[mapserver-commits] r9845 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Sun Feb 21 11:24:38 EST 2010
Author: jimk
Date: 2010-02-21 11:24:36 -0500 (Sun, 21 Feb 2010)
New Revision: 9845
trunk/mapserver/maporaclespatial.c
Fix tabs by converting to spaces.
Modified: trunk/mapserver/maporaclespatial.c
--- trunk/mapserver/maporaclespatial.c 2010-02-21 16:00:28 UTC (rev 9844)
+++ trunk/mapserver/maporaclespatial.c 2010-02-21 16:24:36 UTC (rev 9845)
@@ -112,69 +112,69 @@
item_text item_text_array_query[QUERY_SIZE];
typedef
- struct
- /*Oracle handlers (global to connection)*/
- OCIEnv *envhp;
- OCIError *errhp;
- OCISvcCtx *svchp;
- int last_oci_status;
- text last_oci_error[2048];
- /* This references counter is to avoid the cache freed if there are other layers that could use it */
- int ref_count;
- } msOracleSpatialHandler;
+ struct
+ /*Oracle handlers (global to connection)*/
+ OCIEnv *envhp;
+ OCIError *errhp;
+ OCISvcCtx *svchp;
+ int last_oci_status;
+ text last_oci_error[2048];
+ /* This references counter is to avoid the cache freed if there are other layers that could use it */
+ int ref_count;
+ } msOracleSpatialHandler;
typedef
- struct
- /* Oracle data handlers (global to connection) */
- OCIDescribe *dschp;
- OCIType *tdo;
- } msOracleSpatialDataHandler;
+ struct
+ /* Oracle data handlers (global to connection) */
+ OCIDescribe *dschp;
+ OCIType *tdo;
+ } msOracleSpatialDataHandler;
typedef
- struct
- OCIStmt *stmthp;
+ struct
+ OCIStmt *stmthp;
- /* fetch data buffer */
- ub4 rows_count; /* total number of rows (so far) within cursor */
- ub4 row_num; /* current row index within cursor results */
- ub4 rows_fetched; /* total number of rows fetched into our buffer */
- ub4 row; /* current row index within our buffer */
+ /* fetch data buffer */
+ ub4 rows_count; /* total number of rows (so far) within cursor */
+ ub4 row_num; /* current row index within cursor results */
+ ub4 rows_fetched; /* total number of rows fetched into our buffer */
+ ub4 row; /* current row index within our buffer */
- item_text_array *items; /* items buffer */
- item_text_array_query *items_query; /* items buffer */
- SDOGeometryObj *obj[ARRAY_SIZE]; /* spatial object buffer */
- SDOGeometryInd *ind[ARRAY_SIZE]; /* object indicator (null) buffer */
+ item_text_array *items; /* items buffer */
+ item_text_array_query *items_query; /* items buffer */
+ SDOGeometryObj *obj[ARRAY_SIZE]; /* spatial object buffer */
+ SDOGeometryInd *ind[ARRAY_SIZE]; /* object indicator (null) buffer */
- int uniqueidindex; /*allows to keep whic attribute id index is used as unique id*/
+ int uniqueidindex; /*allows to keep whic attribute id index is used as unique id*/
- } msOracleSpatialStatement;
+ } msOracleSpatialStatement;
typedef
- struct
- /* oracle handlers */
- msOracleSpatialHandler *orahandlers;
- /* oracle data handlers */
- msOracleSpatialDataHandler *oradatahandlers;
- msOracleSpatialStatement *orastmt;
- /* Following items are setup by WhichShapes
- * used by NextShape, ResultGetShape
- * disposed by CloseLayer (if set)
