[mapserver-commits] r10735 - sandbox/mapserver6
svn at osgeo.org
svn at osgeo.org
Wed Nov 17 18:21:20 EST 2010
Author: tamas
Date: 2010-11-17 15:21:19 -0800 (Wed, 17 Nov 2010)
New Revision: 10735
sandbox/mapserver6/mapogl.cpp
sandbox/mapserver6/mapoglcontext.cpp
sandbox/mapserver6/mapoutput.c
Couple of adjustments in the OpenGL renderer
Modified: sandbox/mapserver6/mapogl.cpp
--- sandbox/mapserver6/mapogl.cpp 2010-11-17 19:11:00 UTC (rev 10734)
+++ sandbox/mapserver6/mapogl.cpp 2010-11-17 23:21:19 UTC (rev 10735)
@@ -197,7 +197,7 @@
int msPopulateRendererVTableOGL(rendererVTableObj *renderer) {
#ifdef USE_OGL
renderer->supports_transparent_layers = 1;
- renderer->supports_pixel_buffer = 0;
+ renderer->supports_pixel_buffer = 1;
renderer->supports_clipping = 0;
renderer->use_imagecache = 0;
renderer->supports_bitmap_fonts = 0;
@@ -224,7 +224,7 @@
renderer->transformShape=&msTransformShapeToPixel;
renderer->getTruetypeTextBBox = &msGetTruetypeTextBBoxOgl;
- //renderer->getRasterBufferHandle = msGetRasterBufferHandleOgl;
+ renderer->getRasterBufferHandle = msGetRasterBufferHandleOgl;
renderer->getRasterBufferCopy = msGetRasterBufferCopyOgl;
renderer->initializeRasterBuffer = msInitializeRasterBufferOgl;
renderer->mergeRasterBuffer = msMergeRasterBufferOgl;
Modified: sandbox/mapserver6/mapoglcontext.cpp
--- sandbox/mapserver6/mapoglcontext.cpp 2010-11-17 19:11:00 UTC (rev 10734)
+++ sandbox/mapserver6/mapoglcontext.cpp 2010-11-17 23:21:19 UTC (rev 10735)
@@ -209,11 +209,11 @@
int pixelFormat;
int valid = false;
- UINT numFormats;
+ UINT numFormats = 0;
float fAttributes[] = {0,0};
int samples = MAX_MULTISAMPLE_SAMPLES;
- while (!valid && samples >= 0)
+ while ((!valid || numFormats == 0) && samples >= 0)
int iAttributes[] =
@@ -231,7 +231,7 @@
valid = wglChoosePixelFormatARB(window,iAttributes,fAttributes,1,&pixelFormat,&numFormats);
- if (!valid) samples -= 2;
+ if (!valid || numFormats == 0) samples -= 2;
if(numFormats == 0)
Modified: sandbox/mapserver6/mapoutput.c
--- sandbox/mapserver6/mapoutput.c 2010-11-17 19:11:00 UTC (rev 10734)
+++ sandbox/mapserver6/mapoutput.c 2010-11-17 23:21:19 UTC (rev 10735)
@@ -360,6 +360,11 @@
msCreateDefaultOutputFormat( map, "CAIRO/SVG" );
#endif
+#if defined(USE_OGL)
+ if( msSelectOutputFormat( map, "oglpng24" ) == NULL )
+ msCreateDefaultOutputFormat( map, "OGL/PNG" );
+#endif
#if defined(USE_KML)
if( msSelectOutputFormat( map, "kml" ) == NULL )
msCreateDefaultOutputFormat( map, "kml" );
More information about the mapserver-commits
