[mapserver-commits] r10509 - trunk/docs/en/development/rfc
Sat Sep 18 17:09:20 EDT 2010
Author: tamas
Date: 2010-09-18 21:09:20 +0000 (Sat, 18 Sep 2010)
New Revision: 10509
   trunk/docs/en/development/rfc/ms-rfc-61.txt
Clarify some things, and add reference to the corresponding ticket.
Modified: trunk/docs/en/development/rfc/ms-rfc-61.txt
--- trunk/docs/en/development/rfc/ms-rfc-61.txt	2010-09-17 20:52:33 UTC (rev 10508)
+++ trunk/docs/en/development/rfc/ms-rfc-61.txt	2010-09-18 21:09:20 UTC (rev 10509)
@@ -13,7 +13,7 @@
 Description: This RFC proposes a generic implementation for rendering
 the feature styles retrieved from the various data sources. In this
-regard we intend to enhance the existing STYLEITEM "AUTO" option
+regard we intend to enhance the existing STYLEITEM option
 which could now be specified for all layer types and not restricted
 to the OGR driver.
@@ -42,40 +42,66 @@
 Currently the style string transferred this way can only be rendered by
-the MapServer OGR driver, however it would be reasonable to implement this
+the MapServer OGR driver, however it would be reasonable to implement such
 option for all layer types in MapServer.
 Proposed New Syntax
-We can continue to use the current STYLEITEM "AUTO" syntax, which
-will now be implemented for all layers. In this case the default
-implementation will retrieve the style string from the attribute
-with the name 'OGR_STYLE'.
+This RFC wouldn't alter the current behaviour of STYLEITEM "AUTO" option, which causes
+the driver specific LayerGetAutoStyle vtable method to be called as before.
+If LayerGetAutoStyle is not implemented by a driver an error message is
+provided to the user "'STYLEITEM AUTO' not supported for this data source."
-In addition, we will implement support to specify the renamed
-attributes by using the STYLEITEM "mystyleattribute" in the layer
-definitions of the mapfile.
+We will however add support for specifying the feature attribute containing
+the style string in the form: STYLEITEM "mystyleattribute" which
+will tell mapserver to initialize the style from the specified attribute in
+a generic way.
+Supported Style Representations
+We will implement support for either the current mapserver and OGR specific
+style representations.
+The mapserver style representation follows the syntax of the STYLE and CLASS
+entries in the mapfile format like the following sample:
+  "STYLE BACKGROUNDCOLOR 128 0 0 COLOR 0 0 208 END"
+By specifying the entire CLASS instead of a single style allows to use further options
+(like setting expressions, label attributes, multiple styles) on a per feature basis.
+In addition to the mapserver style the OGR style string format will also be supported
+as described in the following documentation: http://www.gdal.org/ogr/ogr_feature_style.html
+The actual style format will be identifyed at run-time according to the first characters of the
+style strings. This solution will allow to specify multiple style formats within the same layer.
 Implementation Details
 In order to implement this enhancement the following changes should be
 made in the MapServer codebase:
-1) Modify msOGRLayerGetAutoStyle (in mapogr.cpp) and extract the bulk of the style
-   initialization into a separate function. We would add a new function where the style manager
-   would be initialized by using OGRStyleMgr::InitStyleString instead of OGRStyleMgr::InitFromFeature
-   msOGRLayerGetAutoStyle should also support extracting the style from an arbitrary field as
-   specified by the STYLEITEM parameter.
+1) Modify msDrawVectorLayer (in mapdraw.cpp) to invoke a new method (msLayerGetFeatureStyle)
+   when STYLEITEM is set for a particular layer.
+2) Implement msLayerGetFeatureStyle in maplayer.c which will call either msUpdateStyleFromString,
+   msUpdateClassFromString or the new method: msOGRUpdateStyleFromString according to
+   the actual style format retrieved from the layer.
