[mapserver-commits] r10024 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Sat Mar 27 13:58:17 EDT 2010
Author: dmorissette
Date: 2010-03-27 13:58:16 -0400 (Sat, 27 Mar 2010)
New Revision: 10024
trunk/mapserver/mapquery.c
Revert r9829 and produce better error message when loadQuery() filename extension check fails (#3302)
Modified: trunk/mapserver/mapquery.c
--- trunk/mapserver/mapquery.c 2010-03-27 17:52:04 UTC (rev 10023)
+++ trunk/mapserver/mapquery.c 2010-03-27 17:58:16 UTC (rev 10024)
@@ -221,11 +221,14 @@
** Make sure the file at least has the right extension.
- if(msEvalRegex("\\.qy$", filename) != MS_TRUE) return MS_FAILURE;
+ if(msEvalRegex("\\.qy$", filename) != MS_TRUE) {
+ msSetError(MS_MISCERR, "Query file extension check failed on %s (extension must be .qy)", "msLoadQuery()", filename);
+ return MS_FAILURE;
stream = fopen(filename, "r");
if(!stream) {
- msSetError(MS_IOERR, "Query file extension check failed on %s (extension must be .qy)", "msLoadQuery()", filename);
+ msSetError(MS_IOERR, "(%s)", "msLoadQuery()", filename);
return(MS_FAILURE);
More information about the mapserver-commits
