[mapserver-commits] r9846 - in trunk: docs/en/ogc mapserver
msautotest/wxs msautotest/wxs/expected
svn at osgeo.org
svn at osgeo.org
Sun Feb 21 11:40:27 EST 2010
Author: tomkralidis
Date: 2010-02-21 11:40:26 -0500 (Sun, 21 Feb 2010)
New Revision: 9846
Added:
trunk/msautotest/wxs/expected/wms_getmap130layerlimitexception.xml
trunk/docs/en/ogc/wms_server.txt
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapwms.c
trunk/msautotest/wxs/expected/wms_cap130.xml
trunk/msautotest/wxs/expected/wms_cap_latestversion.xml
trunk/msautotest/wxs/wms_simple.map
add WMS 1.3.0 LayerLimit support (#3284)
Modified: trunk/docs/en/ogc/wms_server.txt
--- trunk/docs/en/ogc/wms_server.txt 2010-02-21 16:24:36 UTC (rev 9845)
+++ trunk/docs/en/ogc/wms_server.txt 2010-02-21 16:40:26 UTC (rev 9846)
@@ -636,8 +636,9 @@
- valid values for the EXCEPTIONS parameter in a GetMap request are XML, INIMAGE, BLANK
- valid value for the EXCEPTIONS parameter in a GetFeatureInfo request is XML
+- LayerLimit is introduced, allowing a server to advertise and limit the
+ number of layers a client is allowed to include in a GetMap request
Some Missing features
@@ -887,6 +888,13 @@
- *Description:* (Optional) Same as wms_keywordlist, applied to the root Layer element.
If not set, then wms_keywordlist will be used.
+**wms_layerlimit**
+- *WMS TAG Name:* LayerLimit (WMS1.3.0, sect. 7.2.4.3)
+- *Description:* (Optional) The maximum number of layers a WMS client can
+ specify in a GetMap request. If not set, then no limit is imposed.
Layer Object Metadata
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2010-02-21 16:24:36 UTC (rev 9845)
+++ trunk/mapserver/HISTORY.TXT 2010-02-21 16:40:26 UTC (rev 9846)
@@ -14,6 +14,8 @@
Current Version (SVN trunk):
+- add WMS 1.3.0 LayerLimit support (#3284)
- fix WFS 1.1.0 exception attributes (#3301)
- add more useful error message when query file extension test fails (#3302)
Modified: trunk/mapserver/mapwms.c
--- trunk/mapserver/mapwms.c 2010-02-21 16:24:36 UTC (rev 9845)
+++ trunk/mapserver/mapwms.c 2010-02-21 16:40:26 UTC (rev 9846)
@@ -214,8 +214,6 @@
return MS_FAILURE; /* so that we can call 'return msWMSException();' anywhere */
void msWMSSetTimePattern(const char *timepatternstring, char *timestring)
char *time = NULL;
@@ -408,6 +406,7 @@
int heightfound = 0;
char *request = NULL;
int status = 0;
+ const char *layerlimit = NULL;
char *bboxrequest=NULL;
const char *sldenabled=NULL;
@@ -479,6 +478,16 @@
return msWMSException(map, nVersion, NULL);
+ if (nVersion >= OWS_1_3_0) {
+ layerlimit = msOWSLookupMetadata(&(map->web.metadata), "MO", "layerlimit");
+ if(layerlimit) {
+ if (numlayers > atoi(layerlimit)) {
+ msSetError(MS_WMSERR, "Number of layers requested exceeds LayerLimit.",
+ "msWMSLoadGetMapParams()");
+ return msWMSException(map, nVersion, NULL);
for (iLayer=0; iLayer < map->numlayers; iLayer++)
@@ -1975,6 +1984,7 @@
const char *updatesequence=NULL;
const char *encoding;
+ const char *layerlimit=NULL;
char *pszTmp=NULL;
int i;
const char *format_list=NULL;
@@ -2169,7 +2179,10 @@
- /* LayerLimit not supported. No restriction in MapServer at this point*/
+ if (layerlimit) {
+ msIO_printf(" <LayerLimit>%s</LayerLimit>\n", layerlimit);
