[mapserver-commits] r10164 - trunk/docs/en/mapfile
Tue May 18 08:50:26 EDT 2010
Author: jmckenna
Date: 2010-05-18 08:50:24 -0400 (Tue, 18 May 2010)
New Revision: 10164
   trunk/docs/en/mapfile/projection.txt
add reference to PROJ.4 parameters page
Modified: trunk/docs/en/mapfile/projection.txt
--- trunk/docs/en/mapfile/projection.txt	2010-05-18 04:47:30 UTC (rev 10163)
+++ trunk/docs/en/mapfile/projection.txt	2010-05-18 12:50:24 UTC (rev 10164)
@@ -29,6 +29,11 @@
       "no_defs"
     END
+.. note::
+    For a list of all of the possible PROJ.4 projection parameters, see the
+    `PROJ.4 parameters <http://trac.osgeo.org/proj/wiki/GenParms>`__ page.
 **Example 2: EPSG Projection Use**
 .. code-block:: mapfile