- msOracleSpatialStatement *orastmt2;
- } msOracleSpatialLayerInfo;
+ struct
+ /* oracle handlers */
+ msOracleSpatialHandler *orahandlers;
+ /* oracle data handlers */
+ msOracleSpatialDataHandler *oradatahandlers;
+ msOracleSpatialStatement *orastmt;
+ /* Following items are setup by WhichShapes
+ * used by NextShape, ResultGetShape
+ * disposed by CloseLayer (if set)
+ msOracleSpatialStatement *orastmt2;
+ } msOracleSpatialLayerInfo;
static OCIType *ordinates_tdo = NULL;
static OCIArray *ordinates;
/* local prototypes */
static int TRY( msOracleSpatialHandler *hand, sword status );
static int ERROR( char *routine, msOracleSpatialHandler *hand, msOracleSpatialDataHandler *dthand );
@@ -264,18 +264,18 @@
OCIType *get_tdo(char *typename, msOracleSpatialHandler *hand, msOracleSpatialDataHandler *dthand )
- OCIParam *paramp = NULL;
- OCIRef *type_ref = NULL;
- OCIType *tdoe = NULL;
- int success = 0;
+ OCIParam *paramp = NULL;
+ OCIRef *type_ref = NULL;
+ OCIType *tdoe = NULL;
+ int success = 0;
- success = TRY( hand, OCIDescribeAny(hand->svchp, hand->errhp, (text *)typename, (ub4)strlen((char *)typename), OCI_OTYPE_NAME, (ub1)1, (ub1)OCI_PTYPE_TYPE, dthand->dschp))
- &&TRY( hand, OCIAttrGet((dvoid *)dthand->dschp, (ub4)OCI_HTYPE_DESCRIBE, (dvoid *)¶mp, (ub4 *)0, (ub4)OCI_ATTR_PARAM, hand->errhp))
- &&TRY( hand, OCIAttrGet((dvoid *)paramp, (ub4)OCI_DTYPE_PARAM, (dvoid *)&type_ref, (ub4 *)0, (ub4)OCI_ATTR_REF_TDO, hand->errhp))
- &&TRY( hand, OCIObjectPin(hand->envhp, hand->errhp, type_ref, (OCIComplexObject *)0, OCI_PIN_ANY, OCI_DURATION_SESSION, OCI_LOCK_NONE, (dvoid **)&tdoe));
+ success = TRY( hand, OCIDescribeAny(hand->svchp, hand->errhp, (text *)typename, (ub4)strlen((char *)typename), OCI_OTYPE_NAME, (ub1)1, (ub1)OCI_PTYPE_TYPE, dthand->dschp))
+ &&TRY( hand, OCIAttrGet((dvoid *)dthand->dschp, (ub4)OCI_HTYPE_DESCRIBE, (dvoid *)¶mp, (ub4 *)0, (ub4)OCI_ATTR_PARAM, hand->errhp))
+ &&TRY( hand, OCIAttrGet((dvoid *)paramp, (ub4)OCI_DTYPE_PARAM, (dvoid *)&type_ref, (ub4 *)0, (ub4)OCI_ATTR_REF_TDO, hand->errhp))
+ &&TRY( hand, OCIObjectPin(hand->envhp, hand->errhp, type_ref, (OCIComplexObject *)0, OCI_PIN_ANY, OCI_DURATION_SESSION, OCI_LOCK_NONE, (dvoid **)&tdoe));
if (success)
- return tdoe;
+ return tdoe;
/* if failure, return NULL*/
return NULL;
@@ -526,35 +526,35 @@
/* allocate stmthp */
success = TRY( hand, OCIHandleAlloc( (dvoid *)hand->envhp, (dvoid **)&sthand->stmthp, (ub4)OCI_HTYPE_STMT, (size_t)0, (dvoid **)0 ) );
- sthand->rows_count = 0;
- sthand->row_num = 0;
- sthand->rows_fetched = 0;
- sthand->row = 0;
- sthand->items = NULL;
- sthand->items_query = NULL;
+ sthand->rows_count = 0;
+ sthand->row_num = 0;
+ sthand->rows_fetched = 0;
+ sthand->row = 0;
+ sthand->items = NULL;
+ sthand->items_query = NULL;
- //fprintf(stderr, "Creating statement handle at %p\n", sthand->stmthp);
+ //fprintf(stderr, "Creating statement handle at %p\n", sthand->stmthp);
return success;
/* create statement handle from database connection */
static void msOCIFinishStatement( msOracleSpatialStatement *sthand )
