[mapserver-commits] r9433 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Fri Oct 9 15:04:03 EDT 2009
Author: aboudreault
Date: 2009-10-09 15:04:02 -0400 (Fri, 09 Oct 2009)
New Revision: 9433
trunk/mapserver/mapagg.cpp
trunk/mapserver/mapdraw.c
trunk/mapserver/mapgd.c
trunk/mapserver/mapimagemap.c
trunk/mapserver/maplabel.c
trunk/mapserver/mapserver.h
Renamed resolution factor variable name since it isn't related to the scale
Modified: trunk/mapserver/mapagg.cpp
--- trunk/mapserver/mapagg.cpp 2009-10-09 13:07:50 UTC (rev 9432)
+++ trunk/mapserver/mapagg.cpp 2009-10-09 19:04:02 UTC (rev 9433)
@@ -1040,12 +1040,12 @@
size = size*scalefactor;
} else
size = style->size*scalefactor;
- size = MS_MAX(size, style->minsize*image->resolution_scale_factor);
- size = MS_MIN(size, style->maxsize*image->resolution_scale_factor);
+ size = MS_MAX(size, style->minsize*image->resolutionfactor);
+ size = MS_MIN(size, style->maxsize*image->resolutionfactor);
width = style->width*scalefactor;
- width = MS_MAX(width, style->minwidth*image->resolution_scale_factor);
- width = MS_MIN(width, style->maxwidth*image->resolution_scale_factor);
+ width = MS_MAX(width, style->minwidth*image->resolutionfactor);
+ width = MS_MIN(width, style->maxwidth*image->resolutionfactor);
angle = (style->angle) ? style->angle : 0.0;
angle_radians = angle*MS_DEG_TO_RAD;
@@ -1201,15 +1201,15 @@
size = MS_NINT(size*scalefactor);
} else
size = MS_NINT(style->size*scalefactor);
if (symbol->sizey)
d = size/symbol->sizey; /* compute the scaling factor (d) on the unrotated symbol */
else
d = 1;
width = MS_NINT(style->width*scalefactor);
scalefactor = size / style->size;
ox = style->offsetx*scalefactor;
@@ -1480,8 +1480,8 @@
else
size = style->size;
label.size = size * scalefactor;
- label.size = MS_MAX(label.size, style->minsize*image->resolution_scale_factor);
- label.size = MS_MIN(label.size, style->maxsize*image->resolution_scale_factor);
+ label.size = MS_MAX(label.size, style->minsize*image->resolutionfactor);
+ label.size = MS_MIN(label.size, style->maxsize*image->resolutionfactor);
scalefactor = label.size / size;
gap = MS_MAX(MS_ABS(symbol->gap)*scalefactor,1);
@@ -1572,12 +1572,12 @@
size = style->size;
size = (size*scalefactor);
width = (style->width*scalefactor);
scalefactor = width/style->width;
@@ -1763,12 +1763,12 @@
} else
@@ -1984,12 +1984,12 @@
double size;
size = label->size*scalefactor;
- size = MS_MAX(size, label->minsize*image->resolution_scale_factor);
- size = MS_MIN(size, label->maxsize*image->resolution_scale_factor);
+ size = MS_MAX(size, label->minsize*image->resolutionfactor);
+ size = MS_MIN(size, label->maxsize*image->resolutionfactor);
scalefactor = size / label->size;
- outlinewidth = label->outlinewidth*image->resolution_scale_factor;
- shadowsizex = label->shadowsizex*image->resolution_scale_factor;
- shadowsizey = label->shadowsizey*image->resolution_scale_factor;
+ outlinewidth = label->outlinewidth*image->resolutionfactor;
+ shadowsizex = label->shadowsizex*image->resolutionfactor;
