[mapserver-commits] r10737 - sandbox/mapserver6
svn at osgeo.org
svn at osgeo.org
Fri Nov 19 09:25:35 EST 2010
Author: tbonfort
Date: 2010-11-19 06:25:35 -0800 (Fri, 19 Nov 2010)
New Revision: 10737
sandbox/mapserver6/mapprimitive.c
avoid superfluous test when computing overlap angle in FOLLOW labels
Modified: sandbox/mapserver6/mapprimitive.c
--- sandbox/mapserver6/mapprimitive.c 2010-11-19 13:54:15 UTC (rev 10736)
+++ sandbox/mapserver6/mapprimitive.c 2010-11-19 14:25:35 UTC (rev 10737)
@@ -1734,7 +1734,7 @@
int kernel_size = 5;
double letterspacing = 1.25;
- double maxoverlapangle = 0;;
+ double maxoverlapangle = 0.4 * MS_PI;
offsets = NULL;
@@ -1810,9 +1810,10 @@
label_repeat = 1;
center_label_position = (line_length - text_length) / 2.0;
+ if(label->maxoverlapangle)
+ maxoverlapangle = label->maxoverlapangle/(180/MS_PI); // radian
- maxoverlapangle = label->maxoverlapangle/(180/MS_PI); // radian
for (l=0; l < label_repeat; l++)
if (l == label_repeat-1) { // last label to place is always the center label
@@ -2000,10 +2001,10 @@
theta = -atan2(dy,dx);
- /* If the difference between subsequent angles is > 80% of 180deg
- bail because the line likely overlaps itself. */
- if ( k > 2 && fabs(theta - labelpath->angles[k-2]) > 0.4 * MS_PI ) {
+ /* If the difference between the last char angle and the current one
+ is greater than the MAXOVERLAPANGLE value (set at 80% of 180deg by default)
+ , bail the label */
+ if ( k > 2 && fabs(theta - labelpath->angles[k-2]) > maxoverlapangle ) {
goto LABEL_FAILURE;
@@ -2011,13 +2012,6 @@
labelpath->angles[k-1] = theta;
- /* If the difference between the last char angle and the current one
- is greater than the MAXOVERLAPANGLE value, bail the label */
- if ( (maxoverlapangle != 0) && (k>1) &&
- (fabs(labelpath->angles[k-1]-labelpath->angles[k-2]) > fabs(maxoverlapangle)) )
- goto LABEL_FAILURE;
/* Move the previous point so that when the character is rotated and
placed it is centred on the line */
More information about the mapserver-commits
