[mapserver-commits] r10141 - trunk/mapserver/mapscript/php
svn at osgeo.org
svn at osgeo.org
Fri May 7 13:49:42 EDT 2010
Author: assefa
Date: 2010-05-07 13:49:41 -0400 (Fri, 07 May 2010)
New Revision: 10141
trunk/mapserver/mapscript/php/layer.c
trunk/mapserver/mapscript/php/map.c
setprojection on map and layer should not return a fatal errors (#3436)
Modified: trunk/mapserver/mapscript/php/layer.c
--- trunk/mapserver/mapscript/php/layer.c 2010-05-07 15:42:29 UTC (rev 10140)
+++ trunk/mapserver/mapscript/php/layer.c 2010-05-07 17:49:41 UTC (rev 10141)
@@ -839,8 +839,8 @@
if ((status = layerObj_setProjection(php_layer->layer, projection)) != MS_SUCCESS)
- mapscript_throw_mapserver_exception("" TSRMLS_CC);
- return;
+ mapscript_report_php_error(E_WARNING, "setProjection failed" TSRMLS_CC);
+ return MS_FAILURE;
php_projection->projection = &(php_layer->layer->projection);
Modified: trunk/mapserver/mapscript/php/map.c
--- trunk/mapserver/mapscript/php/map.c 2010-05-07 15:42:29 UTC (rev 10140)
+++ trunk/mapserver/mapscript/php/map.c 2010-05-07 17:49:41 UTC (rev 10141)
@@ -3502,7 +3502,7 @@
if (status == -1)
return MS_FAILURE;
else
@@ -3531,7 +3531,7 @@
- return status;
+ return MS_SUCCESS;
#else
mapscript_throw_exception("Available only with PROJ.4 support." TSRMLS_CC);
return MS_FAILURE;
More information about the mapserver-commits
