[mapserver-commits] r10023 - branches/branch-5-6/mapserver
svn at osgeo.org
svn at osgeo.org
Sat Mar 27 13:52:04 EDT 2010
Author: dmorissette
Date: 2010-03-27 13:52:04 -0400 (Sat, 27 Mar 2010)
New Revision: 10023
branches/branch-5-6/mapserver/HISTORY.TXT
branches/branch-5-6/mapserver/mapquery.c
Improve error message when loadQuery() filename extension check fails (#3302)
Modified: branches/branch-5-6/mapserver/HISTORY.TXT
--- branches/branch-5-6/mapserver/HISTORY.TXT 2010-03-26 18:50:33 UTC (rev 10022)
+++ branches/branch-5-6/mapserver/HISTORY.TXT 2010-03-27 17:52:04 UTC (rev 10023)
@@ -15,6 +15,8 @@
Version 5.6.4 (????-??-??):
+- Improve error message when loadQuery() filename extension check fails (#3302)
- Fix GetLegendGraphic using keyimages (#3398)
- Fix getFeatureInfo quries on WFS layers (#3403)
Modified: branches/branch-5-6/mapserver/mapquery.c
--- branches/branch-5-6/mapserver/mapquery.c 2010-03-26 18:50:33 UTC (rev 10022)
+++ branches/branch-5-6/mapserver/mapquery.c 2010-03-27 17:52:04 UTC (rev 10023)
@@ -220,7 +220,10 @@
** Make sure the file at least has the right extension.
- if(msEvalRegex("\\.qy$", filename) != MS_TRUE) return MS_FAILURE;
+ if(msEvalRegex("\\.qy$", filename) != MS_TRUE) {
+ msSetError(MS_MISCERR, "Query file extension check failed on %s (extension must be .qy)", "msLoadQuery()", filename);
+ return MS_FAILURE;
stream = fopen(filename, "r");
if(!stream) {
More information about the mapserver-commits
