[mapserver-commits] r9432 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Fri Oct 9 09:07:50 EDT 2009
Author: tbonfort
Date: 2009-10-09 09:07:50 -0400 (Fri, 09 Oct 2009)
New Revision: 9432
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapagg.cpp
trunk/mapserver/mapdraw.c
trunk/mapserver/mapgd.c
trunk/mapserver/mapimagemap.c
trunk/mapserver/maplabel.c
trunk/mapserver/maplegend.c
trunk/mapserver/mapogl.cpp
trunk/mapserver/mappdf.c
trunk/mapserver/mapscale.c
trunk/mapserver/mapserv.c
trunk/mapserver/mapserver.h
trunk/mapserver/mapswf.c
trunk/mapserver/maputil.c
trunk/mapserver/mapwcs.c
- make RFC55 highres output be friendly with scaledependant rendering (#3157)
- avoid fractured and overlapping glyphs with angle follow (#2812
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2009-10-09 06:49:57 UTC (rev 9431)
+++ trunk/mapserver/HISTORY.TXT 2009-10-09 13:07:50 UTC (rev 9432)
@@ -19,6 +19,10 @@
Version 5.6.0-beta3 (2009-10-07):
+- make RFC55 highres output be friendly with scaledependant rendering (#3157)
+- avoid fractured and overlapping glyphs with angle follow (#2812)
- Fixed SDE layer seg fault (#3152)
- Fixed placement of labels using ANGLE AUTO which were not always positioned
Modified: trunk/mapserver/mapagg.cpp
--- trunk/mapserver/mapagg.cpp 2009-10-09 06:49:57 UTC (rev 9431)
+++ trunk/mapserver/mapagg.cpp 2009-10-09 13:07:50 UTC (rev 9432)
@@ -848,7 +848,7 @@
// Returns a pointer to a newly created imageObj structure.
// a pointer to the AGG renderer is stored in the imageObj, used for caching
-imageObj *msImageCreateAGG(int width, int height, outputFormatObj *format, char *imagepath, char *imageurl, double resolution)
+imageObj *msImageCreateAGG(int width, int height, outputFormatObj *format, char *imagepath, char *imageurl, double resolution, double defresolution)
imageObj *pNewImage = NULL;
@@ -857,7 +857,7 @@
return NULL;
- pNewImage = msImageCreateGD(width, height, format, imagepath, imageurl, resolution);
+ pNewImage = msImageCreateGD(width, height, format, imagepath, imageurl, resolution, defresolution);
if(!pNewImage)
return pNewImage;
@@ -1040,12 +1040,12 @@
size = size*scalefactor;
} else
size = style->size*scalefactor;
- size = MS_MAX(size, style->minsize);
- size = MS_MIN(size, style->maxsize);
+ size = MS_MAX(size, style->minsize*image->resolution_scale_factor);
+ size = MS_MIN(size, style->maxsize*image->resolution_scale_factor);
width = style->width*scalefactor;
- width = MS_MAX(width, style->minwidth);
- width = MS_MIN(width, style->maxwidth);
+ width = MS_MAX(width, style->minwidth*image->resolution_scale_factor);
+ width = MS_MIN(width, style->maxwidth*image->resolution_scale_factor);
angle = (style->angle) ? style->angle : 0.0;
angle_radians = angle*MS_DEG_TO_RAD;
@@ -1195,23 +1195,25 @@
if(style->symbol >= symbolset->numsymbols || style->symbol < 0) return; /* no such symbol, 0 is OK */
symbolObj *symbol = symbolset->symbol[style->symbol];
- ox = style->offsetx*scalefactor;
- oy = style->offsety*scalefactor;
if(style->size == -1) {
size = msSymbolGetDefaultSize(symbolset->symbol[style->symbol]);
size = MS_NINT(size*scalefactor);
} else
size = MS_NINT(style->size*scalefactor);
if (symbol->sizey)
