[mapserver-commits] r10528 - trunk/mapserver
Tue Sep 28 12:15:53 EDT 2010
Author: warmerdam
Date: 2010-09-28 16:15:53 +0000 (Tue, 28 Sep 2010)
New Revision: 10528
   trunk/mapserver/maprasterquery.c
remove inaccurate comment, someone has implemented tileindex extent support
Modified: trunk/mapserver/maprasterquery.c
--- trunk/mapserver/maprasterquery.c	2010-09-28 15:35:41 UTC (rev 10527)
+++ trunk/mapserver/maprasterquery.c	2010-09-28 16:15:53 UTC (rev 10528)
@@ -1488,15 +1488,6 @@
   CPLErr eErr = CE_Failure;
   char *decrypted_path;
-  ** For the time being we only automatically derive extents from
-  ** single raster files.  Opening many raster files from a tile index
-  ** in order to get the extent would be potentially very expensive.  We
-  ** could - in theory - scan the tile index and build up an extent from
-  ** the polygons but that is quite complicated code wise, so I am leaving
-  ** that till someone cares more about the issue.  (#79)
   if( (!layer->data || strlen(layer->data) == 0)
       && layer->tileindex == NULL)