- if(sthand != NULL)
- //fprintf(stderr, "Freeing statement handle at %p\n", sthand->stmthp);
+ if(sthand != NULL)
+ //fprintf(stderr, "Freeing statement handle at %p\n", sthand->stmthp);
- if (sthand->stmthp != NULL)
- OCIHandleFree( (dvoid *)sthand->stmthp, (ub4)OCI_HTYPE_STMT );
- if (sthand->items != NULL)
- free( sthand->items );
- if (sthand->items_query != NULL)
- free( sthand->items_query );
- memset(sthand, 0, sizeof( msOracleSpatialStatement ) );
- free(sthand);
+ if (sthand->stmthp != NULL)
+ OCIHandleFree( (dvoid *)sthand->stmthp, (ub4)OCI_HTYPE_STMT );
+ if (sthand->items != NULL)
+ free( sthand->items );
+ if (sthand->items_query != NULL)
+ free( sthand->items_query );
+ memset(sthand, 0, sizeof( msOracleSpatialStatement ) );
+ free(sthand);
static int msOCISetDataHandlers(msOracleSpatialHandler *hand, msOracleSpatialDataHandler *dthand)
@@ -653,9 +653,9 @@
static void msOCIClearLayerInfo( msOracleSpatialLayerInfo *layerinfo )
if (layerinfo != NULL) {
- memset( layerinfo, 0, sizeof( msOracleSpatialLayerInfo ) );
- free(layerinfo);
+ memset( layerinfo, 0, sizeof( msOracleSpatialLayerInfo ) );
+ free(layerinfo);
/*function that creates the correct sql for geoditical srid for version 9i*/
@@ -1384,7 +1384,7 @@
if (data3d)
n = msOCIGet3DOrdinates( hand, obj, start, end, points.point );
else if (data4d)
- n = msOCIGet4DOrdinates( hand, obj, start, end, points.point );
+ n = msOCIGet4DOrdinates( hand, obj, start, end, points.point );
else
n = msOCIGet2DOrdinates( hand, obj, start, end, points.point );
@@ -1586,10 +1586,10 @@
if (success)
- /* reading SDO_POINT from SDO_GEOMETRY for a 2D/3D point geometry */
+ /* reading SDO_POINT from SDO_GEOMETRY for a 2D/3D point geometry */
if ((gtype==2001 || gtype==3001 || gtype==4001 ) && ind->point._atomic == OCI_IND_NOTNULL && ind->point.x == OCI_IND_NOTNULL && ind->point.y == OCI_IND_NOTNULL)
success = TRY( hand, OCINumberToReal( hand->errhp, &(obj->point.x), (uword)sizeof(double), (dvoid *)&x ) )
&& TRY( hand, OCINumberToReal( hand->errhp, &(obj->point.y), (uword)sizeof(double), (dvoid *)&y ) );
@@ -1736,9 +1736,9 @@
msOracleSpatialLayerInfo *layerinfo = NULL;
msOracleSpatialDataHandler *dthand = NULL;
- msOracleSpatialStatement *sthand = NULL, *sthand2 = NULL;
+ msOracleSpatialStatement *sthand = NULL, *sthand2 = NULL;
msOracleSpatialHandler *hand = NULL;
if (layer->debug)
msDebug("msOracleSpatialLayerOpen called with: %s (Layer pointer %p)\n",layer->data, layer);
@@ -1821,7 +1821,7 @@
layerinfo->orahandlers = hand;
layerinfo->oradatahandlers = dthand;
layerinfo->orastmt = sthand;
- layerinfo->orastmt2 = sthand2;
+ layerinfo->orastmt2 = sthand2;
layer->layerinfo = layerinfo;
return layer->layerinfo != NULL ? MS_SUCCESS : MS_FAILURE;
@@ -1857,28 +1857,28 @@
*if (!lIntSuccessFree)
* msDebug("Error: %s\n", layerinfo->orahandlers->last_oci_error);
- /* Release Statement Handles */
- if (layerinfo->orastmt != NULL)
- msOCIFinishStatement(layerinfo->orastmt);
- layerinfo->orastmt = NULL;
- if (layerinfo->orastmt2 != NULL)
