[mapserver-commits] r10710 - branches/branch-5-6/docs/en/ogc
Sun Nov 7 09:21:12 EST 2010
Author: rouault
Date: 2010-11-07 06:21:12 -0800 (Sun, 07 Nov 2010)
New Revision: 10710
   branches/branch-5-6/docs/en/ogc/wfs_client.txt
Remove obsolete mention to OGR/GML support requiring Xerces. Since OGR 1.7.0, Expat can be used as well
Modified: branches/branch-5-6/docs/en/ogc/wfs_client.txt
--- branches/branch-5-6/docs/en/ogc/wfs_client.txt	2010-11-07 14:19:44 UTC (rev 10709)
+++ branches/branch-5-6/docs/en/ogc/wfs_client.txt	2010-11-07 14:21:12 UTC (rev 10710)
@@ -8,7 +8,7 @@
 :Contact: jdoyon at nrcan.gc.ca
 :Author: Jeff McKenna
 :Contact: jmckenna at gatewaygeomatics.com
-:Last Updated: 2010-10-07
+:Last Updated: 2010-11-07
 .. contents::
     :depth: 2
@@ -202,8 +202,3 @@
    "wfs_cache_dir" metadata that, if it is set will define a directory where temp
    files should be written.  The default would still be to use the value of
    IMAGEPATH if "wfs_tmpdir" is not set.
-2. Xerces is an annoying dependency for GML support in OGR.  There have been
-   discussions about modifying the OGR GML driver to use in internal XML parser
-   by default.  This would save us from the Xerces dependency. There is no formal
-   plan for when this would happen yet.
