[mapserver-commits] r10508 - sandbox/sdlime/common-expressions/mapserver
Fri Sep 17 16:52:33 EDT 2010
Author: assefa
Date: 2010-09-17 20:52:33 +0000 (Fri, 17 Sep 2010)
New Revision: 10508
   sandbox/sdlime/common-expressions/mapserver/mapogcfilter.c
   sandbox/sdlime/common-expressions/mapserver/mapogcfilter.h
   sandbox/sdlime/common-expressions/mapserver/mapwfs.c
add initial support for binary and logical common expressions
Modified: sandbox/sdlime/common-expressions/mapserver/mapogcfilter.c
--- sandbox/sdlime/common-expressions/mapserver/mapogcfilter.c	2010-09-17 16:07:02 UTC (rev 10507)
+++ sandbox/sdlime/common-expressions/mapserver/mapogcfilter.c	2010-09-17 20:52:33 UTC (rev 10508)
@@ -3093,6 +3093,8 @@
     int bString=0;
     char szTmp[256];
     szBuffer[0] = '\0';
     if (!psFilterNode || !FLTIsBinaryComparisonFilterType(psFilterNode->pszValue))
       return NULL;
@@ -3121,7 +3123,7 @@
       strcat(szBuffer, " (\"[");
     else
       strcat(szBuffer, " ([");
-    /* attribute */
     strcat(szBuffer, psFilterNode->psLeftNode->pszValue);
     if (bString)
@@ -4070,47 +4072,135 @@
-int FLTGetLogicalComparisonExpresssionObj(FilterEncodingNode *psFilterNode, layerObj *lp,
-                                         expressionObj *expression)
+char *FLTGetIsBetweenComparisonCommonExpresssion(FilterEncodingNode *psFilterNode,
+                                                 layerObj *lp)
+    char szBuffer[256];
+    char **aszBounds = NULL;
+    int nBounds = 0;
+    int bString=0;
+    char *pszExpression=NULL;
+    if (!psFilterNode ||
+        !(strcasecmp(psFilterNode->pszValue, "PropertyIsBetween") == 0))
+      return NULL;
+    if (!psFilterNode->psLeftNode || !psFilterNode->psRightNode )
+      return NULL;
-/*      OR and AND                                                      */
+/*      Get the bounds value which are stored like boundmin;boundmax    */
-    if (psFilterNode->psLeftNode && psFilterNode->psRightNode)
+    aszBounds = msStringSplit(psFilterNode->psRightNode->pszValue, ';', &nBounds);
+    if (nBounds != 2)
+      return NULL;
+/*      check if the value is a numeric value or alphanumeric. If it    */
+/*      is alphanumeric, add quotes around attribute and values.        */
+    bString = 0;
+    if (aszBounds[0])
-        FLTFilterNodeToExpressionObj(psFilterNode->psLeftNode, lp /*, exp TODO: non working code, FIXME */);
-        if (strcasecmp(psFilterNode->pszValue, "AND") == 0)
-          expression->tokens[expression->numtokens++].token = MS_TOKEN_LOGICAL_AND;
-        else
-          expression->tokens[expression->numtokens++].token = MS_TOKEN_LOGICAL_OR;
-        FLTFilterNodeToExpressionObj(psFilterNode->psRightNode, lp /*, exp TODO: non working code, FIXME */);
+        sprintf(szBuffer, "%s_type",  psFilterNode->psLeftNode->pszValue);
+        if (msOWSLookupMetadata(&(lp->metadata), "OFG", szBuffer) != NULL &&
+            (strcasecmp(msOWSLookupMetadata(&(lp->metadata), "G", szBuffer), "Character") == 0))
+          bString = 1;
+        else if (FLTIsNumeric(aszBounds[0]) == MS_FALSE)
+          bString = 1;
+    if (!bString)
+        if (aszBounds[1])
+            if (FLTIsNumeric(aszBounds[1]) == MS_FALSE)
+              bString = 1;
-/*      NOT                                                             */
