[mapserver-commits] r9468 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Thu Oct 15 17:12:06 EDT 2009
Author: tbonfort
Date: 2009-10-15 17:12:06 -0400 (Thu, 15 Oct 2009)
New Revision: 9468
trunk/mapserver/mapagg.cpp
remove compilation warnings
Modified: trunk/mapserver/mapagg.cpp
--- trunk/mapserver/mapagg.cpp 2009-10-15 20:49:33 UTC (rev 9467)
+++ trunk/mapserver/mapagg.cpp 2009-10-15 21:12:06 UTC (rev 9468)
@@ -1483,7 +1483,7 @@
label.size = MS_MAX(label.size, style->minsize*image->resolutionfactor);
label.size = MS_MIN(label.size, style->maxsize*image->resolutionfactor);
scalefactor = label.size / size;
- gap = MS_MAX(MS_ABS(symbol->gap)*scalefactor,1);
+ gap = MS_MAX(MS_NINT(MS_ABS(symbol->gap)*scalefactor),1);
label.color = style->color;
label.outlinecolor = style->outlinecolor;
@@ -1589,7 +1589,7 @@
int nonzeroexists=0;
for (i=0; i<symbol->patternlength; i++)
- symbol_pattern[i] = symbol->pattern[i]*scalefactor;
+ symbol_pattern[i] = MS_NINT(symbol->pattern[i]*scalefactor);
if(symbol_pattern[i]>0)
nonzeroexists=1;
@@ -1837,8 +1837,8 @@
for (int i=0; i<symbol->patternlength; i+=2) {
if (i < symbol->patternlength-1) {
/* scale the pattern and add it*/
- symbol_pattern[i+1] = symbol->pattern[i+1]*scalefactor;
+ symbol_pattern[i] = MS_MAX(MS_NINT(symbol->pattern[i]*scalefactor),1);
+ symbol_pattern[i+1] = MS_MAX(MS_NINT(symbol->pattern[i+1]*scalefactor),1);
dash.add_dash(symbol_pattern[i], symbol_pattern[i+1]);
@@ -1991,9 +1991,9 @@
size = MS_MAX(size, label->minsize*image->resolutionfactor);
size = MS_MIN(size, label->maxsize*image->resolutionfactor);
scalefactor = size / label->size;
- outlinewidth = label->outlinewidth*image->resolutionfactor;
- shadowsizex = label->shadowsizex*image->resolutionfactor;
- shadowsizey = label->shadowsizey*image->resolutionfactor;
+ outlinewidth = MS_NINT(label->outlinewidth*image->resolutionfactor);
+ shadowsizex = MS_NINT(label->shadowsizex*image->resolutionfactor);
+ shadowsizey = MS_NINT(label->shadowsizey*image->resolutionfactor);
if(!fontset) {
msSetError(MS_TTFERR, "No fontset defined.", "msDrawTextAGG()");
@@ -2082,9 +2082,9 @@
if(!fontset) {
msSetError(MS_TTFERR, "No fontset defined.", "msDrawTextLineAGG()");
More information about the mapserver-commits
