[mapserver-commits] r10764 - branches/branch-5-6/mapserver
Thu Nov 25 15:28:32 EST 2010
Author: aboudreault
Date: 2010-11-25 12:28:32 -0800 (Thu, 25 Nov 2010)
New Revision: 10764
   branches/branch-5-6/mapserver/HISTORY.TXT
   branches/branch-5-6/mapserver/shp2img.c
Backport 5.6: Fixed double free in shp2img.c (#3497)
Modified: branches/branch-5-6/mapserver/HISTORY.TXT
--- branches/branch-5-6/mapserver/HISTORY.TXT	2010-11-25 20:07:07 UTC (rev 10763)
+++ branches/branch-5-6/mapserver/HISTORY.TXT	2010-11-25 20:28:32 UTC (rev 10764)
@@ -14,6 +14,8 @@
 Current Version
+- Fixed double free in shp2img.c (#3497)
 - Fixed free(): invalid next size in mapfile.c (#3604)
 - Fix for the memory corruption when mapping the string data type in the Java bindings (3491)
Modified: branches/branch-5-6/mapserver/shp2img.c
--- branches/branch-5-6/mapserver/shp2img.c	2010-11-25 20:07:07 UTC (rev 10763)
+++ branches/branch-5-6/mapserver/shp2img.c	2010-11-25 20:28:32 UTC (rev 10764)
@@ -43,7 +43,6 @@
   int num_layers=0;
   int layer_found=0;
-  char *invalid_layer=NULL;
   char *outfile=NULL; /* no -o sends image to STDOUT */
@@ -256,25 +255,18 @@
       layers = msStringSplit(argv[i+1], ' ', &(num_layers));
       for(j=0; j<num_layers; j++) { /* loop over -l */
-        layer_found=0;
-        for(k=0; k<map->numlayers; k++) {
-          if(GET_LAYER(map, k)->name && strcmp(GET_LAYER(map, k)->name, layers[j]) == 0) {
-            layer_found=1;
-            break;
+          layer_found=0;
+          for(k=0; k<map->numlayers; k++) {
+              if(GET_LAYER(map, k)->name && strcmp(GET_LAYER(map, k)->name, layers[j]) == 0) {
+                  layer_found = 1;
+                  break;
-          else {
-            if (invalid_layer)
-              free(invalid_layer);
-            invalid_layer = strdup(layers[j]);
+          if (layer_found==0) {
+              fprintf(stderr, "Layer (-l) \"%s\" not found\n", layers[j]);
+              msCleanup();
+              exit(0);
-        if (layer_found==0) {
-          fprintf(stderr, "Layer (-l) %s not found\n", invalid_layer);
-          msCleanup();
-          exit(0);
       for(j=0; j<map->numlayers; j++) {
