[mapserver-commits] r10733 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Wed Nov 17 14:04:37 EST 2010
Author: sdlime
Date: 2010-11-17 11:04:37 -0800 (Wed, 17 Nov 2010)
New Revision: 10733
trunk/mapserver/maptemplate.c
Enable inner/outer ring header/footer/separator variables. They aren't used yet, just enabled in a shpxy tag. (#3606)
Modified: trunk/mapserver/maptemplate.c
--- trunk/mapserver/maptemplate.c 2010-11-17 11:04:23 UTC (rev 10732)
+++ trunk/mapserver/maptemplate.c 2010-11-17 19:04:37 UTC (rev 10733)
@@ -1856,15 +1856,15 @@
** Pointers to static strings, naming convention is:
- ** char 1 - x=x, y=y, c=coordinate, p=part, s=shape
- ** char 2 - h=header, f=footer, s=seperator
+ ** char 1/2 - x=x, y=y, c=coordinate, p=part, s=shape, ir=inner ring, or=outer ring
+ ** last char - h=header, f=footer, s=seperator
char *xh, *xf, *yh, *yf;
char *cs;
char *ph, *pf, *ps;
char *sh, *sf;
- /* char *irh="", *irf="", *irs=""; // inner ring: necessary for complex polygons */
- /* char *orh="", *orf="", *ors=""; // outer ring */
+ char *irh, *irf, *irs; /* inner ring: necessary for complex polygons */
+ char *orh, *orf, *ors; /* outer ring */
int centroid;
int precision;
@@ -1901,7 +1901,8 @@
while (tagStart) {
xh = yh = yf = ph = pf = sh = sf = ""; /* initialize the tag arguments */
xf= ",";
- ps = cs = " ";
+ irh = irf = orh = orf = "";
+ ps = cs = irs = ors = " ";
centroid = MS_FALSE;
precision = 0;
@@ -1930,6 +1931,21 @@
argValue = msLookupHashTable(tagArgs, "cs");
if(argValue) cs = argValue;
+ argValue = msLookupHashTable(tagArgs, "irh");
+ if(argValue) irh = argValue;
+ argValue = msLookupHashTable(tagArgs, "irf");
+ if(argValue) irf = argValue;
+ argValue = msLookupHashTable(tagArgs, "orh");
+ if(argValue) orh = argValue;
+ argValue = msLookupHashTable(tagArgs, "orf");
+ if(argValue) orf = argValue;
+ argValue = msLookupHashTable(tagArgs, "irs");
+ if(argValue) irs = argValue;
+ argValue = msLookupHashTable(tagArgs, "ors");
+ if(argValue) ors = argValue;
argValue = msLookupHashTable(tagArgs, "ph");
if(argValue) ph = argValue;
argValue = msLookupHashTable(tagArgs, "pf");
More information about the mapserver-commits