- msOCIFinishStatement(layerinfo->orastmt2);
- layerinfo->orastmt2 = NULL;
+ /* Release Statement Handles */
+ if (layerinfo->orastmt != NULL)
+ msOCIFinishStatement(layerinfo->orastmt);
+ layerinfo->orastmt = NULL;
+ if (layerinfo->orastmt2 != NULL)
+ msOCIFinishStatement(layerinfo->orastmt2);
+ layerinfo->orastmt2 = NULL;
/* Release Datahandlers */
if (layer->debug)
msDebug("msOracleSpatialLayerClose. Cleaning layerinfo handlers.\n");
msOCICloseDataHandlers( layerinfo->oradatahandlers );
layerinfo->oradatahandlers = NULL;
- /* Free the OCI cache only if there is no more layer that could use it */
- layerinfo->orahandlers->ref_count--;
- if (layerinfo->orahandlers->ref_count == 0)
- OCICacheFree (layerinfo->orahandlers->envhp, layerinfo->orahandlers->errhp, layerinfo->orahandlers->svchp);
+ /* Free the OCI cache only if there is no more layer that could use it */
+ layerinfo->orahandlers->ref_count--;
+ if (layerinfo->orahandlers->ref_count == 0)
+ OCICacheFree (layerinfo->orahandlers->envhp, layerinfo->orahandlers->errhp, layerinfo->orahandlers->svchp);
/* Release Mapserver Pool */
if (layer->debug)
@@ -1935,9 +1935,9 @@
else
- dthand = (msOracleSpatialDataHandler *)layerinfo->oradatahandlers;
- hand = (msOracleSpatialHandler *)layerinfo->orahandlers;
- sthand = (msOracleSpatialStatement *)layerinfo->orastmt2;
+ dthand = (msOracleSpatialDataHandler *)layerinfo->oradatahandlers;
+ hand = (msOracleSpatialHandler *)layerinfo->orahandlers;
+ sthand = (msOracleSpatialStatement *)layerinfo->orastmt2;
/*init uniqueindex field*/
@@ -2105,14 +2105,14 @@
success = TRY( hand, OCIObjectNew(hand->envhp, hand->errhp, hand->svchp, OCI_TYPECODE_VARRAY, ordinates_tdo, (dvoid *)NULL, OCI_DURATION_SESSION, FALSE, (dvoid **)&ordinates) );
/* convert it to a OCI number and then append minx...maxy to the collection */
- success = TRY ( hand, OCINumberFromReal(hand->errhp, (dvoid *)&(rect.minx), (uword)sizeof(double),(dvoid *)&oci_number))
- &&TRY ( hand, OCICollAppend(hand->envhp, hand->errhp,(dvoid *) &oci_number,(dvoid *)0, (OCIColl *)ordinates))
- &&TRY ( hand, OCINumberFromReal(hand->errhp, (dvoid *)&(rect.miny), (uword)sizeof(double),(dvoid *)&oci_number))
- &&TRY ( hand, OCINumberFromReal(hand->errhp, (dvoid *)&(rect.maxx), (uword)sizeof(double),(dvoid *)&oci_number))
- &&TRY ( hand, OCINumberFromReal(hand->errhp, (dvoid *)&(rect.maxy), (uword)sizeof(double),(dvoid *)&oci_number))
- &&TRY ( hand, OCICollAppend(hand->envhp, hand->errhp,(dvoid *) &oci_number,(dvoid *)0, (OCIColl *)ordinates));
+ success = TRY ( hand, OCINumberFromReal(hand->errhp, (dvoid *)&(rect.minx), (uword)sizeof(double),(dvoid *)&oci_number))
+ &&TRY ( hand, OCICollAppend(hand->envhp, hand->errhp,(dvoid *) &oci_number,(dvoid *)0, (OCIColl *)ordinates))
+ &&TRY ( hand, OCINumberFromReal(hand->errhp, (dvoid *)&(rect.miny), (uword)sizeof(double),(dvoid *)&oci_number))
+ &&TRY ( hand, OCINumberFromReal(hand->errhp, (dvoid *)&(rect.maxx), (uword)sizeof(double),(dvoid *)&oci_number))
+ &&TRY ( hand, OCINumberFromReal(hand->errhp, (dvoid *)&(rect.maxy), (uword)sizeof(double),(dvoid *)&oci_number))
