[mapserver-commits] r10142 - trunk/docs/en/mapscript/php
Fri May 7 13:52:12 EDT 2010
Author: assefa
Date: 2010-05-07 13:52:11 -0400 (Fri, 07 May 2010)
New Revision: 10142
   trunk/docs/en/mapscript/php/index.txt
Add a note on return value for setProjection #3436
Modified: trunk/docs/en/mapscript/php/index.txt
--- trunk/docs/en/mapscript/php/index.txt	2010-05-07 17:49:41 UTC (rev 10141)
+++ trunk/docs/en/mapscript/php/index.txt	2010-05-07 17:52:11 UTC (rev 10142)
@@ -843,7 +843,8 @@
 int setProjection(string proj_params)
     Set layer :ref:`projection <projection>` and coordinate system.  Parameters are given as
-    a single string of comma-delimited PROJ.4 parameters.
+    a single string of comma-delimited PROJ.4 parameters. Returns MS_SUCCESS or
+    MS_FAILURE on error.
 int setWKTProjection(string proj_params)
     Same as setProjection(), but takes an OGC WKT projection