+ shadowsizey = label->shadowsizey*image->resolutionfactor;
if(!fontset) {
msSetError(MS_TTFERR, "No fontset defined.", "msDrawTextAGG()");
@@ -2075,12 +2075,12 @@
char s[11]; /* UTF-8 characters can be up to 6 bytes wide, entities 10 (ϑ) */
if(!fontset) {
msSetError(MS_TTFERR, "No fontset defined.", "msDrawTextLineAGG()");
Modified: trunk/mapserver/mapdraw.c
--- trunk/mapserver/mapdraw.c 2009-10-09 13:07:50 UTC (rev 9432)
+++ trunk/mapserver/mapdraw.c 2009-10-09 19:04:02 UTC (rev 9433)
@@ -1005,7 +1005,7 @@
/* adapt width (must take scalefactor into account) */
- pStyle->width += (pStyle->outlinewidth / (layer->scalefactor/image->resolution_scale_factor)) * 2;
+ pStyle->width += (pStyle->outlinewidth / (layer->scalefactor/image->resolutionfactor)) * 2;
pStyle->minwidth += pStyle->outlinewidth * 2;
pStyle->maxwidth += pStyle->outlinewidth * 2;
pStyle->size += (pStyle->outlinewidth/layer->scalefactor*(map->resolution/map->defresolution));
@@ -1026,7 +1026,7 @@
/* reset widths to original state */
- pStyle->width -= (pStyle->outlinewidth / (layer->scalefactor/image->resolution_scale_factor)) * 2;
+ pStyle->width -= (pStyle->outlinewidth / (layer->scalefactor/image->resolutionfactor)) * 2;
pStyle->minwidth -= pStyle->outlinewidth * 2;
pStyle->maxwidth -= pStyle->outlinewidth * 2;
pStyle->size -= (pStyle->outlinewidth/layer->scalefactor*(map->resolution/map->defresolution));
Modified: trunk/mapserver/mapgd.c
--- trunk/mapserver/mapgd.c 2009-10-09 13:07:50 UTC (rev 9432)
+++ trunk/mapserver/mapgd.c 2009-10-09 19:04:02 UTC (rev 9433)
@@ -298,7 +298,7 @@
image->imagepath = NULL;
image->imageurl = NULL;
image->resolution = resolution;
- image->resolution_scale_factor = resolution/defresolution;
+ image->resolutionfactor = resolution/defresolution;
if(imagepath) image->imagepath = strdup(imagepath);
if(imageurl) image->imageurl = strdup(imageurl);
Modified: trunk/mapserver/mapimagemap.c
--- trunk/mapserver/mapimagemap.c 2009-10-09 13:07:50 UTC (rev 9432)
+++ trunk/mapserver/mapimagemap.c 2009-10-09 19:04:02 UTC (rev 9433)
@@ -331,7 +331,7 @@
if( strcasecmp("ON",msGetOutputFormatOption( format, "DXF", "OFF" )) == 0){
dxf = 1;
Modified: trunk/mapserver/maplabel.c
--- trunk/mapserver/maplabel.c 2009-10-09 13:07:50 UTC (rev 9432)
+++ trunk/mapserver/maplabel.c 2009-10-09 19:04:02 UTC (rev 9433)
@@ -779,8 +779,8 @@
char *font=NULL;
- size = MS_MAX(size, label->minsize*img->resolution_scale_factor);
- size = MS_MIN(size, label->maxsize*img->resolution_scale_factor);
+ size = MS_MAX(size, label->minsize*img->resolutionfactor);
+ size = MS_MIN(size, label->maxsize*img->resolutionfactor);
font = msLookupHashTable(&(fontset->fonts), label->font);
if(!font) {
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h 2009-10-09 13:07:50 UTC (rev 9432)
+++ trunk/mapserver/mapserver.h 2009-10-09 19:04:02 UTC (rev 9433)
@@ -1472,7 +1472,7 @@
#endif
int width, height;
double resolution;
- double resolution_scale_factor;
+ double resolutionfactor;
char *imagepath, *imageurl;
More information about the mapserver-commits