msIO_printf(" <MaxWidth>%d</MaxWidth>\n", map->maxsize);
msIO_printf(" <MaxHeight>%d</MaxHeight>\n", map->maxsize);
@@ -3737,8 +3750,6 @@
return(MS_SUCCESS);
#endif /* USE_WMS_SVR */
Modified: trunk/msautotest/wxs/expected/wms_cap130.xml
--- trunk/msautotest/wxs/expected/wms_cap130.xml 2010-02-21 16:24:36 UTC (rev 9845)
+++ trunk/msautotest/wxs/expected/wms_cap130.xml 2010-02-21 16:40:26 UTC (rev 9846)
@@ -32,6 +32,7 @@
</ContactInformation>
<Fees>None</Fees>
<AccessConstraints>None</AccessConstraints>
+ <LayerLimit>1</LayerLimit>
<MaxWidth>2048</MaxWidth>
<MaxHeight>2048</MaxHeight>
</Service>
Modified: trunk/msautotest/wxs/expected/wms_cap_latestversion.xml
--- trunk/msautotest/wxs/expected/wms_cap_latestversion.xml 2010-02-21 16:24:36 UTC (rev 9845)
+++ trunk/msautotest/wxs/expected/wms_cap_latestversion.xml 2010-02-21 16:40:26 UTC (rev 9846)
@@ -32,6 +32,7 @@
<Fees>None</Fees>
</Service>
Added: trunk/msautotest/wxs/expected/wms_getmap130layerlimitexception.xml
--- trunk/msautotest/wxs/expected/wms_getmap130layerlimitexception.xml (rev 0)
+++ trunk/msautotest/wxs/expected/wms_getmap130layerlimitexception.xml 2010-02-21 16:40:26 UTC (rev 9846)
@@ -0,0 +1,8 @@
+Content-type: text/xml
+<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
+<ServiceExceptionReport version="1.3.0" xmlns="http://www.opengis.net/ogc" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/ogc http://schemas.opengis.net/wms/1.3.0/exceptions_1_3_0.xsd">
+<ServiceException>
+msWMSLoadGetMapParams(): WMS server error. Number of layers requested exceeds LayerLimit.
+</ServiceException>
+</ServiceExceptionReport>
Modified: trunk/msautotest/wxs/wms_simple.map
--- trunk/msautotest/wxs/wms_simple.map 2010-02-21 16:24:36 UTC (rev 9845)
+++ trunk/msautotest/wxs/wms_simple.map 2010-02-21 16:40:26 UTC (rev 9846)
@@ -49,6 +49,9 @@
# GetMap exception (passing SRS instead of CRS)
# RUN_PARMS: wms_getmap130crsexception.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&SRS=EPSG%3A4326&BBOX=35.18749999863387,-141.0000000021858,90.81250000136613,-51.99999999781419&WIDTH=560&HEIGHT=350&LAYERS=road&STYLES=&FORMAT=image%2Fpng&BGCOLOR=0xFFFFFF&TRANSPARENT=FALSE&EXCEPTIONS=XML" > [RESULT]
+# GetMap exception (number of layers < LayerLimit)
+# RUN_PARMS: wms_getmap130layerlimitexception.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&SRS=EPSG%3A4326&BBOX=35.18749999863387,-141.0000000021858,90.81250000136613,-51.99999999781419&WIDTH=560&HEIGHT=350&LAYERS=road,road&STYLES=&FORMAT=image%2Fpng&BGCOLOR=0xFFFFFF&TRANSPARENT=FALSE&EXCEPTIONS=XML" > [RESULT]
# GetFeatureInfo
# RUN_PARMS: wms_getfeatureinfo130.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetFeatureInfo&CRS=EPSG%3A4326&BBOX=35.18749999863387,-141.0000000021858,90.81250000136613,-51.99999999781419&WIDTH=560&HEIGHT=350&LAYERS=road&STYLES=&FORMAT=image%2Fpng&BGCOLOR=0xFFFFFF&TRANSPARENT=FALSE&QUERY_LAYERS=road&INFO_FORMAT=application%2Fvnd.ogc.gml&I=483&J=291&FEATURE_COUNT=5" > [RESULT]
@@ -115,6 +118,7 @@
"ows_rootlayer_title" "My Layers"
"ows_rootlayer_abstract" "These are my layers"
"ows_rootlayer_keywordlist" "layers,list"
+ "ows_layerlimit" "1"
END
END
More information about the mapserver-commits