+ &&TRY ( hand, OCICollAppend(hand->envhp, hand->errhp,(dvoid *) &oci_number,(dvoid *)0, (OCIColl *)ordinates));
if (layer->debug)
@@ -2197,7 +2197,7 @@
msOracleSpatialLayerInfo *layerinfo = (msOracleSpatialLayerInfo *)layer->layerinfo;
- msOracleSpatialStatement *sthand = NULL;
+ msOracleSpatialStatement *sthand = NULL;
if (layerinfo == NULL)
@@ -2215,9 +2215,9 @@
if (sthand->rows_fetched == 0)
return MS_DONE;
- if(layer->debug >=5 )
- msDebug("msOracleSpatialLayerNextShape on layer %p, row_num: %d\n", layer, sthand->row_num);
+ if(layer->debug >=5 )
+ msDebug("msOracleSpatialLayerNextShape on layer %p, row_num: %d\n", layer, sthand->row_num);
do{
/* is buffer empty? */
if (sthand->row >= sthand->rows_fetched)
@@ -2227,10 +2227,10 @@
&& TRY( hand, OCIAttrGet( (dvoid *)sthand->stmthp, (ub4)OCI_HTYPE_STMT, (dvoid *)&sthand->rows_fetched, (ub4 *)0, (ub4)OCI_ATTR_ROWS_FETCHED, hand->errhp ) )
&& TRY( hand, OCIAttrGet( (dvoid *)sthand->stmthp, (ub4)OCI_HTYPE_STMT, (dvoid *)&sthand->rows_count, (ub4 *)0, (ub4)OCI_ATTR_ROW_COUNT, hand->errhp ) );
- if(layer->debug >= 4 )
- msDebug("msOracleSpatialLayerNextShape on layer %p, Fetched %d more rows (%d total)\n", layer, sthand->rows_fetched, sthand->rows_count);
+ if(layer->debug >= 4 )
+ msDebug("msOracleSpatialLayerNextShape on layer %p, Fetched %d more rows (%d total)\n", layer, sthand->rows_fetched, sthand->rows_count);
if (!success || sthand->rows_fetched == 0)
return MS_DONE;
@@ -2291,134 +2291,134 @@
int msOracleSpatialLayerResultGetShape( layerObj *layer, shapeObj *shape, int record, long pkey )
- int success, i;
- long buffer_first_row_num, buffer_last_row_num;
- SDOGeometryObj *obj;
- SDOGeometryInd *ind;
+ int success, i;
+ long buffer_first_row_num, buffer_last_row_num;
+ SDOGeometryObj *obj;
+ SDOGeometryInd *ind;
- msOracleSpatialLayerInfo *layerinfo;
- if(layer == NULL) {
- msSetError( MS_ORACLESPATIALERR, "msOracleSpatialLayerResultGetShape called on unopened layer","msOracleSpatialLayerResultGetShape()" );
- return MS_FAILURE;
- layerinfo = (msOracleSpatialLayerInfo *)layer->layerinfo;
- if (layerinfo == NULL)
- msSetError( MS_ORACLESPATIALERR, "msOracleSpatialLayerResultGetShape called on unopened layer (layerinfo)","msOracleSpatialLayerResultGetShape()" );
+ msOracleSpatialLayerInfo *layerinfo;
+ if(layer == NULL) {
+ msSetError( MS_ORACLESPATIALERR, "msOracleSpatialLayerResultGetShape called on unopened layer","msOracleSpatialLayerResultGetShape()" );
+ return MS_FAILURE;
+ layerinfo = (msOracleSpatialLayerInfo *)layer->layerinfo;
+ if (layerinfo == NULL)
+ msSetError( MS_ORACLESPATIALERR, "msOracleSpatialLayerResultGetShape called on unopened layer (layerinfo)","msOracleSpatialLayerResultGetShape()" );
/* get layerinfo */
- if (layer->resultcache == NULL)
- msSetError( MS_ORACLESPATIALERR, "msOracleSpatialLayerResultGetShape called before msOracleSpatialLayerWhichShapes()","msOracleSpatialLayerResultGetShape()" );
- /* TODO: do we need to fall back... we should never get here.