d = size/symbol->sizey; /* compute the scaling factor (d) on the unrotated symbol */
else
d = 1;
width = MS_NINT(style->width*scalefactor);
+ scalefactor = size / style->size;
+ ox = style->offsetx*scalefactor;
+ oy = style->offsety*scalefactor;
@@ -1477,12 +1479,11 @@
else
size = style->size;
- if(size*scalefactor > style->maxsize) scalefactor = (float)style->maxsize/(float)size;
- if(size*scalefactor < style->minsize) scalefactor = (float)style->minsize/(float)size;
- gap = MS_ABS(symbol->gap)* (int) scalefactor;
- label.size = (size * scalefactor);
- // label.minsize = style->minsize;
- // label.maxsize = style->maxsize;
+ label.size = size * scalefactor;
+ label.size = MS_MAX(label.size, style->minsize*image->resolution_scale_factor);
+ label.size = MS_MIN(label.size, style->maxsize*image->resolution_scale_factor);
+ scalefactor = label.size / size;
+ gap = MS_MAX(MS_ABS(symbol->gap)*scalefactor,1);
label.color = style->color;
label.outlinecolor = style->outlinecolor;
@@ -1571,13 +1572,15 @@
size = style->size;
size = (size*scalefactor);
width = (style->width*scalefactor);
+ scalefactor = width/style->width;
ox = style->offsetx * scalefactor;
oy = style->offsety * scalefactor;
@@ -1760,12 +1763,14 @@
} else
angle_radians = style->angle*MS_DEG_TO_RAD;
@@ -1979,11 +1984,12 @@
double size;
size = label->size*scalefactor;
- size = MS_MAX(size, label->minsize);
- size = MS_MIN(size, label->maxsize);
- outlinewidth = label->outlinewidth;
- shadowsizex = label->shadowsizex*scalefactor;
- shadowsizey = label->shadowsizey*scalefactor;
+ size = MS_MAX(size, label->minsize*image->resolution_scale_factor);
+ size = MS_MIN(size, label->maxsize*image->resolution_scale_factor);
+ scalefactor = size / label->size;
+ outlinewidth = label->outlinewidth*image->resolution_scale_factor;
+ shadowsizex = label->shadowsizex*image->resolution_scale_factor;
+ shadowsizey = label->shadowsizey*image->resolution_scale_factor;
if(!fontset) {
msSetError(MS_TTFERR, "No fontset defined.", "msDrawTextAGG()");
@@ -2069,11 +2075,12 @@
char s[11]; /* UTF-8 characters can be up to 6 bytes wide, entities 10 (ϑ) */
if(!fontset) {
msSetError(MS_TTFERR, "No fontset defined.", "msDrawTextLineAGG()");
@@ -2091,9 +2098,30 @@
return(-1);
- /* Iterate over the label line and draw each letter.*/
+ /* Iterate over the label line and draw each letter.
+ * first draw all the outlines and shadows*/
+ if(agg_ocolor.a || agg_scolor.a) {
+ string_ptr = string;
+ for (i = 0; i < labelpath->path.numpoints; i++) {
+ double x, y;
+ double theta;
+ if (msGetNextGlyph(&string_ptr, s) == -1)
+ break; /* Premature end of string??? */
+ theta = labelpath->angles[i];
+ x = labelpath->path.point[i].x;
+ y = labelpath->path.point[i].y;
+ ren->renderGlyphs(x,y,AGG_NO_COLOR,agg_ocolor,
+ size,font,s,theta,agg_scolor,
+ shadowsizex,shadowsizey,
+ outlinewidth);
+ /* then draw the actual text */
double x, y;
double theta;
@@ -2105,8 +2133,8 @@
- ren->renderGlyphs(x,y,agg_color,agg_ocolor,
- size,font,s,theta,agg_scolor,
+ ren->renderGlyphs(x,y,agg_color,AGG_NO_COLOR,
+ size,font,s,theta,AGG_NO_COLOR,
outlinewidth);
Modified: trunk/mapserver/mapdraw.c
--- trunk/mapserver/mapdraw.c 2009-10-09 06:49:57 UTC (rev 9431)