+/*      build expresssion.                                              */
-    else if (psFilterNode->psLeftNode &&
-             strcasecmp(psFilterNode->pszValue, "NOT") == 0)
+    /* attribute */
+    if (bString)
+      sprintf(szBuffer,  "%s", " (\"[");
+    else
+      sprintf(szBuffer, "%s", " ([");
+    pszExpression = msStringConcatenate(pszExpression, szBuffer);
+    pszExpression = msStringConcatenate(pszExpression, psFilterNode->psLeftNode->pszValue);
+    if (bString)
+      sprintf(szBuffer, "%s", "]\" ");
+    else
+      sprintf(szBuffer, "%s", "] ");
+    sprintf(szBuffer, "%s", " >= ");
+    if (bString)
-        expression->tokens[expression->numtokens++].token = MS_TOKEN_LOGICAL_NOT;
-        FLTFilterNodeToExpressionObj(psFilterNode->psLeftNode, lp);
+        sprintf(szBuffer,"%s", "\"");
-    return MS_TRUE;
+    sprintf(szBuffer, "%s", aszBounds[0]);
+    if (bString)
+        sprintf(szBuffer, "%s", "\"");
+    sprintf(szBuffer, "%s", " AND ");
-int FLTGetBinaryComparisonExpresssionObj(FilterEncodingNode *psFilterNode, layerObj *lp,
+    if (bString)
+      sprintf(szBuffer, "%s", " \"[");
+    else
+      sprintf(szBuffer, "%s", " [");
+    /* attribute */
+    if (bString)
+    else
+    sprintf(szBuffer, "%s", " <= ");
+    if (bString)
+    sprintf(szBuffer, "%s", aszBounds[1]);
+    if (bString)
+        sprintf(szBuffer,"\"");
+    strcat(szBuffer, ")");
+    return pszExpression;
+char *FLTGetBinaryComparisonCommonExpression(FilterEncodingNode *psFilterNode, layerObj *lp)
-    int n=0;
-    int bString=0;
-    char szTmp[256];
+     char szTmp[256];
+     char *pszExpression = NULL;
+     int bString;
-    if (!expression)
-      return MS_FALSE;
-    if (!psFilterNode || !FLTIsBinaryComparisonFilterType(psFilterNode->pszValue))
-      return  MS_FALSE;
+     if (!psFilterNode || !FLTIsBinaryComparisonFilterType(psFilterNode->pszValue))
+      return NULL;
@@ -4131,83 +4221,186 @@
     if (psFilterNode->psRightNode->pszValue == NULL)
       bString = 1;
-    n = expression->numtokens;
+    /* attribute */
     if (bString)
-      expression->tokens[n].token = MS_TOKEN_BINDING_STRING;
+      sprintf(szTmp, "%s", " (\"[");
     else
-      expression->tokens[n].token = MS_TOKEN_BINDING_DOUBLE;
-    expression->tokens[n].tokenval.bindval.item = strdup(psFilterNode->psLeftNode->pszValue);
+      sprintf(szTmp,  "%s"," ([");
+    pszExpression = msStringConcatenate(pszExpression, szTmp);
+    if (bString)
+      sprintf(szTmp,  "%s","]\" ");
+    else
+      sprintf(szTmp,  "%s", "] ");
-    n++;
-    /* logical operator */
                    "PropertyIsEqualTo") == 0)
         /*case insensitive set ? */
         if (psFilterNode->psRightNode->pOther &&
             (*(int *)psFilterNode->psRightNode->pOther) == 1)
-          expression->tokens[n].token = MS_TOKEN_COMPARISON_IEQ;
+          sprintf(szTmp,  "%s", "=="); /*TODO whar should be this??*/
         else
-          expression->tokens[n].token =  MS_TOKEN_COMPARISON_EQ;
     else if (strcasecmp(psFilterNode->pszValue,
                         "PropertyIsNotEqualTo") == 0)
-      expression->tokens[n].token = MS_TOKEN_COMPARISON_NE;
+      sprintf(szTmp,  "%s", " != ");
                         "PropertyIsLessThan") == 0)
-      expression->tokens[n].token = MS_TOKEN_COMPARISON_LT;
+      sprintf(szTmp,  "%s", " < ");