- * fprintf(stderr, "WARNING: msOracleSpatialLayerResultGetShape called before msOracleSpatialLayerWhichShapes()\n");
- * return msOracleSpatialLayerGetShape(layer, shape, pkey);*/
- if (layer->debug >= 5)
- msDebug("msOracleSpatialLayerResultGetShape was called. Using the record = %ld of %ld. (shape: %ld should equal pkey: %ld)\n",
- record, layer->resultcache->numresults, layer->resultcache->results[record].shapeindex, pkey);
- //record = layer->resultcache->results[record].tileindex; // Do we need to do this? Is record our tile index or an index into the result cache?
+ if (layer->resultcache == NULL)
+ msSetError( MS_ORACLESPATIALERR, "msOracleSpatialLayerResultGetShape called before msOracleSpatialLayerWhichShapes()","msOracleSpatialLayerResultGetShape()" );
+ /* TODO: do we need to fall back... we should never get here.
+ * fprintf(stderr, "WARNING: msOracleSpatialLayerResultGetShape called before msOracleSpatialLayerWhichShapes()\n");
+ * return msOracleSpatialLayerGetShape(layer, shape, pkey);*/
+ if (layer->debug >= 5)
+ msDebug("msOracleSpatialLayerResultGetShape was called. Using the record = %ld of %ld. (shape: %ld should equal pkey: %ld)\n",
+ record, layer->resultcache->numresults, layer->resultcache->results[record].shapeindex, pkey);
+ //record = layer->resultcache->results[record].tileindex; // Do we need to do this? Is record our tile index or an index into the result cache?
if (record >= sthand->rows_count || record < 0)
- /*msDebug("msOracleSpatialLayerResultGetShape problem with cursor. Trying to fetch record = %ld of %ld, falling back to GetShape\n",
- * record, sthand->rows_count);
- *return msOracleSpatialLayerGetShape(layer, shape, pkey); */
+ /*msDebug("msOracleSpatialLayerResultGetShape problem with cursor. Trying to fetch record = %ld of %ld, falling back to GetShape\n",
+ * record, sthand->rows_count);
+ *return msOracleSpatialLayerGetShape(layer, shape, pkey); */
- msSetError( MS_ORACLESPATIALERR, "msOracleSpatialLayerResultGetShape record out of range","msOracleSpatialLayerResultGetShape()" );
- /* NOTE: with the way the resultcache works, we should see items in increasing order, but some may have been filtered out. */
- /* Best case: item in buffer */
- /* Next best case: item is in next fetch block */
- /* Worst case: item is random access */
- buffer_first_row_num = sthand->row_num - sthand->row; /* cursor id of first item in buffer */
- buffer_last_row_num = buffer_first_row_num + sthand->rows_fetched - 1; /* cursor id of last item in buffer */
- if(record >= buffer_first_row_num && record <= buffer_last_row_num) /* Item is in buffer. Calculate position in buffer */
- sthand->row += record - sthand->row_num; /* move sthand row an row_num by offset from last call */
- sthand->row_num += record - sthand->row_num;
- else /* Item is not in buffer. Fetch item from Oracle */
- if (layer->debug >= 4)
- msDebug("msOracleSpatialLayerResultGetShape: Fetching result from DB start: %ld end:%ld record: %ld\n", buffer_first_row_num, buffer_last_row_num, record);
- success = TRY( hand, OCIStmtFetch2( sthand->stmthp, hand->errhp, (ub4)ARRAY_SIZE, (ub2)OCI_FETCH_ABSOLUTE, (sb4)record+1, (ub4)OCI_DEFAULT ) )
- && TRY( hand, OCIAttrGet( (dvoid *)sthand->stmthp, (ub4)OCI_HTYPE_STMT, (dvoid *)&sthand->rows_fetched, (ub4 *)0, (ub4)OCI_ATTR_ROWS_FETCHED, hand->errhp ) );