+++ trunk/mapserver/mapdraw.c 2009-10-09 13:07:50 UTC (rev 9432)
@@ -165,7 +165,7 @@
else if( MS_RENDERER_GD(map->outputformat) )
image = msImageCreateGD(map->width, map->height, map->outputformat,
- map->web.imagepath, map->web.imageurl, map->resolution);
+ map->web.imagepath, map->web.imageurl, map->resolution, map->defresolution);
if( image != NULL ) msImageInitGD( image, &map->imagecolor );
msPreAllocateColorsGD(image, map);
@@ -173,14 +173,14 @@
else if( MS_RENDERER_AGG(map->outputformat) )
image = msImageCreateAGG(map->width, map->height, map->outputformat,
if( image != NULL ) msImageInitAGG( image, &map->imagecolor );
#endif
else if( MS_RENDERER_IMAGEMAP(map->outputformat) )
image = msImageCreateIM(map->width, map->height, map->outputformat,
if( image != NULL ) msImageInitIM( image );
else if( MS_RENDERER_RAWDATA(map->outputformat) )
@@ -280,9 +280,7 @@
else if(GET_LAYER(map, i)->symbolscaledenom > 0 && map->scaledenom > 0)
GET_LAYER(map, i)->scalefactor = GET_LAYER(map, i)->symbolscaledenom/map->scaledenom;
else
- GET_LAYER(map, i)->scalefactor = 1;
- GET_LAYER(map, i)->scalefactor *= map->resolution/map->defresolution;
+ GET_LAYER(map, i)->scalefactor *= map->resolution/map->defresolution;
return image;
@@ -725,7 +723,7 @@
if(layer->opacity > 0 && layer->opacity < 100) {
msApplyOutputFormat(&transFormat, image->format, MS_TRUE, MS_NOOVERRIDE, MS_NOOVERRIDE);
- image_draw = msImageCreateGD( image->width, image->height, transFormat, image->imagepath, image->imageurl, map->resolution );
+ image_draw = msImageCreateGD( image->width, image->height, transFormat, image->imagepath, image->imageurl, map->resolution, map->defresolution );
if(!image_draw) {
msSetError(MS_GDERR, "Unable to initialize image.", "msDrawLayer()");
return(MS_FAILURE);
@@ -768,7 +766,7 @@
- image_draw = msImageCreateAGG(image->width, image->height, transFormat, image->imagepath, image->imageurl, map->resolution);
+ image_draw = msImageCreateAGG(image->width, image->height, transFormat, image->imagepath, image->imageurl, map->resolution, map->defresolution);
if(!image_draw) {
return(MS_FAILURE);
@@ -1007,7 +1005,7 @@
/* adapt width (must take scalefactor into account) */
- pStyle->width += (pStyle->outlinewidth / layer->scalefactor) * 2;
+ pStyle->width += (pStyle->outlinewidth / (layer->scalefactor/image->resolution_scale_factor)) * 2;
pStyle->minwidth += pStyle->outlinewidth * 2;
pStyle->maxwidth += pStyle->outlinewidth * 2;
pStyle->size += (pStyle->outlinewidth/layer->scalefactor*(map->resolution/map->defresolution));
@@ -1028,7 +1026,7 @@
/* reset widths to original state */
- pStyle->width -= (pStyle->outlinewidth / layer->scalefactor) * 2;
+ pStyle->width -= (pStyle->outlinewidth / (layer->scalefactor/image->resolution_scale_factor)) * 2;
pStyle->minwidth -= pStyle->outlinewidth * 2;
pStyle->maxwidth -= pStyle->outlinewidth * 2;
pStyle->size -= (pStyle->outlinewidth/layer->scalefactor*(map->resolution/map->defresolution));
Modified: trunk/mapserver/mapgd.c
--- trunk/mapserver/mapgd.c 2009-10-09 06:49:57 UTC (rev 9431)
+++ trunk/mapserver/mapgd.c 2009-10-09 13:07:50 UTC (rev 9432)
@@ -269,7 +269,7 @@
* Utility function to create a GD image. Returns
* a pointer to an imageObj structure.
