[mapserver-commits] r10765 - trunk/mapserver
Fri Nov 26 14:15:50 EST 2010
Author: assefa
Date: 2010-11-26 11:15:50 -0800 (Fri, 26 Nov 2010)
New Revision: 10765
   trunk/mapserver/mapkmlrenderer.cpp
   trunk/mapserver/mapoutput.c
add kmz support #3620
Modified: trunk/mapserver/mapkmlrenderer.cpp
--- trunk/mapserver/mapkmlrenderer.cpp	2010-11-25 20:28:32 UTC (rev 10764)
+++ trunk/mapserver/mapkmlrenderer.cpp	2010-11-26 19:15:50 UTC (rev 10765)
@@ -35,6 +35,12 @@
 #include "mapio.h"
+#if defined(USE_OGR)
+#  include "cpl_conv.h"
+#  include "cpl_vsi.h"
+#endif
 KmlRenderer::KmlRenderer(int width, int height, outputFormatObj *format, colorObj* color/*=NULL*/)
 	:	XmlDoc(NULL), LayerNode(NULL), GroundOverlayNode(NULL), Width(width), Height(height),
 		FirstLayer(MS_TRUE), MapCellsize(1.0),
@@ -105,7 +111,7 @@
 	return NULL;
-int KmlRenderer::saveImage(imageObj *, FILE *fp, outputFormatObj*)
+int KmlRenderer::saveImage(imageObj *, FILE *fp, outputFormatObj *format)
@@ -115,15 +121,72 @@
     int bufSize = 0;
     xmlChar *buf = NULL;
     msIOContext *context = NULL;
+    int chunkSize = 4096;
+    int bZip = MS_FALSE;
     if( msIO_needBinaryStdout() == MS_FAILURE )
       return MS_FAILURE;
-    xmlDocDumpFormatMemoryEnc(XmlDoc, &buf, &bufSize, "UTF-8", 1);
+   xmlDocDumpFormatMemoryEnc(XmlDoc, &buf, &bufSize, "UTF-8", 1);
+    if (format && format->driver && strcasecmp(format->driver, "kmz") == 0)
+#if defined(CPL_ZIP_API_OFFERED)
+        bZip = MS_TRUE;
+#else
+        msSetError( MS_MISCERR, "kmz format support unavailable, perhaps you need to upgrade to GDAL/OGR 1.8?",
+                    "KmlRenderer::saveImage()");
+        xmlFree(buf);
+        return MS_FAILURE;
+#endif
+    if (bZip)
+        VSILFILE *fpZip;
+        int bytes_read;
+        char buffer[1024];
+        char *zip_filename =NULL;
+        void *hZip=NULL;
+        zip_filename = msTmpFile( NULL, "/vsimem/kmlzip/", "kmz" );
+        hZip = CPLCreateZip( zip_filename, NULL );
+        CPLCreateFileInZip( hZip, "mapserver.kml", NULL );
+        for (int i=0; i<bufSize; i+=chunkSize)
+             int size = chunkSize;
+             if (i + size > bufSize)
+               size = bufSize - i;
+             CPLWriteFileInZip( hZip,  buf+i, size);
+        CPLCloseFileInZip( hZip );
+        CPLCloseZip( hZip );
+        context = msIO_getHandler(fp);
+        fpZip = VSIFOpenL( zip_filename, "r" );
+         while( (bytes_read = VSIFReadL( buffer, 1, sizeof(buffer), fpZip )) > 0 )
+             if (context)
+               msIO_contextWrite(context, buffer, bytes_read);
+             else
+               msIO_fwrite( buffer, 1, bytes_read, fp );
+         VSIFCloseL( fpZip );
+         msFree( zip_filename);
+         xmlFree(buf);
+         return(MS_SUCCESS);
+#endif
+#endif
-    int chunkSize = 4096;
Modified: trunk/mapserver/mapoutput.c
--- trunk/mapserver/mapoutput.c	2010-11-25 20:28:32 UTC (rev 10764)
+++ trunk/mapserver/mapoutput.c	2010-11-26 19:15:50 UTC (rev 10765)
@@ -255,7 +255,17 @@
         format->imagemode = MS_IMAGEMODE_RGB;
         format->extension = strdup("kml");
         format->renderer = MS_RENDER_WITH_KML;
+        msSetOutputFormatOption( format, "ATTACHMENT", "mapserver.kml");
+    if( strcasecmp(driver,"KMZ") == 0 )
+        format = msAllocOutputFormat( map, "kmz", driver );
+        format->mimetype = strdup("application/vnd.google-earth.kmz");
+        format->imagemode = MS_IMAGEMODE_RGB;
+        format->extension = strdup("kmz");
+        format->renderer = MS_RENDER_WITH_KML;
+        msSetOutputFormatOption( format, "ATTACHMENT", "mapserver.kmz");
 #endif
 #ifdef USE_MING_FLASH
@@ -385,6 +395,8 @@
 #if defined(USE_KML)
     if( msSelectOutputFormat( map, "kml" ) == NULL )
         msCreateDefaultOutputFormat( map, "kml" );
+    if( msSelectOutputFormat( map, "kmz" ) == NULL )
+        msCreateDefaultOutputFormat( map, "kmz" );
 #endif
     if( map->imagetype != NULL )
@@ -943,7 +955,8 @@
                 strncasecmp(map->outputformatlist[i]->driver, "GDAL/", 5)==0 ||
                 strncasecmp(map->outputformatlist[i]->driver, "AGG/", 4)==0 ||
                 strcasecmp(map->outputformatlist[i]->driver, "svg")==0 ||
-                strcasecmp(map->outputformatlist[i]->driver, "kml")==0))
+                strcasecmp(map->outputformatlist[i]->driver, "kml")==0 ||
+                strcasecmp(map->outputformatlist[i]->driver, "kmz")==0))
               mime_list[mime_count++] = map->outputformatlist[i]->mimetype;
