[mapserver-commits] r10763 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Thu Nov 25 15:07:07 EST 2010
Author: dmorissette
Date: 2010-11-25 12:07:07 -0800 (Thu, 25 Nov 2010)
New Revision: 10763
trunk/mapserver/Makefile.in
trunk/mapserver/configure
trunk/mapserver/configure.in
Fixed configure/dependencies when building with libpng, giflib, etc. in non-system dir
Modified: trunk/mapserver/Makefile.in
--- trunk/mapserver/Makefile.in 2010-11-25 17:36:16 UTC (rev 10762)
+++ trunk/mapserver/Makefile.in 2010-11-25 20:07:07 UTC (rev 10763)
@@ -97,6 +97,13 @@
PNG_INC= @PNG_INC@
PNG_LIB= @PNG_LIB@
+# Giflib support
+GIF_INC= @GIF_INC@
+GIF_LIB= @GIF_LIB@
+GIF= @GIF_ENABLED@
# ZLIB option (compressed SVG)
@@ -241,7 +248,8 @@
DEFINES = $(IGNORE_MISSING_DATA) $(USE_POINT_Z_M) $(STRINGS) @ALL_ENABLED@ $(FRIBIDI) -DDISABLE_CVSID
-INCLUDES = $(FT_INC) $(REGEX_INC) $(PNG_INC) $(GD_INC) $(AGG_INC) $(OGL_INC) $(FTGL_INC) $(PROJ_INC) $(JPEG_INC) $(EGIS_INC) \
+INCLUDES = $(FT_INC) $(REGEX_INC) $(PNG_INC) $(GIF_INC) $(JPEG_INC) $(GD_INC) \
+ $(AGG_INC) $(OGL_INC) $(FTGL_INC) $(PROJ_INC) $(EGIS_INC) \
$(SDE_INC) $(GDAL_INC) $(POSTGIS_INC) $(MYGIS_INC) \
$(CURL_INC) $(MING_INC) $(ORACLESPATIAL_INC) $(GEOS_INC) $(ICONV_INC) \
$(FASTCGI_INC) $(ZLIB_INC) $(XML2_INC) $(FRIBIDI_INC) $(CAIRO_INC)
@@ -253,7 +261,7 @@
# Link flags and shared libs only
SUP_LIBS = $(FT_LIB) $(GD_LIB) $(AGG_LIB) $(OGL_LIB) $(FTGL_LIB) $(PROJ_LIBS) \
- $(JPEG_LIB) $(PNG_LIB) $(SDE_LIB) $(GDAL_LIB) $(MING_LIB) $(POSTGIS_LIB) \
+ $(JPEG_LIB) $(PNG_LIB) $(GIF_LIB) $(SDE_LIB) $(GDAL_LIB) $(MING_LIB) $(POSTGIS_LIB) \
$(MYGIS_LIB) $(CURL_LIB) $(ORACLESPATIAL_LIB) $(GEOS_LIB) \
$(THREAD_LIB) $(ICONV_LIB) $(FASTCGI_LIB) $(XSLT_LIB) $(EXSLT_LIB) \
$(ZLIB_LIB) $(XML2_LIB) $(FRIBIDI_LIB) $(XTRALIBS) $(CAIRO_LIB)
Modified: trunk/mapserver/configure
--- trunk/mapserver/configure 2010-11-25 17:36:16 UTC (rev 10762)
+++ trunk/mapserver/configure 2010-11-25 20:07:07 UTC (rev 10763)
@@ -4827,6 +4827,7 @@
_cppflags="$CPPFLAGS"
_ldflags="$LDFLAGS"
+_libs="$LIBS"
CPPFLAGS="$FT_CFLAGS $CPPFLAGS"
LDFLAGS="$FT_LDFLAGS $LDFLAGS"
@@ -5138,6 +5139,7 @@
CPPFLAGS=$_cppflags
LDFLAGS=$_ldflags
+LIBS=$_libs
FT_ENABLED="-DUSE_FREETYPE"
