[mapserver-commits] r9386 - trunk/msautotest/pymod
svn at osgeo.org
svn at osgeo.org
Tue Oct 6 14:14:05 EDT 2009
Author: tomkralidis
Date: 2009-10-06 14:14:05 -0400 (Tue, 06 Oct 2009)
New Revision: 9386
trunk/msautotest/pymod/mstestlib.py
add percentage to final report
Modified: trunk/msautotest/pymod/mstestlib.py
--- trunk/msautotest/pymod/mstestlib.py 2009-10-06 17:54:12 UTC (rev 9385)
+++ trunk/msautotest/pymod/mstestlib.py 2009-10-06 18:14:05 UTC (rev 9386)
@@ -330,7 +330,6 @@
print ' no expected file exists, accepting result as expected.'
init_count = init_count + 1
os.rename( 'result/' + out_file, 'expected/' + out_file )
- print 'Test done:\n %d tested skipped\n %d tests succeeded\n %d tests failed\n %d test results initialized' \
- % (skip_count, succeed_count, fail_count, init_count )
+ print 'Test done (%.2f%% success):\n %d tested skipped\n %d tests succeeded\n %d tests failed\n %d test results initialized' \
+ % ((float(succeed_count)/float(succeed_count+fail_count)*100), skip_count, succeed_count, fail_count, init_count)
More information about the mapserver-commits