+ msSetError( MS_ORACLESPATIALERR, "msOracleSpatialLayerResultGetShape record out of range","msOracleSpatialLayerResultGetShape()" );
+ /* NOTE: with the way the resultcache works, we should see items in increasing order, but some may have been filtered out. */
+ /* Best case: item in buffer */
+ /* Next best case: item is in next fetch block */
+ /* Worst case: item is random access */
+ buffer_first_row_num = sthand->row_num - sthand->row; /* cursor id of first item in buffer */
+ buffer_last_row_num = buffer_first_row_num + sthand->rows_fetched - 1; /* cursor id of last item in buffer */
+ if(record >= buffer_first_row_num && record <= buffer_last_row_num) /* Item is in buffer. Calculate position in buffer */
+ sthand->row += record - sthand->row_num; /* move sthand row an row_num by offset from last call */
+ sthand->row_num += record - sthand->row_num;
+ else /* Item is not in buffer. Fetch item from Oracle */
+ if (layer->debug >= 4)
+ msDebug("msOracleSpatialLayerResultGetShape: Fetching result from DB start: %ld end:%ld record: %ld\n", buffer_first_row_num, buffer_last_row_num, record);
+ success = TRY( hand, OCIStmtFetch2( sthand->stmthp, hand->errhp, (ub4)ARRAY_SIZE, (ub2)OCI_FETCH_ABSOLUTE, (sb4)record+1, (ub4)OCI_DEFAULT ) )
+ && TRY( hand, OCIAttrGet( (dvoid *)sthand->stmthp, (ub4)OCI_HTYPE_STMT, (dvoid *)&sthand->rows_fetched, (ub4 *)0, (ub4)OCI_ATTR_ROWS_FETCHED, hand->errhp ) );
- ERROR("msOracleSpatialLayerResultGetShape", hand, dthand);
+ ERROR("msOracleSpatialLayerResultGetShape", hand, dthand);
- sthand->row_num = record;
- sthand->row = 0; /* reset row index */
- if (!success || sthand->rows_fetched == 0) {
- msSetError( MS_ORACLESPATIALERR, "msOracleSpatialLayerResultGetShape could not fetch specified record.", "msOracleSpatialLayerResultGetShape()" );
- /* set obj & ind for current row */
- obj = sthand->obj[ sthand->row ];
- ind = sthand->ind[ sthand->row ];
- /* get the items for the shape */
- shape->index = record; /* By definition this is what we asked for */
- shape->numvalues = layer->numitems;
- shape->values = (char **)malloc( sizeof(char*) * shape->numvalues );
- if (shape->values == NULL)
- msSetError( MS_ORACLESPATIALERR, "No memory avaliable to allocate the values", "msOracleSpatialLayerNextShape()" );
- for( i=0; i < shape->numvalues; ++i )
- shape->values[i] = (char *)malloc(strlen((char *)sthand->items[i][ sthand->row ])+1);
- if (shape->values[i] == NULL)
- msSetError( MS_ORACLESPATIALERR, "No memory avaliable to allocate the items", "msOracleSpatialLayerNextShape()" );
- else
- strcpy(shape->values[i], (char *)sthand->items[i][ sthand->row ]);
- shape->values[i][strlen((char *)sthand->items[i][ sthand->row ])] = '\0';
- /* fetch a layer->type object */
- success = osGetOrdinates(dthand, hand, shape, obj, ind);
- if (success != MS_SUCCESS)
- msSetError( MS_ORACLESPATIALERR, "Call to osGetOrdinates failed.", "msOracleSpatialLayerResultGetShape()" );
- osShapeBounds(shape);
- if(shape->type == MS_SHAPE_NULL) {
- /*fprintf(stderr, "\trecord: %ld, row: %d rownum: %ld pkey: %s\n", record, sthand->row, sthand->row_num, shape->values[0]);*/
+ sthand->row_num = record;
+ sthand->row = 0; /* reset row index */
