[mapserver-commits] r9469 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Thu Oct 15 21:38:34 EDT 2009
Author: assefa
Date: 2009-10-15 21:38:33 -0400 (Thu, 15 Oct 2009)
New Revision: 9469
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapwfslayer.c
Correct cases where a valid WFS Layer might return errors if map extent does not overlap the layer extent (#3139)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2009-10-15 21:12:06 UTC (rev 9468)
+++ trunk/mapserver/HISTORY.TXT 2009-10-16 01:38:33 UTC (rev 9469)
@@ -15,6 +15,9 @@
Current Version (SVN trunk):
+- Correct cases where a valid WFS Layer might return errors if
+ map extent does not overlap the layer extent (#3139)
- fix problem with 0-length line patterns in AGG
- Fixed problem of text/html WMS GetFeatureInfo which was returning HTML
Modified: trunk/mapserver/mapwfslayer.c
--- trunk/mapserver/mapwfslayer.c 2009-10-15 21:12:06 UTC (rev 9468)
+++ trunk/mapserver/mapwfslayer.c 2009-10-16 01:38:33 UTC (rev 9469)
@@ -447,7 +447,7 @@
rectObj rect; /* set by WhichShapes */
char *pszGetUrl;
int nStatus; /* HTTP status */
- int bLayerOpened; /* False until msWFSLayerOpen() is called*/
+ int bLayerHasValidGML; /* False until msWFSLayerWhichShapes() is called and determines the result GML is valid with features*/
} msWFSLayerInfo;
@@ -467,7 +467,6 @@
psInfo->rect.miny = psInfo->rect.maxy = 0;
psInfo->pszGetUrl = NULL;
psInfo->nStatus = 0;
- psInfo->bLayerOpened = MS_FALSE;
else
@@ -846,7 +845,6 @@
if (msWFSLayerWhichShapes(lp, psInfo->rect) == MS_FAILURE)
status = MS_FAILURE;
- psInfo->bLayerOpened = MS_TRUE;
return status;
#else
@@ -911,6 +909,90 @@
+ * msWFSLayerGetShape()
+int msWFSLayerGetShape(layerObj *layer, shapeObj *shape, int tile,
+ long record)
+ msWFSLayerInfo* psInfo = NULL;
+ if(layer != NULL && layer->wfslayerinfo != NULL)
+ psInfo = (msWFSLayerInfo*)layer->wfslayerinfo;
+ else
+ msSetError(MS_WFSERR, "Layer is not opened.", "msWFSLayerGetShape()");
+ return MS_FAILURE;
+ if(psInfo->bLayerHasValidGML)
+ return msOGRLayerGetShape(layer, shape, tile, record);
+ else
+ /* Layer is successful, but there is no data to process */
+ msFreeShape(shape);
+ shape->type = MS_SHAPE_NULL;
+ * msWFSLayerGetNextShape()
+int msWFSLayerNextShape(layerObj *layer, shapeObj *shape)
+ else
+ msSetError(MS_WFSERR, "Layer is not opened.", "msWFSLayerNextShape()");
+ return msOGRLayerNextShape(layer, shape);
+ else
+ * msWFSLayerGetExtent()
+int msWFSLayerGetExtent(layerObj *layer, rectObj *extent)
+ else
+ msSetError(MS_WFSERR, "Layer is not opened.", "msWFSLayerGetExtent()");
+ return msOGRLayerGetExtent(layer, extent);
+ else
+ msSetError(MS_WFSERR, "Unable to get extents for this layer.", "msWFSLayerGetExtent()");
* msWFSLayerGetItems()
@@ -922,7 +1004,25 @@
/* It could also be implemented to call DescribeFeatureType for */
/* this layer, but we don't need to do it so why waste resources? */
- return msOGRLayerGetItems(layer);
+ else
+ msSetError(MS_WFSERR, "Layer is not opened.", "msWFSLayerGetItems()");
+ return msOGRLayerGetItems(layer);
+ else
+ layer->numitems = 0;
+ layer->items = NULL;
+ return MS_SUCCESS;
@@ -1091,7 +1191,10 @@
return status;
status = msOGRLayerWhichShapes(lp, rect);
+ /* Mark that the OGR Layer is valid */
+ psInfo->bLayerHasValidGML = MS_TRUE;
return status;
#else
@@ -1189,12 +1292,12 @@
layer->vtable->LayerOpen = msWFSLayerOpenVT;
layer->vtable->LayerIsOpen = msWFSLayerIsOpen;
layer->vtable->LayerWhichShapes = msWFSLayerWhichShapes;
- layer->vtable->LayerNextShape = msOGRLayerNextShape; /* yes, OGR */
- layer->vtable->LayerResultsGetShape = msOGRLayerGetShape; /* yes, OGR but no special version, use ...GetShape() */
- layer->vtable->LayerGetShape = msOGRLayerGetShape; /* yes, OGR */
+ layer->vtable->LayerNextShape = msWFSLayerNextShape;
+ layer->vtable->LayerResultsGetShape = msWFSLayerGetShape;
+ layer->vtable->LayerGetShape = msWFSLayerGetShape;
layer->vtable->LayerClose = msWFSLayerClose;
layer->vtable->LayerGetItems = msWFSLayerGetItems;
- layer->vtable->LayerGetExtent = msOGRLayerGetExtent; /* yes, OGR */
+ layer->vtable->LayerGetExtent = msWFSLayerGetExtent;
/* layer->vtable->LayerGetAutoStyle, use default */
/* layer->vtable->LayerApplyFilterToLayer, use default */
/* layer->vtable->LayerCloseConnection, use default */
More information about the mapserver-commits