                         "PropertyIsGreaterThan") == 0)
-      expression->tokens[n].token = MS_TOKEN_COMPARISON_GT;
+      sprintf(szTmp,  "%s", " > ");
                         "PropertyIsLessThanOrEqualTo") == 0)
-      expression->tokens[n].token = MS_TOKEN_COMPARISON_LE;
+      sprintf(szTmp,  "%s", " <= ");
                         "PropertyIsGreaterThanOrEqualTo") == 0)
-       expression->tokens[n].token = MS_TOKEN_COMPARISON_GE;
+      sprintf(szTmp,  "%s", " >= ");
+    else if (strcasecmp(psFilterNode->pszValue,
+                        "PropertyIsLike") == 0)
+      sprintf(szTmp,  "%s", " ~* ");
+    /* value */
+    if (bString)
+      sprintf(szTmp,  "%s", "\"");
+    if (psFilterNode->psRightNode->pszValue)
+      pszExpression = msStringConcatenate(pszExpression, psFilterNode->psRightNode->pszValue);
-    n++;
-    expression->tokens[n].token = MS_TOKEN_LITERAL_STRING;
-    expression->tokens[n].tokenval.strval = strdup(psFilterNode->psRightNode->pszValue);
+    if (bString)
+      sprintf(szTmp,  "%s", "\") ");
-    expression->numtokens = n;
-    return  MS_TRUE;
+char *FLTGetLogicalComparisonCommonExpression(FilterEncodingNode *psFilterNode, layerObj *lp)
+    char *pszTmp = NULL;
+    if (!psFilterNode || !FLTIsLogicalFilterType(psFilterNode->pszValue))
+      return NULL;
+/*      OR and AND                                                      */
+    if (psFilterNode->psLeftNode && psFilterNode->psRightNode)
+        pszTmp = FLTFilterNodeToCommonExpression(psFilterNode->psLeftNode, lp);
+        if (!pszTmp)
+          return NULL;
+        sprintf(szBuffer, "%s", " (");
+        pszExpression = msStringConcatenate(pszExpression, pszTmp);
+        msFree(pszTmp);
+        sprintf(szBuffer, "%s", " ");
+        pszExpression = msStringConcatenate(pszExpression, psFilterNode->pszValue);
+        pszTmp = FLTFilterNodeToCommonExpression(psFilterNode->psRightNode, lp);
+        if (!pszTmp)
+          return NULL;
+        msFree(pszTmp);
+        sprintf(szBuffer, "%s", ") ");
+/*      NOT                                                             */
+    else if (psFilterNode->psLeftNode &&
+             strcasecmp(psFilterNode->pszValue, "NOT") == 0)
+        if (!pszTmp)
+          return NULL;
+        sprintf(szBuffer, "%s", " (NOT ");
+        msFree(pszTmp);
-expressionObj *FLTFilterNodeToExpressionObj(FilterEncodingNode *psFilterNode, layerObj *lp)
+char *FLTFilterNodeToCommonExpression(FilterEncodingNode *psFilterNode, layerObj *lp)
-    expressionObj *exp =NULL;
     if (!psFilterNode)
       return NULL;
-    exp = (expressionObj *)malloc(sizeof(expressionObj));
-    exp->numtokens = 0;
-    //initExpression(exp);
     if (psFilterNode->eType == FILTER_NODE_TYPE_COMPARISON)
         if ( psFilterNode->psLeftNode && psFilterNode->psRightNode)
             if (FLTIsBinaryComparisonFilterType(psFilterNode->pszValue))
-                FLTGetBinaryComparisonExpresssionObj(psFilterNode, lp, exp);
+                pszExpression = FLTGetBinaryComparisonCommonExpression(psFilterNode, lp);
+        else if (strcasecmp(psFilterNode->pszValue, "PropertyIsBetween") == 0)
+            pszExpression = FLTGetIsBetweenComparisonCommonExpresssion(psFilterNode, lp);
     else if (psFilterNode->eType == FILTER_NODE_TYPE_LOGICAL)