-imageObj *msImageCreateGD(int width, int height, outputFormatObj *format, char *imagepath, char *imageurl, double resolution)
+imageObj *msImageCreateGD(int width, int height, outputFormatObj *format, char *imagepath, char *imageurl, double resolution, double defresolution)
imageObj *image;
@@ -298,6 +298,7 @@
image->imagepath = NULL;
image->imageurl = NULL;
image->resolution = resolution;
+ image->resolution_scale_factor = resolution/defresolution;
if(imagepath) image->imagepath = strdup(imagepath);
if(imageurl) image->imageurl = strdup(imageurl);
Modified: trunk/mapserver/mapimagemap.c
--- trunk/mapserver/mapimagemap.c 2009-10-09 06:49:57 UTC (rev 9431)
+++ trunk/mapserver/mapimagemap.c 2009-10-09 13:07:50 UTC (rev 9432)
@@ -293,7 +293,7 @@
imageObj *msImageCreateIM(int width, int height, outputFormatObj *format,
- char *imagepath, char *imageurl, double resolution)
+ char *imagepath, char *imageurl, double resolution, double defresolution)
imageObj *image=NULL;
if (setvbuf(stdout, NULL, _IONBF , 0)){
@@ -331,6 +331,7 @@
if( strcasecmp("ON",msGetOutputFormatOption( format, "DXF", "OFF" )) == 0){
dxf = 1;
Modified: trunk/mapserver/maplabel.c
--- trunk/mapserver/maplabel.c 2009-10-09 06:49:57 UTC (rev 9431)
+++ trunk/mapserver/maplabel.c 2009-10-09 13:07:50 UTC (rev 9432)
@@ -779,9 +779,9 @@
char *font=NULL;
+ size = MS_MAX(size, label->minsize*img->resolution_scale_factor);
+ size = MS_MIN(size, label->maxsize*img->resolution_scale_factor);
font = msLookupHashTable(&(fontset->fonts), label->font);
if(!font) {
if(label->font)
Modified: trunk/mapserver/maplegend.c
--- trunk/mapserver/maplegend.c 2009-10-09 06:49:57 UTC (rev 9431)
+++ trunk/mapserver/maplegend.c 2009-10-09 13:07:50 UTC (rev 9432)
@@ -203,10 +203,10 @@
/* create image */
#ifdef USE_AGG
if(MS_RENDERER_AGG(map->outputformat))
- image = msImageCreateAGG(width, height, map->outputformat, map->web.imagepath, map->web.imageurl, map->resolution);
+ image = msImageCreateAGG(width, height, map->outputformat, map->web.imagepath, map->web.imageurl, map->resolution, map->defresolution);
else
#endif
- image = msImageCreateGD(width, height, map->outputformat, map->web.imagepath, map->web.imageurl, map->resolution);
+ image = msImageCreateGD(width, height, map->outputformat, map->web.imagepath, map->web.imageurl, map->resolution, map->defresolution);
/* drop this reference to output format */
msApplyOutputFormat( &format, NULL, MS_NOOVERRIDE, MS_NOOVERRIDE, MS_NOOVERRIDE );
@@ -458,10 +458,10 @@
/* initialize the legend image */
#ifdef USE_AGG
- image = msImageCreateAGG(size_x, size_y, format, map->web.imagepath, map->web.imageurl, map->resolution);
+ image = msImageCreateAGG(size_x, size_y, format, map->web.imagepath, map->web.imageurl, map->resolution, map->defresolution);
else
#endif
- image = msImageCreateGD(size_x, size_y, format, map->web.imagepath, map->web.imageurl, map->resolution);
+ image = msImageCreateGD(size_x, size_y, format, map->web.imagepath, map->web.imageurl, map->resolution, map->defresolution);
msApplyOutputFormat(&format, NULL, MS_NOOVERRIDE, MS_NOOVERRIDE, MS_NOOVERRIDE);
Modified: trunk/mapserver/mapogl.cpp
--- trunk/mapserver/mapogl.cpp 2009-10-09 06:49:57 UTC (rev 9431)
+++ trunk/mapserver/mapogl.cpp 2009-10-09 13:07:50 UTC (rev 9432)