-2) Modify LayerDefaultGetAutoStyle (in maplayer.c) to retrieve the style string attribute
-   and call the appropriate function in mapogr.cpp described above.
+3) Modify msOGRLayerGetAutoStyle (in mapogr.cpp) and extract the bulk of the style
+   initialization into a separate function (msOGRUpdateStyle). We will add a new function
+   (msOGRUpdateStyleFromString) where the style manager will be initialized by using
+   OGRStyleMgr::InitStyleString instead of OGRStyleMgr::InitFromFeature
-3) Modify msLayerWhichItems in (maplayer.c) to retrieve the attribute containing the style string
-   specified in the STYLEITEM parameter. Using STYLEITEM "AUTO" would require to retrieve the
-   attribute with name 'OGR_STYLE'. For those layers which override LayerGetAutoStyle with
-   a custom implementation (like the OGR driver) no additional attribute will be retrieved.
+4) Modify msLayerWhichItems in (maplayer.c) to retrieve the attribute containing the style string
+   specified in the STYLEITEM parameter. By using STYLEITEM "AUTO" no additional attribute
+   will be retrieved just as before.
 MapScript Issues
@@ -89,41 +115,43 @@
 To implement the solution the following files would require to be changed:
-- mapserver.h => Add the declaration of a new function implemented in mapogr.cpp
-- mapogr.cpp => Add a new function to process the style string
-- maplayer.c => Implement LayerDefaultGetAutoStyle, modify msLayerWhichItems
+- mapserver.h => Add the declaration for msLayerGetFeatureStyle and msOGRUpdateStyleFromString
+- mapogr.cpp => Add msOGRUpdateStyleFromString and msOGRUpdateStyle
+- maplayer.c => Modify msLayerWhichItems and implement msLayerGetFeatureStyle
+- mapdraw.c => Call msLayerGetFeatureStyle in addition to msLayerGetAutoStyle
 Backwards Compatibilty Issues
-Currently STYLEITEM "AUTO" has only been implemented in the OGR driver which
+Currently 'STYLEITEM "AUTO"' has only been implemented in the OGR driver which
 overrides LayerGetAutoStyle with a custom implementation. This behaviour would
 continue to work as previously since the generic implementation would not affect those
-drivers which provide custom implementation. However msOGRLayerGetAutoStyle should also
-be modified to initialize the style from an arbitrary attribute in addition to the
-"AUTO" option.
+drivers which provide custom auto style implementation.
+When using the 'STYLEITEM "mystyleattribute"' setting, we provide a generic implementation
+to set the style directly from the feature attribute and no driver specific
+function will be called. This option will work for all drivers in the same way.
 Further Considerations
 In the future we may provide support further style representations in addition to
-the OGR style strings. Handling multiple style representations are not covered by
-this RFC, however the generic style implementation could easily be extended in this regard.
-This would require to add a new parameter (or a layer processing) option to select
-how the style attribute should actually be handled in MapServer.
+the mapserver and OGR style strings. Each new representation will require a
+proper (and fast) method to identify the format from the style string itself.
-This generic approach would require the OGR driver to be compiled in. If we compile
-MapServer without OGR support we continue to provide an error message in case of an
-attempt to use the STYLEITEM option in the mapfiles.
+Using the OGR style format will require the OGR driver to be compiled in. If we compile
+MapServer without OGR support and the 'STYLEITEM "mystyleattribute"' option is used,
+those features may not be rendered correctly where the actual style format is OGR
+style string.
-Currently the OracleSpatial driver does override LayerGetAutoStyle just because to provide a
-custom error message when the STYLEITEM option is used. For this driver we should
-probably switch back to the "generic" implementation during the vtable initialization.
 Bug ID
-Not yet assigned
+The ticket for RFC-61 (containing the implementation) can be found here.
+Bug 3544_
+.. _3544: http://trac.osgeo.org/mapserver/ticket/3544
 Voting history