+ if (!success || sthand->rows_fetched == 0) {
+ msSetError( MS_ORACLESPATIALERR, "msOracleSpatialLayerResultGetShape could not fetch specified record.", "msOracleSpatialLayerResultGetShape()" );
+ /* set obj & ind for current row */
+ obj = sthand->obj[ sthand->row ];
+ ind = sthand->ind[ sthand->row ];
+ /* get the items for the shape */
+ shape->index = record; /* By definition this is what we asked for */
+ shape->numvalues = layer->numitems;
+ shape->values = (char **)malloc( sizeof(char*) * shape->numvalues );
+ if (shape->values == NULL)
+ msSetError( MS_ORACLESPATIALERR, "No memory avaliable to allocate the values", "msOracleSpatialLayerNextShape()" );
+ for( i=0; i < shape->numvalues; ++i )
+ shape->values[i] = (char *)malloc(strlen((char *)sthand->items[i][ sthand->row ])+1);
+ if (shape->values[i] == NULL)
+ msSetError( MS_ORACLESPATIALERR, "No memory avaliable to allocate the items", "msOracleSpatialLayerNextShape()" );
+ else
+ strcpy(shape->values[i], (char *)sthand->items[i][ sthand->row ]);
+ shape->values[i][strlen((char *)sthand->items[i][ sthand->row ])] = '\0';
+ /* fetch a layer->type object */
+ success = osGetOrdinates(dthand, hand, shape, obj, ind);
+ if (success != MS_SUCCESS)
+ msSetError( MS_ORACLESPATIALERR, "Call to osGetOrdinates failed.", "msOracleSpatialLayerResultGetShape()" );
+ osShapeBounds(shape);
+ if(shape->type == MS_SHAPE_NULL) {
+ /*fprintf(stderr, "\trecord: %ld, row: %d rownum: %ld pkey: %s\n", record, sthand->row, sthand->row_num, shape->values[0]);*/
msSetError( MS_ORACLESPATIALERR, "Shape type is null... this probably means a record number was requested that could not have beeen in a result set (as returned by NextShape).", "msOracleSpatialLayerResultGetShape()" );
return (MS_SUCCESS);
@@ -2466,7 +2466,7 @@
msOracleSpatialLayerInfo *layerinfo = (msOracleSpatialLayerInfo *) layer->layerinfo;
if (layer->debug)
msDebug("msOracleSpatialLayerGetItems was called.\n");
@@ -2480,8 +2480,8 @@
- sthand = (msOracleSpatialStatement *) layerinfo->orastmt;
+ sthand = (msOracleSpatialStatement *) layerinfo->orastmt;
table_name = (char *) malloc(sizeof(char) * TABLE_NAME_SIZE);
if (!msSplitData(layer->data, geom_column_name, &table_name, unique, srid, &function, &version))
@@ -2546,7 +2546,7 @@
/*Retrive columns name from the user table*/
for (i = 0; i <= layer->numitems; i++)
success = TRY( hand, OCIParamGet ((dvoid*) sthand->stmthp, (ub4)OCI_HTYPE_STMT,hand->errhp,(dvoid*)&pard, (ub4)i+1))
&& TRY( hand, OCIAttrGet ((dvoid *) pard,(ub4) OCI_DTYPE_PARAM,(dvoid*)&rzttype,(ub4 *)0, (ub4) OCI_ATTR_DATA_TYPE, hand->errhp ))
&& TRY( hand, OCIParamGet ((dvoid*) sthand->stmthp, (ub4)OCI_HTYPE_STMT,hand->errhp,(dvoid*)&pard, (ub4)i+1))
@@ -2570,7 +2570,7 @@
/*Comapre the column name (flk) with geom_column_name and ignore with true*/
if (strcmp(flk, geom_column_name) != 0)
if (rzttype!=OCI_TYPECODE_BLOB)
layer->items[count_item] = (char *)malloc(sizeof(char) * flk_len+1);
@@ -2622,7 +2622,7 @@
if (layer->debug)
msDebug("msOracleSpatialLayerGetShape was called. Using the record = %ld.\n", record);
@@ -2636,7 +2636,7 @@
/* allocate enough space for items */
@@ -2909,7 +2909,7 @@
if (layer->debug)
msDebug("msOracleSpatialLayerGetExtent was called.\n");
@@ -2923,7 +2923,7 @@
More information about the mapserver-commits