@@ -161,7 +161,7 @@
int msSaveImageOgl(imageObj *img, char *filename, outputFormatObj *format)
- imageObj* gdImg = msImageCreateGD(img->width, img->height, format, filename, NULL, 72);
+ imageObj* gdImg = msImageCreateGD(img->width, img->height, format, filename, NULL, 72, 72);
OglRenderer* ogl = getOglRenderer(img);
ogl->attach(gdImg);
Modified: trunk/mapserver/mappdf.c
--- trunk/mapserver/mappdf.c 2009-10-09 06:49:57 UTC (rev 9431)
+++ trunk/mapserver/mappdf.c 2009-10-09 13:07:50 UTC (rev 9432)
@@ -226,7 +226,7 @@
oImage->img.pdf->imagetmp = (imageObj *)
msCreateDefaultOutputFormat(map, driver),
return oImage;
@@ -1484,7 +1484,7 @@
image_tmp = msImageCreateGD(map->width, map->height,
else
Modified: trunk/mapserver/mapscale.c
--- trunk/mapserver/mapscale.c 2009-10-09 06:49:57 UTC (rev 9431)
+++ trunk/mapserver/mapscale.c 2009-10-09 13:07:50 UTC (rev 9432)
@@ -263,7 +263,7 @@
/* create image */
image = msImageCreateGD(map->scalebar.width, sy, format,
Modified: trunk/mapserver/mapserv.c
--- trunk/mapserver/mapserv.c 2009-10-09 06:49:57 UTC (rev 9431)
+++ trunk/mapserver/mapserv.c 2009-10-09 13:07:50 UTC (rev 9432)
@@ -1508,10 +1508,10 @@
#ifdef USE_AGG
if(MS_RENDERER_AGG(mapserv->map->outputformat))
- img = msImageCreateAGG(mapserv->map->legend.keysizex, mapserv->map->legend.keysizey, format, mapserv->map->web.imagepath, mapserv->map->web.imageurl, mapserv->map->resolution);
+ img = msImageCreateAGG(mapserv->map->legend.keysizex, mapserv->map->legend.keysizey, format, mapserv->map->web.imagepath, mapserv->map->web.imageurl, mapserv->map->resolution, mapserv->map->defresolution);
else
#endif
- img = msImageCreateGD(mapserv->map->legend.keysizex, mapserv->map->legend.keysizey, format, mapserv->map->web.imagepath, mapserv->map->web.imageurl, mapserv->map->resolution);
+ img = msImageCreateGD(mapserv->map->legend.keysizex, mapserv->map->legend.keysizey, format, mapserv->map->web.imagepath, mapserv->map->web.imageurl, mapserv->map->resolution, mapserv->map->defresolution);
/* allocate the background color */
#ifdef USE_AGG
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h 2009-10-09 06:49:57 UTC (rev 9431)
+++ trunk/mapserver/mapserver.h 2009-10-09 13:07:50 UTC (rev 9432)
@@ -1472,6 +1472,8 @@
#endif
int width, height;
double resolution;
+ double resolution_scale_factor;
char *imagepath, *imageurl;
outputFormatObj *format;
@@ -2023,7 +2025,7 @@
/* Prototypes for functions in mapimagemap.c */
-MS_DLL_EXPORT imageObj *msImageCreateIM(int width, int height, outputFormatObj *format, char *imagepath, char *imageurl, double resolution);
+MS_DLL_EXPORT imageObj *msImageCreateIM(int width, int height, outputFormatObj *format, char *imagepath, char *imageurl, double resolution, double defresolution);
MS_DLL_EXPORT imageObj *msImageLoadIM( const char *filename );
MS_DLL_EXPORT imageObj *msImageLoadGD( const char *filename );
MS_DLL_EXPORT imageObj *msImageLoadGDCtx( gdIOCtx *ctx, const char *driver );
@@ -2050,7 +2052,7 @@
MS_DLL_EXPORT imageObj *msImageLoadGDCtx(gdIOCtx* ctx, const char *driver);
MS_DLL_EXPORT int msCompareColors(colorObj *c1, colorObj *c2);
MS_DLL_EXPORT void msPreAllocateColorsGD(imageObj *image, mapObj *map);