FT_ENABLED=$FT_ENABLED
@@ -6006,10 +6008,10 @@
fi
if test -n "$GIF_INCLUDE" ; then
- as_ac_Header=`echo "ac_cv_header_$GIF_INCLUDE/png.h" | $as_tr_sh`
+ as_ac_Header=`echo "ac_cv_header_$GIF_INCLUDE/gif_lib.h" | $as_tr_sh`
if eval "test \"\${$as_ac_Header+set}\" = set"; then
- echo "$as_me:$LINENO: checking for $GIF_INCLUDE/png.h" >&5
-echo $ECHO_N "checking for $GIF_INCLUDE/png.h... $ECHO_C" >&6
+ echo "$as_me:$LINENO: checking for $GIF_INCLUDE/gif_lib.h" >&5
+echo $ECHO_N "checking for $GIF_INCLUDE/gif_lib.h... $ECHO_C" >&6
echo $ECHO_N "(cached) $ECHO_C" >&6
fi
@@ -6017,8 +6019,8 @@
echo "${ECHO_T}`eval echo '${'$as_ac_Header'}'`" >&6
else
# Is the header compilable?
-echo "$as_me:$LINENO: checking $GIF_INCLUDE/png.h usability" >&5
-echo $ECHO_N "checking $GIF_INCLUDE/png.h usability... $ECHO_C" >&6
+echo "$as_me:$LINENO: checking $GIF_INCLUDE/gif_lib.h usability" >&5
+echo $ECHO_N "checking $GIF_INCLUDE/gif_lib.h usability... $ECHO_C" >&6
cat >conftest.$ac_ext <<_ACEOF
/* confdefs.h. */
_ACEOF
@@ -6026,7 +6028,7 @@
cat >>conftest.$ac_ext <<_ACEOF
/* end confdefs.h. */
$ac_includes_default
-#include <$GIF_INCLUDE/png.h>
+#include <$GIF_INCLUDE/gif_lib.h>
_ACEOF
rm -f conftest.$ac_objext
if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
@@ -6062,15 +6064,15 @@
echo "${ECHO_T}$ac_header_compiler" >&6
# Is the header present?
-echo "$as_me:$LINENO: checking $GIF_INCLUDE/png.h presence" >&5
-echo $ECHO_N "checking $GIF_INCLUDE/png.h presence... $ECHO_C" >&6
+echo "$as_me:$LINENO: checking $GIF_INCLUDE/gif_lib.h presence" >&5
+echo $ECHO_N "checking $GIF_INCLUDE/gif_lib.h presence... $ECHO_C" >&6
/* confdefs.h. */
_ACEOF
cat confdefs.h >>conftest.$ac_ext
_ACEOF
if { (eval echo "$as_me:$LINENO: \"$ac_cpp conftest.$ac_ext\"") >&5
(eval $ac_cpp conftest.$ac_ext) 2>conftest.er1
@@ -6104,25 +6106,25 @@
# So? What about this header?
case $ac_header_compiler:$ac_header_preproc:$ac_c_preproc_warn_flag in
yes:no: )
- { echo "$as_me:$LINENO: WARNING: $GIF_INCLUDE/png.h: accepted by the compiler, rejected by the preprocessor!" >&5
-echo "$as_me: WARNING: $GIF_INCLUDE/png.h: accepted by the compiler, rejected by the preprocessor!" >&2;}
- { echo "$as_me:$LINENO: WARNING: $GIF_INCLUDE/png.h: proceeding with the compiler's result" >&5
-echo "$as_me: WARNING: $GIF_INCLUDE/png.h: proceeding with the compiler's result" >&2;}
+ { echo "$as_me:$LINENO: WARNING: $GIF_INCLUDE/gif_lib.h: accepted by the compiler, rejected by the preprocessor!" >&5
+echo "$as_me: WARNING: $GIF_INCLUDE/gif_lib.h: accepted by the compiler, rejected by the preprocessor!" >&2;}
+ { echo "$as_me:$LINENO: WARNING: $GIF_INCLUDE/gif_lib.h: proceeding with the compiler's result" >&5
+echo "$as_me: WARNING: $GIF_INCLUDE/gif_lib.h: proceeding with the compiler's result" >&2;}
ac_header_preproc=yes
no:yes:* )
- { echo "$as_me:$LINENO: WARNING: $GIF_INCLUDE/png.h: present but cannot be compiled" >&5
-echo "$as_me: WARNING: $GIF_INCLUDE/png.h: present but cannot be compiled" >&2;}
- { echo "$as_me:$LINENO: WARNING: $GIF_INCLUDE/png.h: check for missing prerequisite headers?" >&5
-echo "$as_me: WARNING: $GIF_INCLUDE/png.h: check for missing prerequisite headers?" >&2;}
- { echo "$as_me:$LINENO: WARNING: $GIF_INCLUDE/png.h: see the Autoconf documentation" >&5
-echo "$as_me: WARNING: $GIF_INCLUDE/png.h: see the Autoconf documentation" >&2;}
- { echo "$as_me:$LINENO: WARNING: $GIF_INCLUDE/png.h: section \"Present But Cannot Be Compiled\"" >&5
-echo "$as_me: WARNING: $GIF_INCLUDE/png.h: section \"Present But Cannot Be Compiled\"" >&2;}
- { echo "$as_me:$LINENO: WARNING: $GIF_INCLUDE/png.h: proceeding with the preprocessor's result" >&5
