[mapserver-commits] r10527 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Tue Sep 28 11:35:41 EDT 2010
Author: warmerdam
Date: 2010-09-28 15:35:41 +0000 (Tue, 28 Sep 2010)
New Revision: 10527
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapwmslayer.c
Avoid EPSG lookups for WMS client layers if possible (#3533)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2010-09-28 15:05:24 UTC (rev 10526)
+++ trunk/mapserver/HISTORY.TXT 2010-09-28 15:35:41 UTC (rev 10527)
@@ -14,6 +14,8 @@
Current Version (SVN trunk):
+- Avoid EPSG lookups for WMS client layers if possible (#3533)
- RFC-60: Add ability to skip ANGLE FOLLOW labels with too much character overlap (#3523)
- Fixed SWF: not a valid Bitmap FillStyle (#3548)
Modified: trunk/mapserver/mapwmslayer.c
--- trunk/mapserver/mapwmslayer.c 2010-09-28 15:05:24 UTC (rev 10526)
+++ trunk/mapserver/mapwmslayer.c 2010-09-28 15:35:41 UTC (rev 10527)
@@ -626,18 +626,29 @@
if ((pszTmp = msOWSGetEPSGProj(&(lp->projection), NULL, "MO", MS_TRUE)) == NULL ||
strcasecmp(pszEPSG, pszTmp) != 0)
- if (strncasecmp(pszEPSG, "EPSG:", 5) == 0)
+ const char *ows_srs;
+ /* no need to set lp->proj if it is already set and there is only
+ one item in the _srs metadata for this layer - we will assume
+ the projection block matches the _srs metadata (the search for ' '
+ in ows_srs is a test to see if there are multiple EPSG: codes) */
+ if( lp->projection.numargs == 0
+ || (ows_srs = msOWSGetEPSGProj(NULL,&(lp->metadata), "MO", MS_FALSE)) == NULL
+ || (strchr(ows_srs,' ') != NULL) )
- char szProj[20];
- sprintf(szProj, "init=epsg:%s", pszEPSG+5);
- if (msLoadProjectionString(&(lp->projection), szProj) != 0)
- return MS_FAILURE;
+ if (strncasecmp(pszEPSG, "EPSG:", 5) == 0)
+ char szProj[20];
+ sprintf(szProj, "init=epsg:%s", pszEPSG+5);
+ if (msLoadProjectionString(&(lp->projection), szProj) != 0)
+ return MS_FAILURE;
+ else
+ if (msLoadProjectionString(&(lp->projection), pszEPSG) != 0)
- else
- if (msLoadProjectionString(&(lp->projection), pszEPSG) != 0)
@@ -660,10 +671,9 @@
/* Sometimes our remote WMS only accepts square pixel */
-/* requests. If this is the case adjust grow the bbox so that */
-/* the pixels will be square given our map width/height. It */
-/* seems it is difficult to adjust width/height the way things */
-/* are structured now. */
+/* requests. If this is the case adjust adjust the number of */
+/* pixels or lines in the request so that the pixels are */
+/* square. */
const char *nonsquare_ok =
More information about the mapserver-commits