-MS_DLL_EXPORT imageObj *msImageCreateGD(int width, int height, outputFormatObj *format, char *imagepath, char *imageurl, double resolution);
+MS_DLL_EXPORT imageObj *msImageCreateGD(int width, int height, outputFormatObj *format, char *imagepath, char *imageurl, double resolution, double defresolution);
MS_DLL_EXPORT void msImageInitGD( imageObj *image, colorObj *background );
MS_DLL_EXPORT int msImageSetPenGD(gdImagePtr img, colorObj *color);
@@ -2081,7 +2083,7 @@
/* Prototypes for functions in mapagg.cpp */
-MS_DLL_EXPORT imageObj *msImageCreateAGG(int width, int height, outputFormatObj *format, char *imagepath, char *imageurl, double resolution);
+MS_DLL_EXPORT imageObj *msImageCreateAGG(int width, int height, outputFormatObj *format, char *imagepath, char *imageurl, double resolution, double defresolution);
MS_DLL_EXPORT void msImageInitAGG( imageObj *image, colorObj *background );
MS_DLL_EXPORT int msSaveImageAGG(imageObj *img, char *filename, outputFormatObj *format);
Modified: trunk/mapserver/mapswf.c
--- trunk/mapserver/mapswf.c 2009-10-09 06:49:57 UTC (rev 9431)
+++ trunk/mapserver/mapswf.c 2009-10-09 13:07:50 UTC (rev 9432)
@@ -1146,7 +1146,7 @@
((SWFObj *)image->img.swf)->imagetmp = (imageObj *)
free(driver);
return image;
@@ -2849,7 +2849,7 @@
bFreeImage = 1;
else
@@ -3444,7 +3444,7 @@
imagetmp = msImageCreateGD(map->width, map->height,
bFreeImage = 1;
else
Modified: trunk/mapserver/maputil.c
--- trunk/mapserver/maputil.c 2009-10-09 06:49:57 UTC (rev 9431)
+++ trunk/mapserver/maputil.c 2009-10-09 13:07:50 UTC (rev 9432)
@@ -1384,7 +1384,7 @@
if( MS_RENDERER_GD(format) )
image = msImageCreateGD(width, height, format,
- imagepath, imageurl, map->resolution);
+ imagepath, imageurl, map->resolution, map->defresolution);
if( image != NULL && map) msImageInitGD( image, &map->imagecolor );
else if(MS_RENDERER_PLUGIN(format)) {
@@ -1410,7 +1410,7 @@
else if( MS_RENDERER_AGG(format) )
image = msImageCreateAGG(width, height, format,
if( image != NULL && map) msImageInitAGG( image, &map->imagecolor );
#endif
@@ -1466,7 +1466,7 @@
else if( MS_RENDERER_IMAGEMAP(format) )
image = msImageCreateIM(width, height, format,
#ifdef USE_MING_FLASH
Modified: trunk/mapserver/mapwcs.c
--- trunk/mapserver/mapwcs.c 2009-10-09 06:49:57 UTC (rev 9431)
+++ trunk/mapserver/mapwcs.c 2009-10-09 13:07:50 UTC (rev 9432)
@@ -1703,11 +1703,11 @@
msSetError(MS_WCSERR, "The map outputformat is missing!", "msWCSGetCoverage()");
return msWCSException(map, NULL, NULL, params->version );
} else if( MS_RENDERER_GD(map->outputformat) ) {
- image = msImageCreateGD(map->width, map->height, map->outputformat, map->web.imagepath, map->web.imageurl, map->resolution);
+ image = msImageCreateGD(map->width, map->height, map->outputformat, map->web.imagepath, map->web.imageurl, map->resolution, map->defresolution);
#ifdef USE_AGG
} else if( MS_RENDERER_AGG(map->outputformat) ) {
- image = msImageCreateAGG(map->width, map->height, map->outputformat, map->web.imagepath, map->web.imageurl, map->resolution);
+ image = msImageCreateAGG(map->width, map->height, map->outputformat, map->web.imagepath, map->web.imageurl, map->resolution, map->defresolution);
#endif
} else if( MS_RENDERER_RAWDATA(map->outputformat) ) {
More information about the mapserver-commits