-echo "$as_me: WARNING: $GIF_INCLUDE/png.h: proceeding with the preprocessor's result" >&2;}
- { echo "$as_me:$LINENO: WARNING: $GIF_INCLUDE/png.h: in the future, the compiler will take precedence" >&5
-echo "$as_me: WARNING: $GIF_INCLUDE/png.h: in the future, the compiler will take precedence" >&2;}
+ { echo "$as_me:$LINENO: WARNING: $GIF_INCLUDE/gif_lib.h: present but cannot be compiled" >&5
+echo "$as_me: WARNING: $GIF_INCLUDE/gif_lib.h: present but cannot be compiled" >&2;}
+ { echo "$as_me:$LINENO: WARNING: $GIF_INCLUDE/gif_lib.h: check for missing prerequisite headers?" >&5
+echo "$as_me: WARNING: $GIF_INCLUDE/gif_lib.h: check for missing prerequisite headers?" >&2;}
+ { echo "$as_me:$LINENO: WARNING: $GIF_INCLUDE/gif_lib.h: see the Autoconf documentation" >&5
+echo "$as_me: WARNING: $GIF_INCLUDE/gif_lib.h: see the Autoconf documentation" >&2;}
+ { echo "$as_me:$LINENO: WARNING: $GIF_INCLUDE/gif_lib.h: section \"Present But Cannot Be Compiled\"" >&5
+echo "$as_me: WARNING: $GIF_INCLUDE/gif_lib.h: section \"Present But Cannot Be Compiled\"" >&2;}
+ { echo "$as_me:$LINENO: WARNING: $GIF_INCLUDE/gif_lib.h: proceeding with the preprocessor's result" >&5
+echo "$as_me: WARNING: $GIF_INCLUDE/gif_lib.h: proceeding with the preprocessor's result" >&2;}
+ { echo "$as_me:$LINENO: WARNING: $GIF_INCLUDE/gif_lib.h: in the future, the compiler will take precedence" >&5
+echo "$as_me: WARNING: $GIF_INCLUDE/gif_lib.h: in the future, the compiler will take precedence" >&2;}
cat <<\_ASBOX
@@ -6133,8 +6135,8 @@
sed "s/^/$as_me: WARNING: /" >&2
esac
-echo "$as_me:$LINENO: checking for $GIF_INCLUDE/png.h" >&5
+echo "$as_me:$LINENO: checking for $GIF_INCLUDE/gif_lib.h" >&5
else
@@ -6147,8 +6149,8 @@
if test `eval echo '${'$as_ac_Header'}'` = yes; then
GIF_INC=-I$GIF_INCLUDE
else
- { { echo "$as_me:$LINENO: error: cannot find png headers" >&5
-echo "$as_me: error: cannot find png headers" >&2;}
+ { { echo "$as_me:$LINENO: error: cannot find gif headers" >&5
+echo "$as_me: error: cannot find gif headers" >&2;}
{ (exit 1); exit 1; }; }
fi
@@ -6465,6 +6467,7 @@
_ldflags="$LDFLAGS"
+ _libs="$LIBS"
CPPFLAGS="$JPEG_INC $CPPFLAGS"
LDFLAGS="$JPEG_LIB $LDFLAGS"
@@ -6694,11 +6697,13 @@
JPEG_ENABLED="-DUSE_JPEG"
CPPFLAGS=$_cppflags
LDFLAGS=$_ldflags
+ LIBS=$_libs
echo "$as_me:$LINENO: result: using libjpeg from system $JPEG_LIB" >&5
echo "${ECHO_T} using libjpeg from system $JPEG_LIB" >&6
else
echo "$as_me:$LINENO: checking for jpeg_read_header in -ljpeg" >&5
echo $ECHO_N "checking for jpeg_read_header in -ljpeg... $ECHO_C" >&6
if test "${ac_cv_lib_jpeg_jpeg_read_header+set}" = set; then
Modified: trunk/mapserver/configure.in
--- trunk/mapserver/configure.in 2010-11-25 17:36:16 UTC (rev 10762)
+++ trunk/mapserver/configure.in 2010-11-25 20:07:07 UTC (rev 10763)
@@ -175,6 +175,7 @@
_ldflags="$LDFLAGS"
+_libs="$LIBS"
@@ -186,6 +187,7 @@
CPPFLAGS=$_cppflags
LDFLAGS=$_ldflags
+LIBS=$_libs
AC_SUBST(FT_ENABLED,$FT_ENABLED)
AC_SUBST(FT_INC,$FT_CFLAGS)
@@ -367,8 +369,8 @@
fi
- AC_CHECK_HEADER([$GIF_INCLUDE/png.h],GIF_INC=-I$GIF_INCLUDE,
- [AC_MSG_ERROR([cannot find png headers])])
+ AC_CHECK_HEADER([$GIF_INCLUDE/gif_lib.h],GIF_INC=-I$GIF_INCLUDE,
+ [AC_MSG_ERROR([cannot find gif headers])])
ALL_INC="$GIF_INC $ALL_INC"
else
AC_MSG_ERROR([cannot find gif headers in $GIF_DIR])
@@ -432,6 +434,7 @@
_ldflags="$LDFLAGS"
+ _libs="$LIBS"
AC_CHECK_LIB(jpeg, jpeg_read_header,,AC_MSG_ERROR(["cannot link with libjpeg"]),,)
@@ -439,9 +442,12 @@
CPPFLAGS=$_cppflags
LDFLAGS=$_ldflags
+ LIBS=$_libs
AC_MSG_RESULT([ using libjpeg from system $JPEG_LIB])
else
+ dnl Look for libjpeg in system dirs
AC_CHECK_HEADER(jpeglib.h,,AC_MSG_ERROR(["cannot find jpeg headers"]))
More information about the mapserver-commits
