[mapserver-commits] r10709 - trunk/docs/en/ogc
svn at osgeo.org
svn at osgeo.org
Sun Nov 7 09:19:44 EST 2010
Author: rouault
Date: 2010-11-07 06:19:44 -0800 (Sun, 07 Nov 2010)
New Revision: 10709
trunk/docs/en/ogc/wfs_client.txt
Remove obsolete mention to OGR/GML support requiring Xerces. Since OGR 1.7.0, Expat can be used as well
Modified: trunk/docs/en/ogc/wfs_client.txt
--- trunk/docs/en/ogc/wfs_client.txt 2010-11-06 21:25:31 UTC (rev 10708)
+++ trunk/docs/en/ogc/wfs_client.txt 2010-11-07 14:19:44 UTC (rev 10709)
@@ -8,7 +8,7 @@
:Contact: jdoyon at nrcan.gc.ca
:Author: Jeff McKenna
:Contact: jmckenna at gatewaygeomatics.com
-:Last Updated: 2010-10-07
+:Last Updated: 2010-11-07
.. contents::
:depth: 2
@@ -202,8 +202,3 @@
"wfs_cache_dir" metadata that, if it is set will define a directory where temp
files should be written. The default would still be to use the value of
IMAGEPATH if "wfs_tmpdir" is not set.
-2. Xerces is an annoying dependency for GML support in OGR. There have been
- discussions about modifying the OGR GML driver to use in internal XML parser
- by default. This would save us from the Xerces dependency. There is no formal
- plan for when this would happen yet.
More information about the mapserver-commits
