[mapserver-commits] r10163 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Tue May 18 00:47:32 EDT 2010
Author: sdlime
Date: 2010-05-18 00:47:30 -0400 (Tue, 18 May 2010)
New Revision: 10163
trunk/mapserver/maplayer.c
trunk/mapserver/mapserver.h
Added a msLayerGetItemIndex() function...
Modified: trunk/mapserver/maplayer.c
--- trunk/mapserver/maplayer.c 2010-05-15 19:13:39 UTC (rev 10162)
+++ trunk/mapserver/maplayer.c 2010-05-18 04:47:30 UTC (rev 10163)
@@ -352,11 +352,21 @@
+int msLayerGetItemIndex(layerObj *layer, char *item)
+ int i;
-** This function builds a list of items necessary to draw or query a particular layer by
-** examining the contents of the various xxxxitem parameters and expressions. That list is
-** then used to set the iteminfo variable.
+ for(i=0; i<layer->numitems; i++) {
+ if(strcasecmp(layer->items[i], item) == 0) return(i);
+ return -1; /* item not found */
+** This function builds a list of items necessary to draw or query a particular layer by
+** examining the contents of the various xxxxitem parameters and expressions. That list is
+** then used to set the iteminfo variable.
int msLayerWhichItems(layerObj *layer, int get_all, char *metadata)
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h 2010-05-15 19:13:39 UTC (rev 10162)
+++ trunk/mapserver/mapserver.h 2010-05-18 04:47:30 UTC (rev 10163)
@@ -1961,6 +1961,7 @@
MS_DLL_EXPORT int msLayerIsOpen(layerObj *layer);
MS_DLL_EXPORT void msLayerClose(layerObj *layer);
MS_DLL_EXPORT int msLayerWhichShapes(layerObj *layer, rectObj rect);
+MS_DLL_EXPORT int msLayerGetItemIndex(layerObj *layer, char *item);
MS_DLL_EXPORT int msLayerWhichItems(layerObj *layer, int get_all, char *metadata);
MS_DLL_EXPORT int msLayerNextShape(layerObj *layer, shapeObj *shape);
MS_DLL_EXPORT int msLayerGetItems(layerObj *layer);
More information about the mapserver-commits
