);
@@ -588,8 +588,8 @@
 			    if (symbol->sizey)
 			    	scaling = size / symbol->sizey; /* compute the scaling factor (d) on the unrotated symbol */
Modified: trunk/mapserver/mapsvg.c
--- trunk/mapserver/mapsvg.c	2009-10-06 17:38:52 UTC (rev 9384)
+++ trunk/mapserver/mapsvg.c	2009-10-06 17:54:12 UTC (rev 9385)
@@ -549,8 +549,8 @@
@@ -1364,8 +1364,8 @@
Modified: trunk/mapserver/mapswf.c
--- trunk/mapserver/mapswf.c	2009-10-06 17:38:52 UTC (rev 9384)
+++ trunk/mapserver/mapswf.c	2009-10-06 17:54:12 UTC (rev 9385)
@@ -1990,8 +1990,8 @@
     if(style->symbol > symbolset->numsymbols || style->symbol < 0) /* no such symbol, 0 is OK */
       return;
@@ -2120,8 +2120,8 @@
         return;
Modified: trunk/mapserver/mapsymbol.c
--- trunk/mapserver/mapsymbol.c	2009-10-06 17:38:52 UTC (rev 9384)
+++ trunk/mapserver/mapsymbol.c	2009-10-06 17:54:12 UTC (rev 9385)
@@ -745,8 +745,8 @@
   else
   switch(symbolset->symbol[style->symbol]->type) {
