[mapserver-commits] r10734 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Wed Nov 17 14:11:00 EST 2010
Author: sdlime
Date: 2010-11-17 11:11:00 -0800 (Wed, 17 Nov 2010)
New Revision: 10734
trunk/mapserver/maptemplate.c
Removed inner/outer ring separator attributes from shpxy tag. Can just use the part separator in both cases.
Modified: trunk/mapserver/maptemplate.c
--- trunk/mapserver/maptemplate.c 2010-11-17 19:04:37 UTC (rev 10733)
+++ trunk/mapserver/maptemplate.c 2010-11-17 19:11:00 UTC (rev 10734)
@@ -1863,8 +1863,8 @@
char *cs;
char *ph, *pf, *ps;
char *sh, *sf;
- char *irh, *irf, *irs; /* inner ring: necessary for complex polygons */
- char *orh, *orf, *ors; /* outer ring */
+ char *irh, *irf; /* inner ring: necessary for complex polygons */
+ char *orh, *orf; /* outer ring */
int centroid;
int precision;
@@ -1902,7 +1902,7 @@
xh = yh = yf = ph = pf = sh = sf = ""; /* initialize the tag arguments */
xf= ",";
irh = irf = orh = orf = "";
- ps = cs = irs = ors = " ";
+ ps = cs = " ";
centroid = MS_FALSE;
precision = 0;
@@ -1941,11 +1941,6 @@
argValue = msLookupHashTable(tagArgs, "orf");
if(argValue) orf = argValue;
- argValue = msLookupHashTable(tagArgs, "irs");
- if(argValue) irs = argValue;
- argValue = msLookupHashTable(tagArgs, "ors");
- if(argValue) ors = argValue;
argValue = msLookupHashTable(tagArgs, "ph");
if(argValue) ph = argValue;
argValue = msLookupHashTable(tagArgs, "pf");
More information about the mapserver-commits