-      FLTGetLogicalComparisonExpresssionObj(psFilterNode, lp, exp);
+      pszExpression = FLTGetLogicalComparisonCommonExpression(psFilterNode, lp);
-    return exp;
+int FLTApplyFilterToLayerCommonExpression(mapObj *map, int iLayerIndex, char *pszExpression)
+    int retval;
+    //msFreeQuery(&(map->query));
+     /* TODO : this should be done but crashs query->filter is corrupted and not NULL*/
+    // msInitQuery(&(map->query));
+    map->query.type = MS_QUERY_BY_FILTER;
+    map->query.filter = (expressionObj *) malloc(sizeof(expressionObj));
+    map->query.filter->string = strdup(pszExpression);
+    map->query.filter->type = 2000;
+    map->query.layer = iLayerIndex;
+    map->query.rect = map->extent;
+    retval = msQueryByFilter(map);
+    return retval;
 #ifdef USE_LIBXML2
 xmlNodePtr FLTGetCapabilities(xmlNsPtr psNsParent, xmlNsPtr psNsOgc, int bTemporal)
Modified: sandbox/sdlime/common-expressions/mapserver/mapogcfilter.h
--- sandbox/sdlime/common-expressions/mapserver/mapogcfilter.h	2010-09-17 16:07:02 UTC (rev 10507)
+++ sandbox/sdlime/common-expressions/mapserver/mapogcfilter.h	2010-09-17 20:52:33 UTC (rev 10508)
@@ -122,8 +122,14 @@
 MS_DLL_EXPORT int FLTParseGMLEnvelope(CPLXMLNode *psRoot, rectObj *psBbox, char **ppszSRS);
 MS_DLL_EXPORT  int FLTParseGMLBox(CPLXMLNode *psBox, rectObj *psBbox, char **ppszSRS);
-expressionObj *FLTFilterNodeToExpressionObj(FilterEncodingNode *psFilterNode, layerObj *lp);
+/*common-expressions*/
+MS_DLL_EXPORT   char *FLTGetBinaryComparisonCommonExpression(FilterEncodingNode *psFilterNode, layerObj *lp);
+MS_DLL_EXPORT  char *FLTFilterNodeToCommonExpression(FilterEncodingNode *psFilterNode, layerObj *lp);
+MS_DLL_EXPORT int FLTApplyFilterToLayerCommonExpression(mapObj *map, int iLayerIndex, char *pszExpression);
 #ifdef USE_LIBXML2
 MS_DLL_EXPORT xmlNodePtr FLTGetCapabilities(xmlNsPtr psNsParent, xmlNsPtr psNsOgc, int bTemporal);
 #endif
Modified: sandbox/sdlime/common-expressions/mapserver/mapwfs.c
--- sandbox/sdlime/common-expressions/mapserver/mapwfs.c	2010-09-17 16:07:02 UTC (rev 10507)
+++ sandbox/sdlime/common-expressions/mapserver/mapwfs.c	2010-09-17 20:52:33 UTC (rev 10508)
@@ -1782,6 +1782,8 @@
       /*      or groups. Need to be a bit more sophisticated here.            */
       for (i=0; i<nFilters; i++) {
 	iLayerIndex = msGetLayerIndex(map, layers[i]);
 	if (iLayerIndex < 0) {
 	  msSetError(MS_WFSERR, "Invalid Typename in GetFeature : %s", "msWFSGetFeature()", layers[i]);
@@ -1813,9 +1815,13 @@
         /*preparse the filter for gml aliases*/
         FLTPreParseFilterForAlias(psNode, map, iLayerIndex, "G");
+        pszExpression = FLTFilterNodeToCommonExpression(psNode,  GET_LAYER(map, iLayerIndex));
         /* run filter.  If no results are found, do not throw exception */
         /* this is a null result */
-        if( FLTApplyFilterToLayer(psNode, map, iLayerIndex, MS_FALSE) != MS_SUCCESS )
+        /*if( FLTApplyFilterToLayer(psNode, map, iLayerIndex, MS_FALSE) != MS_SUCCESS ) */
+        if (FLTApplyFilterToLayerCommonExpression(map, iLayerIndex, pszExpression) != MS_SUCCESS )
             ms_error = msGetErrorObj();
@@ -1826,8 +1832,11 @@
-         FLTFreeFilterEncodingNode( psNode );
+        FLTFreeFilterEncodingNode( psNode );
         psNode = NULL;
+        if (pszExpression)
+          msFree(pszExpression);
       if (paszFilter)
